NEED HELP Unknown Driver and No Start
TJBaker57
3,502
Colorado
continuity line communication pcm canle dark green. It's ok
This refers to post #203
I continue to review all of this thread amd look for possible answers. In this picture, testing continuity of dark green PCM serial data wire, what is the reading on the meter? Does that read 10 ohms? Should this not read at or very close to zero ohms?
Does anyone know what would be the threshold of resistance reading on a class 2 serial data line before the signal might be attenuated enough to cause a lack of communication?
budwich
2,257
kanata
I don't know the actual value but I don't think "10" anything is correct for basically a wire run. Having said that, the OP is using the "beep" mode which isn't a very good resistance measurement AND you don't know how much his "test lead setup" is by itself... some baseline measurements are needed there in. I think that you have pointed out a lot of "not sure how you did this" stuff for the OP to double check especially around pins.
Mramses
322
17176352
Mramses
322
17176352
Now what should I check friends?
I check again the resistance from c1 59 to sp205 dark green wire.
and the resistance from c1 58 to f12 c2 bcm?
Reactions: TJBaker57
Mramses
322
17176352
I made a cable with ties of more than 4 linear meters long and it has a resistance of 1.8 ohm
Mramses
322
17176352
resistance measurement in this order
c1 59 to sp205 dark green cable
c1 58 to c2 f14 bcm yellow cable
sp205 a c1 b1 bcm
all values do not exceed 2 ohms
Mramses
322
17176352
Have you taken readings on the PCM, C1 pin 59 to PCM ground, and C1, pin 58 to PCM ground? On my truck PCM the readings are:
C1, pin 59 to PCM ground = 4.66k
C1, pin 58 to PCM ground = 1.2k
c1 pin 58 to ground c2 pin 65=43.6 kohm
c1 pin 59 to ground c2 pin 65=43.6 kohm
Mramses
322
17176352
friends could bcm be bad? and cause these problems?
Even with the tester it is not possible to measure fluctuating voltage of the data class2 communication line, the measurement of the voltage + green cable bcm and - cable to ground, there is a voltage fluctuation between 0-3 vdc perp after a few seconds it disappears.
the same is true for the pcm.
But when measuring voltage between + gray cable (cluster) and - to ground, a fixed voltage of 1.19 vdc remains, this voltage does not change at any time, it only drops to 0 when turning the key off
Mramses
322
17176352
C1 pin 58 PCM to ground pcm=9.56 kohm(20k)
C1 pin 59 pcm to ground pcm=9.56 kohm (20k)
if I change the scale from 20k to 200k they give these values
at 20k gives 9.56 both pin 58 and 59
at 200k gives 43.6 both pin 58 and 59
budwich
2,257
kanata
try changing the batteries in the meter. I don't believe that your meter should give different readings on different scales. The scales have more to do with the number of digits available for display. A reading of 10k on the 20k scale will read 10.0 but on a 200k scale will read 10.
TJBaker57
3,502
Colorado
Was this your truck prior to having the engine work done and did the cluster work OK then?
Is it possible the cluster is bad?
I tested my cluster, splice pack comb removed, key to RUN and read 0.04 to 1.76 VDC. The high readings were directly after turning the key on. It then settled to 0.04 and fairly remained there.
TJBaker57
3,502
Colorado
Oddly, I have a meter that behaves the same on some circuits but not others. I have been puzzling over this. Same circuit seen here. My autoranging meter shows yet another reading!
Reactions: Mramses
Mramses
322
17176352
but it is not normal that it measures a fixed voltage of 1.19 vdc. must it be bad?
budwich
2,257
kanata
View attachment 97090View attachment 97091
quality of the meter... :smile: and possibly some "finger problems" during use... for example, trying to measure resistance in a circuit that is powered. Depending on what powering is in a circuit, it may cause "internal problems" with the bridges that are used to measure the resistance. Of course, a check would be an out of circuit, free standard resistor. You know it can not change value from one range to another.
Mramses
322
17176352
Have you ever tried to start the truck with no comb in the splice pack sp205? What happens?
Yes, friend, I try start every time I do any of the tests that it indicates. so far nothing different all the same.
Check engine turns on, does not start, doors do not work, windows do not work, hvac does not work and unknown driver
8,573
You have probably already done or tried what is covered in this Video... But Just In Case ...Not Yet...
TJBaker57
3,502
Colorado
@Mramses
Did you say you had the App "Car Scanner Pro"??
Car scanner Pro has a terminal screen that allows us to 'talk' to the ELM327 and also the vehicle network. The terminal screen is in the "Setting" menu selection. It does NOT do the commands for you, you must know what to type. Here in this first short clip I connect to the ELM327 and ask it to tell me what protocol it is using to try to connect to the vehicle. For our trucks this must be SAE J1850 VPW. This is not speaking to the vehicle yet. This is only talking with the ELM327. But this is where we begin....
