Fire06 said:
Good luck Blazin I just did all that and the bushings in the control arms also.
Where's the write-ups, pics, and vids?
10,812
02TrailBlazer said:
Back to stock at the moment, it is really faint at stock config. only enough to dimly light the front 194's. I originally noticed it when I put in my modded taillight boards with led bulbs which lit up like I had my hazards on whenever I went to turn lol, so I took those out and went back to stock for the troubleshooting which hasn't ended yet.
AFAIK, it has to be a bad ground for the turn signals OR bulbs/sockets that are messed up.
I'd rather fix the source of the bleed but if it comes down to it I'll just add diodes.
On a side note, if I determine that it's turn signal grounds it should be a cleaning of G401 and G402. That or I make a new ground straight to the battery.
I'm showing G107 and G103 for mine, maybe I'll get under there and check mine as well for good measure, since I'm really hoping this isn't a wiring issue that I'll have to track down. I only added the diodes on mine because I didn't build the switchback circuit myself, so I didn't know what all of the connections were, and the LED bulbs I was using before didn't have this problem. My diodes were downstream of the 3157 sockets.
Reactions: 02TrailBlazer
02TrailBlazer
64
Those are just what I came up with from some searches, I think it was on the "other" site. Best of luck!
kjkim93
696
Got that ext rear heat hose thing that connects to the intake manifold. I think gmpartsdirect went a little over board with the box
MAY03LT
Delmarva
Got my EXT shortie serp belt today.
MAY03LT
Delmarva
kjkim93 said:
There's a shorty version for us?
Yeah, two different sized belts for the I6. The EXTs have a shorter serp belt (90 7/8") then the SWB's.(92 1/8"). These measurements are for the ACD belts, I think when I looked at rockauto the goodyears were slightly different.
kjkim93
696
Oh god. Hopefully they gave me the right one. According to my vin
MAY03LT
Delmarva
If their 2290mm measurement is correct, it will work. :cool:
High Voltage
Yeah if I get this damn thing figured out! My phone didn't work for a week +. Didn't know it cause it worked when it was on WiFi at home.[emoji16]
Reactions: Midnyteryder196
Darkrider_LS
9,332
sawicksted said:
Quad beam MOD :wooot:
Got some MUD on the truck.... see - just like the sign says!!!
That plate looks familiar lol
sawicksted
366
Darkrider_LS said:
Sk. Canada!!! Good old Canadian tire - gotta love it. The interesting thing is that we have red mud here and the plate I got has "reddish" mud splashes on it where as your has the "greyish" mud splashes.
Pretty cool!
Loaded it for a 3 day roadtrip
MAY03LT
Delmarva
kjkim93 said:
Wow that's some pretty quick shipping.
What's in the box? :undecided:
Nice!
Reactions: jrSS
dmanns67
32,979
Ordered some smoke vinyl film for the tail lights, 3rd brake light, and rear reflectors. Picked up some new bowtie vinyls from Motor City Vinyl for the new center caps I just ordered to replace the ones on the SS wheels. I called every dealership locally and none of them had the center caps in stock. They also wanted any where from $20 to $28 each for the center caps. GM parts direct had them for $11 each.
Reactions: TexazReece and jrSS
4,052
Parked it outside the garage for the first time last night...more in the FU thread.
Reactions: Robbabob
Drove it to work.
MAY03LT
Delmarva
Got the new alt today. I was thinking about some things and I realized that the batts that I have now are getting close to 5 years old so guess it's time to replace them as well.
jkmichigan
