Envoys are sooooo much sexier than Trailblazers!
Apparently I have been living under a rock and didn't know Ascender tails fit Envoy![]()
Did you have any trouble wiring them up or are they plug and play?
@xavierny25 Thanks for the pics. I really like the look of your truck. I'm still trying to find a set of those 18s to replace my 17s as backups.
As long as it doesn’t sound like a darn rice burner
Original handle: An idiot friend tried to open the glove box while it was locked and the surround cracked, which annoyed me because it made the handle loose. Then the linkage came disconnected so I had to smash the handle out to be able to open the glove box.What was wrong with them? Mine never broke. Of course, I never had a broken console lid, or dead ignition switch, and my fan clutch only just started to die after 200k miles so I may have been lucky.
@CaptainKD are those the DNA motoring ones?
was that pressure reading with the engine running? I only added until I got to 35psiHad one of those " I should of known better and checked that" moments.
I had no a.c. this afternoon so I thought wow its been over 3yrs since i recharged the system. It could be time for a charge. Ran over to auto zone spent a $50. on a charging can with a gauge. Walked out cranked up the a.c. in the Voy along with turning on the fan for the rear. Popped the hood open slapped on the gauge and can of r134 and the pressure is at max. I thought oh shyt I'm screwed. Looked over at the compressor and the clutch isn't engaged. Walked over to the fuse box and sure enough I screwed up when deleting the sais system. I removed the wrong relay. Smh. Grabbed the relay from the sais location swapped it over and my a.c. was working right as rain. Big Issue averted.View attachment 84255
But now I'm stuck with a can of r134 I never needed in the first place.
That's when I finally got the compressor running it made it's way down to about 40 psi before I disconnected the gauge. Took about 7 minutes to get it down to 40 from pegged to the max.was that pressure reading with the engine running? I only added until I got to 35psi
Got.my front camera installed. It was easier than I thought.
So you're running front and rear? Or just front?
Took pic's of it for @dna59 View attachment 84083
It's dark and wet out but this is the best I can do for now.
