Members projector retrofits
10,688
I had the XB halos, only 2 wires passing through a driver. Which halos did you get?
littleblazer
9,267
Maybe it shuts them off when the projectors turn on?
10,688
:undecided: This may be the case, as it's commonly known that the LEDs in the halos die out unexpectedly quick when left on at the same time as the HIDs. :hopeless:
Aarkon
5,607
I had a kid buy a set at work ive been debating that myself im wondering if they are supposed to shut off for the turn signals it was the first time ive seen those as well
Mounce
13,667
Tuscaloosa, AL
What a great idea! Lol that hadn't even crossed my mind. Thanks fellas. :tiphat:
Now if only I could get demon eyes to turn off with them. Any ideas?
-and if it's for the turn signals I wouldn't hook it up, Ryan. As soon as you remove power from the white wire, it comes back on. So it'd act like the AW switchbacks kinda.
-and Carlton, the xb halos that are currently in closeouts.
littleblazer
9,267
Perhaps use a normally closed relay for power then when it energizes it kills the demon eyes and halos?
Mounce
13,667
Tuscaloosa, AL
That's those 5 pin relays isn't it?
I thought about that, I'll definitely do my homework.
-five minutes of homework and after finding an explanatory wiring diagram I understand it. Thanks for the idea LB. :tiphat:
Reactions: littleblazer
littleblazer
9,267
Thats the easiest way I can think of doing it.
10,688
From the TRS site regarding the halos:
Simplicity: Wiring is easy with a variant of the X Change Module integrated into the LED driver that powers each ring. The white wire receives a constant 12V+. The black wire is grounded, and the yellow wire is tapped into the turn signal circuit.
That's what I built for my current retro. I had a pair of mini relays, so I stuck them on a cut down piece of perf board, and soldered some wires to the appropriate connections to make a small control module that can sit inside the headlight.
Mounce
13,667
Tuscaloosa, AL
That's almost the same thing Dave said, I don't have their fancy XSB halos with the X.change drivers thus I have no yellow wire.
-okay, second paragraph in the link in your post kind of explains it but still isn't exactly for my application because I don't have white/yellow/black wires but that's how I plan on wiring mine since the white wire acts pretty much the same as the yellow wire.
I sent TRS an email so we can get a definite answer lol.
Mounce
13,667
Tuscaloosa, AL
The verdict is in....
"Hello Garth,
If you're referring to the third wire to the setup that's actually a "DRL" wire. Basically you would tap that wire into the low beam headlight's positive wire and it would turn the LED ring off when the headlights came on. Something we would highly recommend to add some longevity to the setup since these LED rings are incredibly sensitive to heat when in use."
littleblazer
9,267
"Hello Garth,
Holy cow I guessed right on something. Time to play the lottery.
68impalacp
37
Got them all finished up last night. Installed them this morning. Love the result. I need to order new switchbacks for my turns apparently I order the wrong style bulb.....big thanks to everyone who's done retrofits for reference and those who have helped when I had questions.
Mounce
13,667
Tuscaloosa, AL
Right on bro, looks good!
Reactions: 68impalacp
GMCRick
17
Looks great, how hard was it for you to do?
littleblazer
9,267
So all you guys with projectors, how far do you have them aimed up and where do you have the step relative to the road?
Just curious is all.
dmanns67
32,979
You can do the measuring method, but I do real world driving for adjustment. I want the cutoff line right below the driver's side mirror of other vehicles.
My step comes all the way over to the lane divider.
littleblazer
9,267
Okay. My cutoff is right below a cars mirror, but the step is more centered in the lane.
littleblazer
9,267
I wonder if I should move it over toward the divider. It would help the visibility some.... projects for another day.
Aarkon
5,607
Apparently they recommend 42 inch from the ground but that seems like garbage so I agree with dave do some driving and adjust them to your needs ive never been flashed with my quads so they must be good enough
dmanns67
32,979
Yeah it would. Thats the whole point of the step. Lights up your entire lane then steps down for oncoming traffic. If your're half, I wouldnt open the headlights just for that unless you are doing something else.
littleblazer
9,267
Whatever the height of our mirrors are is what mine are currently at. [emoji13]
littleblazer
9,267
I actually don't remember what I did. I need figure it out. My sheet with measurements is still around. Maybe in the morning.
littleblazer
9,267
Found it. So at 25 feet the step is the same width as center to center of the projectors. Height is mirror height to bottom minus 5 inches. I believe that makes it 37ish high at 25 feet.
Theblackarrow
95
Hi Guys Did anyone here in the community tried to do a retrofit with Audi Style LED Eye line i believe it will be really awesome it's something that have been coming in my mind lately especially after the big failure i had with the eBay Halogen Projectors LOL maybe some one can put a mock up design how shall it look like cause i have a picture of it in my imagination that literally eating my brain
see below
http://www.ebay.com/itm/Audi-Style-LED-Eye-Line-Head-Lamp-Light-DRL-For-12-2015-Hyundai-Elantra-GT-I30-/171028487190
http://www.ebay.com/itm/For-Audi-Style-White-Amber-Tube-Switchback-Headlight-LED-Strip-DRL-DC-12V-2x60cm-/141502456657?pt=LH_DefaultDomain_15&hash=item20f2342351&vxp=mtr
http://www.ebay.com/itm/Chevrolet-Cruze-2010-2012-Audi-Style-LED-Xenon-HID-Projector-Headlights-/321649670880?hash=item4ae3d07ae0&vxp=mtr
Aarkon
5,607
I have a set of those laying around my house but I wasn't very impressed with the light output on them
dmanns67
32,979
I acutally like flexiable silicone look better than the strips with the individual chips. Not sure how they would look in our headlights. Maybe if you used them as switchback turn signals. Maybe run two horizontally in the main turn signal and run one veritcally in the side marker turn signal.
Are you still messing with the EBay halogen projectors?
For all you whores out there wanting to upgrade your HID bulbs, TRS has 880 and 9006 3Five HIDs in the closeout section. Brand new for $15 a pair. Not sure what kelvins are left. $15 is cheap for the Morimoto HIDs, just to have a set as back up :yes:
http://www.theretrofitsource.com/closeouts.html
Reactions: Mounce and Sib
Aarkon
5,607
I am slacking. I need to get my fogs finished. Most likely will not have time to work on them until we move in June.
Ya I wondered why I haven't heard from you about them or seen any pics you slacker haha
Aarkon
5,607
Ordering a pair of x lense d2s 3.0 projectors tomorrow and gattling shrouds tomorrow for these lt lights already picked up the silver paint
Reactions: Sib and Mounce
onlyatauction
