littleblazer said:Maybe it shuts them off when the projectors turn on?
 This may be the case, as it's commonly known that the LEDs in the halos die out unexpectedly quick when left on at the same time as the HIDs.
 Perhaps use a normally closed relay for power then when it energizes it kills the demon eyes and halos?Mounce said:What a great idea! Lol that hadn't even crossed my mind. Thanks fellas.
Now if only I could get demon eyes to turn off with them. Any ideas?
-and if it's for the turn signals I wouldn't hook it up, Ryan. As soon as you remove power from the white wire, it comes back on. So it'd act like the AW switchbacks kinda.
-and Carlton, the xb halos that are currently in closeouts.
Simplicity: Wiring is easy with a variant of the X Change Module integrated into the LED driver that powers each ring. The white wire receives a constant 12V+. The black wire is grounded, and the yellow wire is tapped into the turn signal circuit.
Mounce said:Now if only I could get demon eyes to turn off with them. Any ideas?
That's what I built for my current retro. I had a pair of mini relays, so I stuck them on a cut down piece of perf board, and soldered some wires to the appropriate connections to make a small control module that can sit inside the headlight.littleblazer said:Perhaps use a normally closed relay for power then when it energizes it kills the demon eyes and halos?
That's almost the same thing Dave said, I don't have their fancy XSB halos with the X.change drivers thus I have no yellow wire.Blckshdw said:From the TRS site regarding the halos:
Holy cow I guessed right on something. Time to play the lottery.Mounce said:The verdict is in....
"Hello Garth,
If you're referring to the third wire to the setup that's actually a "DRL" wire. Basically you would tap that wire into the low beam headlight's positive wire and it would turn the LED ring off when the headlights came on. Something we would highly recommend to add some longevity to the setup since these LED rings are incredibly sensitive to heat when in use."
I will take a set!!!Aarkon said:20150226_212501.jpgwill be doing an all chrome set on these plan to have them done by sunday to sell and hopefully recoup some of my money
Pm senteutechnyx said:I will take a set!!!
Right on bro, looks good!68impalacp said:Got them all finished up last night. Installed them this morning. Love the result. I need to order new switchbacks for my turns apparently I order the wrong style bulb.....big thanks to everyone who's done retrofits for reference and those who have helped when I had questions.
Looks great, how hard was it for you to do?68impalacp said:Got them all finished up last night. Installed them this morning. Love the result. I need to order new switchbacks for my turns apparently I order the wrong style bulb.....big thanks to everyone who's done retrofits for reference and those who have helped when I had questions.
Ya the fogs will be color matched for sure just cant paint until they are mounteddmanns67 said:Not color matching like the headlights?
Ya I wondered why I haven't heard from you about them or seen any pics you slacker hahadmanns67 said:I am slacking. I need to get my fogs finished. Most likely will not have time to work on them until we move in June.
