Mike534x
- Apr 9, 2012
- 918
Fixed the exhaust leak on the Envoy finally! The tick from the front driver side exhaust manifold had been getting louder over the past 2 months, thought it was the lifters but saw the manifold had a gap between the headers that a dime could easily squeeze into....yikes.
Ordered a Dorman 917-142 exhaust manifold clamp, that supposedly fits the front driver side. While the hole for the coolant sensor lined up, the clamp was incompatible. The manifold for the LH6 has a slightly different design from the one used in my Avalanche. There is a bit of a "hump" where it meets the heat shield, this "hump" prevents the clamp from lining up with the screw holes properly causing it to be off about 3/8 to a 1/2". Decided to search again for a fix, but this time searching for a clamp that fits the TB SS, and came across the #KAP108 clamp that fits the 5.3/6.0 (verified to work with the 360/370). Got it today and installed it a few minutes ago. The tick is gone, and it sits flush against the manifold and block. What a difference, and $50 was all it took! Next step is to figure out where the "vibration" noise I'm getting on startup from the truck is coming from.
