NEED HELP CEL with P0332 rear knock sensor - how to test wire?
trkpony
Houston
Hey all,
I have a 2007 GMC Envoy 4.2L I6. It has about 150k miles on it, I bought it in 2010 with about 35k miles on it, I'm the 2nd owner.
TLDR: P0332 won't go away. I changed sensors and plugs. What's the next step for diagnosis?
Recently replaced all the front end suspension and steering components, and changed the oil.
The vehicle has a leaky valve cover gasket and has had it for a long time, so it has always had a bit of a misfire mostly just noticeable at idle, it hasn't ever effected driving conditions. When I checked in the past, I know there was oil leaking onto the spark plugs.
I got a CEL for code P0332. Which by my search, shows a low input on bank 2 (rear) knock sensor. I turned the key on with engine off, KOEO, and checked the voltage with a meter holding one probe on the negative battery terminal and the other probe on the sensor connector and got a voltage reading of 4.052V. I have read it is supposed to have 5V, so I am not sure if this 4.052V would set off the low input reading for the CEL.
1. Is 4.052V too low for the expected voltage reading on the wiring harness connector?
Since I am getting voltage, and I don't know the answer to the above question, I figured the wiring should be good to the connector, so I went ahead and ordered 2 new AC Delco sensors from RockAuto. I replaced them and torqued them to somewhere around 20ft/lbs (My clicky torque wrench starts at 30ft/lbs and so I used the other manual dial/gauge style torque wrench that I have and tried to get it close/above the 18ft/lbs reading)
Reconnected sensors, reset the CEL with the cheap little reader that I have and drove around. The code came back and is the same, P0332. So then I went and swapped the sensors from the front bank to the rear bank to see if the code would shift from P0332 to a different code for the front bank (P0331?) following a bad sensor after the swap.
I should have tried this swap PRIOR to ordering new knock sensors, but I didn't think about it at the time... anyways, the light still came back on and it is the same P0332. So swapping the sensors didn't shift the code to the front bank, so I assume the sensors are good... I have seen a couple videos on testing the sensors, but I wasn't real confident in my results when I tried to test the sensor by itself. All the videos show a slightly different style sensor, like from the v8 motor and I wasn't sure where to test on the 4.2L sensor.
So THEN, I replaced the spark plugs with new plugs. 41-103 AC Delco plugs. When I pulled the old plugs there were a couple that shows oil all the way down their threads. But I haven't ever received a misfire CEL. Also, the cylinder 3 plug had cracked porcelain. I'm not sure how that would happen?
Pictures of spark plugs attached.
I haven't heard any weird popping or pinging noises that I would think I should hear if I have uncontrolled detonation.
What's the best next step for diagnosis? obviously I need to change out valve cover gasket, but should I run a wire from a pin to the knock sensor connector if the 4.052V isn't good enough? How would I do that?
thanks for reading all this and any help
The oil on the plugs are likely leaking plug well to valve cover gaskets.
Check the block's ground connections for corrosion or poor contact. Remove and clean thoroughly.
Then, get the schematic of the circuit from the manual from either Charm or Lemon and check for proper continuity, no shorts to ground or voltage. Check the connectors for corrosion at both ends. With both the sensor and PCM unplugged, there should be no voltage or short to ground.
Checking a little further, according to this video, there should be very little voltage to the sensors. Not the same vehicle or engine but his diagnostic process is very thorough.
So I'd compare the voltage between the two sensors. If just the one has voltage, this would need to be investigated further. In that case, I would look for damage in the wiring harness for a short to another wire.
I'm just going to copy-paste the "Intro" from a similar post which explains that by using my Snap-On Vantage Pro Diagnostic Scope that includes "Guided Component Tests"... these 60 images of ALL the Steps involved when doing the KS Diagnostics might "Lift The Stone" off of your chest. These are always technical, non-trivial diagnostics, but without you owning your own unit...THIS procedure is the Next Best Thing for what you need to know:
Welcome to GMT Nation,
Let me know if this appeals to you, but I can plug your 2007 GMC Envoy parameters either into my Snap-On Vantage Pro Graphing Multi-Meter and Scope and check out the KS Diagnostics Steps needed here through the "Guided Component Diagnostics" for your particular SUV and then produce all of the necessary Step By Steps that can be Screen Printed and Posted right back here.... if you think that would help.
Usually, all of these Steps are done with exquisite detail (sort of like Holding The Pro Mechanics Hand) and I have to take a digital picture of what each one looks like on the Scanner screen and then crop, scale and edit them one by one (NEVER a Problem with doing that Task) ...so there are always quite a few images to follow on with... but they will all appear here in groups of 20 images at a time as consecutive Posts that you can then download, save and just use them.
With these images, it will be as though these Snap-On devices were in your own hands while you are standing near the truck, trying to figure out WTF to do next. Other Members will probably chime in with much more direct ideas... but from a purely professional point of view...THESE Machines are very hard to beat for showing What to DO, WHERE to DO it and How to DO it with the RIGHT Diagnostic Tools to use... so they do work very well, too.
