Short Bus
1,906
jrSS said:
Updated pic of my tinted tails
Anyone wanna get rid of some leds???
Ebay, but you'll need to mod your boards, or I'll give you a good deal on my boards that I'm not using (non-SRCK + quad tails).
[EBAY]190472615418[/EBAY]
or
[EBAY]180968958643[/EBAY]
I want to try these for reverse lights
[EBAY]160804484310[/EBAY]
I have these (not bad, but could be better)
[EBAY]271046543094[/EBAY]
ramrod919
42
Short Bus said:
And why did the DEALER do your brakes? It amazes me how much people will pay for a simple job like brakes. If you don't know how to do brakes, how would you check to see if they did them correctly?
They had them done before we bought the TB. I just recently learned how easy brakes are to do, had to do the rear brakes on the Suburban. Basically, if you can operate a jack and turn a socket, you can do your own brakes.
Today, I put the correct size belt on the truck. Partially my own fault for not remembering the LWB gets the short belt.
Feb 18, 2012
27
Well today I was in clean mode. I decided to clean up the truck inside and out and even cleaned the throttle body.
Am I the only one that can never find an air freshener that doesn't smell terrible? This is the third time trying and I give up now.
Voymom
2,523
I got pissed off and took a can of spray paint to the truck....pictures to follow tomorrow, to dark now.
...................... :ugh:
ramrod919
42
Fire06 said:
You are on the road to becoming a GMTnation backyard mechanic Ramrod :thumbsup::thumbsup:
Well, I have always loved to "tinker" and do basic routine maintenance. But, with recent changes in finances, I have had to take many more maintenance issues into my own hands. But, now I can teach my boys to save some money and do it themselves!
TangoBravo
208
Took mine to the lake with my wife and son. Then cleaned the throttle body when we got home.
Voymom
2,523
Simon01
116
Got my temp sensor and harness from Amazon today, so I soldered the harness in to complete the installation of my new (used) auto-dim compass temp mirror.:wootwoot:
Need to backtrack slightly.....
Had tires mounted sometime when my son's shoe size was a half size smaller earlier this year.......with kids it's hard to keep track. :smile:
Before I had the tires mounted I replaced my left tie rod end to end up with the correct alignment.
I had a wait appt on a Sat and low and behold, the alignment rack wouldn't power up. I was sent to a sister shop 10 miles away and when they finished I hit the hwy to find my steering wheel crooked. Came back and they said someone was already on the rack and I was furious. I gave up and had stuff to do. Went back to original shop next week and they straightneed it but said I needed lower ball joints and bring it back when I replaced them. Fine.
Granted this is my goto shop so when I spoke with the manager about my ordeal I had some free goodies. :wootwoot: They cannot guarantee my tires without a proper alignment so that's understandable.
I originally replaced the left tie rod and the shop moved the right one due to the spray oil I found...:confused:
So what did I do to my GMT today.....
When I stopped for a cup of joe on the way home I felt the tires and they were warm on the insides, due to slight wandering I figured they were toed out.
When I arrived home (10PM) I jacked up one side (in the driveway with a flashlight) and rotated the tires, beforehand I measured my front toe.....the center tread was just over 1/4" wider in front so it was toed out big time. I took each tie rod and brought each side in 1/2 turn and now she doesn't wander and after about 15 miles the front tires were cool across the entire tread. Didn't measure but will in the morning, however I can guarantee it's ALOT straighter than it was and probably right on track or within spec.
Naturally I can't count on that and will get it checked but lower ball joints next for sure. I was getting some slight feathering on the insides which sparked my whole process. At least for now I can save the tread until I do get the alignment.
fletch09
1,982
dropped it off @ the dealership for some warranty issues.
squeeky brake pedal. believe there is a TSB out there for it
fog lights; inside reflective part is flaking/discoloring
RUST on the lower inside of rear pass. door
only an 09 w/ 44825 mi
Shipped off the pcm for reflash
jrSS
Sorry to tell u this but the rust warranty is for rust thru only. Just sayin. But goodluck. Maybe u will get lucky!!
Boricua SS
3,080
reflash :undecided: adding something new are we??
as for what i did to my GMT... just starred at it in the garage again lol... its been raining all week here so she hasnt moved from the garage again... plus i just stare at her to decide what i should do... keep her, trade her in, out right sell her, the saga continues lol...
Remove some codes...adjust tire size...change few other settings
jrSS
That's easy. Get rid of her and sell ur go fast parts to me. Bwhahahaha
SBUBandit
597
I have very similar rust on the bottom of the pass door. Anyone know the best course of action to keep it from spreading and becoming an issue?
JRTAHOE
848
CdnGMan said:
a thorough hand job tomorrow - I gotta try and outdo Darren (DnD) and Stef (Harmless)... LOL!!
:rotfl::rotfl::rotfl:
cody_s
625
Atlanta, GA
^ LOL :biggrin:
Got to work cutting down my CB antenna a bit to tune it. I had been getting around 2.5:3, now I'm like 1:1.5. Next time, I'll have to be sure to get one with the tuning screw in the tip, this whole cutting fiberglass thing gets annoying after a while. :tongue:
fletch09
1,982
thats what i was told. only covered if you can poke a hole in it.
i'm at an impass on what to do.
i still have till 01/2014 and aprrox 30,000 mi left on extended warranty ($0 deduct)
do i fix it now, or by 01/2014 make sure you can poke a hole in it :undecided:
SAR85
74
Painted some more trim...the front bumper plastic and grill. Also sanded, primed and painted an underbody crossmember that had a bunch of rust spots from rocks chipping the paint. Not the best lighting, but some pics anyway:
Oh yeah, also did the door handles:
TangoBravo
208
Plugged my bran new Guard Dog because I picked up a nail somewhere. It never happends when you need to replace a tire, oh no it happends right after you put new ones on fricken figures.
AV8ER
260
Lol i had the same problem when i got my new tires. It was about 2 weeks and i picked up a nail
Fire06
7,223
You never get a nail in the old tires just the new ones. On the car with the new snow tires last year we picked up two nails in the same tire. Just to make you happy :hissyfit::hissyfit:
TangoBravo
208
I feel good now knowing I am not the only one who gets screwed. (cheesy pun intended):wink::wink:
TangoBravo
208
Fire06 said:
Tango I am leaving that one alone:rotfl::rotfl:
Yeah I had the chance and took it. :wootwoot:
MAY03LT
Delmarva
Today I finally dropped and filled the rear diff fluid in my 03. The fluid had 80K on it and it was the nasty lol.
Voymom
2,523
Voymom
2,523
Fire06 said:
Just noticed Voymom that your truck is dirty :raspberry::raspberry: :rotfl::rotfl:
Just washed it!!! But it's dirty again lol took it to take pictures for the next picture contest :raspberry:
Voymom
2,523
jrSS said:
Huh. Next pic contest. What's the theme?
Big Ed will post it, Mat e-mailed him already with the theme....I just got a head start :raspberry:
I'll give you all a hint though
Harrisons