Edit: The video seems to clip off the last screen so here is the final output...
TJBaker57
3,502
Colorado
@Mramses
Here in this video I use Car Scanner Pro terminal to ping all modules on the vehicle network. This might be able to tell what modules are working on your truck, as long as the network is not prevented from working by a short circuit or a bad module. If you can get some communication established you could maybe determine what modules work and what modules do not.
Mramses
322
17176352
@Mramses
very interesting friend. To do these tests, must the sp205 and sp 306 be connected?
How can you know which command corresponds to which module?
TJBaker57
3,502
Colorado
You can connect any modules you wish to test. Just jumper them to the purple DLC wire. You can test one at a time or any combination.
But first must confirm the ELM327 device connects with SAE J1850 VPW. If it reads something else then there is another command to switch that to SAE J1850 VPW.
The third byte is the address of the responding module:
10 = PCM
1A = TCCM
29 = EBCM
40 = BCM
58 = Supplemental Restraints
60 = Instrument Panel Cluster
80 = Radio
81 = Amplifier
97 = Onstar
98 = HVAC Module
A0 = Driver Door Module
A1 = Passenger Door Module
A2 = Liftgate
A7 = Rear Seat Audio (+HVAC)
8,573
budwich
2,257
kanata
mramses, you continue to be side tracked. TJbaker57 has posted video that shows you only need the PCM to be working. Doing anything beyond that is a waste of time at this point.
TJBaker57
3,502
Colorado
If this refers to the tests using the Car Scanner app,,, that is indeed aimed at seeing if the PCM is communicating at some level. My tests using the cluster has one inherent flaw,,, what if the cluster is the issue causing the PCM to cluster comm failure? Mramses has tested powers, grounds, and the serial lines from the PCM. Tested internal resistances of the PCM as well and though I see variances with his readings vs mine we have no official documentation to give guidance on what is the right reading. We know the PCM is functional at some level due to the lighting of the MIL light at key in RUN position plus the fuel pump primes, also a PCM function. Short of swapping in yet another PCM I'm not seeing what else to test on the PCM. Anyone got a suggestion?
@limequat Any insight on testing a PCM to confirm operability?
Reactions: Mramses
budwich
2,257
kanata
I was referring to your post of a video (post 178) showing how a truck runs with the PCM and NO comb pack installed with NO jumpers. Hence, you only need to focus on the PCM and not worry about the other modules. Maybe I misunderstand... in which case I leave. Further, the resistance measurement of this devices can't be all over the place... this is either a meter problem or a device issue. The metering can be check against know resistance. Further, I don't believe the OP actually confirmed proper pins for voltages. Anyway, you will make progress based on the great information that you have provided... it just needs to be conveyed to the other end.
TJBaker57
3,502
Colorado
Ah! I see said the blind man!
Agreed. But how do we know the PCM is talking? The PCM must communicate with the BCM or you get no crank. The reason it starts without a comb is because the PCM and BCM are connected by a serial data line (yellow wire) that bypasses the splice pack entirely. So I think an attempt at confirming serial data activity from the PCM is warranted.
You don't misunderstand, I think we are on the same page, but taking different approaches to the same goal of evaluating the PCM functionality.
Also agreed. But I have no known resistances at my end and I have no idea what he has either. I felt I was hitting some limits of my knowledge here and maybe another avenue might yield some results.
There is indeed a lot of images to review and some are erroneous measurements for certain. My PCM begins serial data with only pin 20 (hot at all times) and pin 21 (Ign 0, ign sw terminal E, rear fuse 47) powered. In reviewing all the photos yesterday in this thread I 'thought' I found those pins powered in Mramses posts.
Mramses
322
17176352
Help
TJBaker57
3,502
Colorado
What are the conditions of this test? Serial data jumpers? Splice comb installed or no?
If yes, then try this again with no comb and no jumpers installed. Edit: This was wrong.... You need at least one jumper from the purple wire to somewhere. Try PCM, try Instrument cluster, try Transfer Case module.
Mramses
322
17176352
good night friends. the test was with the sp205 comb installed
TJBaker57
3,502
Colorado
It has the appearance of somethong wrong on the network. Like a bad module. One bad module or a shorted wire can short out the network and then no communication is possible.
We already suspect either PCM or BCM so it may be wise to establish communication with other modules to prove the elm327 works. Remove the comb and try with a jumper from purple wire to some other module or modules. Try the blue & white wire to the rear splice pack, that would give 3 or 4 modules. Key needs to be on.
When the elm replied "searching" this meant it was trying different protocols in an attempt to establish communications. By default from the factory the elm327 is set to try protocols in a set order. We can reset it to use SAE J1850 VPW. Do this by entering in the terminal screen AT SP 2.
nelkin79