The First Batch of 20 of 60 Images Follow On:
Second Batch of 20 Images of 60 Total Images:
IMG_2388.JPGIMG_2389.JPGIMG_2390.JPGIMG_2391.JPGIMG_2392.JPGIMG_2393.JPGIMG_2394.JPGIMG_2395.JPGIMG_2396.JPGIMG_2397.JPGIMG_2398.JPGIMG_2399.JPGIMG_2400.JPGIMG_2401.JPGIMG_2402.JPGIMG_2403.JPGIMG_2404.JPGIMG_2405.JPGIMG_2406.JPGIMG_2408.JPG
Last 20 Images of 60 Total Images:
IMG_2409.JPGIMG_2410.JPGIMG_2411.JPGIMG_2412.JPGIMG_2413.JPGIMG_2414.JPGIMG_2415.JPGIMG_2416.JPGIMG_2417.JPGIMG_2418.JPGIMG_2419.JPGIMG_2420.JPGIMG_2421.JPGIMG_2422.JPGIMG_2423.JPGIMG_2424.JPGIMG_2425.JPGIMG_2426.JPGIMG_2427.JPGIMG_2428.JPG
End for all Three Posts.
NOTE: Because the Knock Sensor is classified as a "Piezo-Electric" Device that converts the tympanic engine vibrations and untoward shudders from a flexing speaker-cone like set of motions into Electrical Signals that require an Oscilloscope to be able to sense in very fine details and likewise see the images being created during the Tests above to prove that a New KS is working and that other issues (Broken Wiring) are not involved, feel free to drop in on THIS Link and find out whether or not you would like to get an inexpensive one for this problem and not go broke when doing so:
The SM "suggests" a "simple" impedance test of the wiring. Basically, disconnect the sensor. With an ohm meter, measure at the connector, each pin back to a known good ground. The reading should be "OL" (ie. infinity... no continuity)... do the measurement with "key off".
Compare the results for each pin and each sensor. Go from the results.
Ok, thanks to you three for the response.
I wanted to give an update because I haven't really had much time to jack with this over the past week.
I watched the video and looked at all the pictures here.
I then disconnected the newly installed sensors and used the multimeter on the ohm setting and checked the sensors.
I can't seem to get any reading on my multimeter from the sensors...
I put it in ohms mode, and selected the auto setting. When the probes are separate, I get OL on the meter. When I put the probes together I get a sound/tone and the meter shows zero 0.00.
I tried to test with both battery cables still connected, and key off engine off. I did not insert the key at all.
There are multiple ground connections on the drivers side of the motor. I tried to hold the black probe directly on the end of the wire spade connectors going to the bolts and also directly on the bolts. Then, I also tried using an alligator clip to connect one black probe to a ground bolt and then each time I tried a different ground bolt. I also held the probe directly on the engine block.
For each ground bolt, I held the other red probe on one pin of the knock sensor to test each pin on the knock sensor... But I'm not getting a reading. I just get OL on the meter. I did this for multiple ground bolts and all 4 pins, 2 on each front and rear knock sensor.
(What are the chances that none of these are good grounds?)
I also did this on the connector and same thing, I get OL. I put the red probe in each of the two pins on the connector separately and held the black probe on the ground bolt and got OL. (I think this is the simple impedance test mentioned above by budwich)
If I grab the end of the red probe I get some readings, I guess it is measuring resistance through my fingers to some other ground location. But I get nothing from the wiring harness connector or the knock sensor pins.
I also tried changing the settings with the auto button on my multimeter, but it doesn't effect the readings. I can change between AUTO, Mohms, Kohm, and just ohm scales.
What am I doing wrong here? Should I disconnect the battery? Should I be connecting both pins on the sensors instead of just 1 at a time?
Do the 4.2L I6 two wire knock sensors work differently than others?
Yes... that is the "simple test".... its basically used to "thumb check" the system side of things.... looking for some sort of "draw" (less then infinite). Of course, the results don't take into account a broken wire... but I think you did some other tests (voltage measurements) to prove that part.... BUT I see further down in the SM that ~4.2v (to ground) on each sensor is "nominal".... so it appears your earlier voltage measurement might be low... was that measured on both sensors? I guess that should have questioned at the start.... :-)
Be sure to check your main ground wire from the battery to the block. When I had my engine mounts changed, when they jacked the engine, the main ground wire was basically just green pus and whatever strands of copper that were left just broke. Do a resistance check between the block and the negative battery post. It should be very low, close to 0.
At this point, if I were you, I'd be checking continuity from the sensor connector to the PCM. The diagnostic aid from the manual also says to check the sensor pins to ground. Should be OL.
I just checked both the front sensor and the rear sensor. I turned the key on engine off KOEO, then put meter in DC volts mode, then I put the black probe on the negative battery terminal and red male probe on each of the terminals of the harness side connector, I got readings of around 4.02v, to 4.07v. I then moved the black probe to one of the ground bolts on the engine and same readings. I checked both front and back sensor connectors this time and both gave the same readings, so that isn't different from each sensor either.
thank you for the direct link to the Lemon manual, I see why you said to check it in your first post, walks you through each step pretty clearly.
So Step 1/2 is check for engine noise or diagnostic proceedure. I know my valve cover gasket leaks oil on the plugs, which is causing a misfire and could ultimately be causing this knocking too, so I need to fix that. But I don't hear any noise so I'm skipping this step for now.
Step 3, as you mentioned is checking the sensor pin to ground, which is what I did above and its reading OL. which appears to be good, I thought I was doing something wrong getting the OL reading.
I'll go try the next steps and report back. thanks again.
Now you getting into the "dirt".... both readings are "too conveniently low".... yet only one "complains". Its quite possible that your meter / leads might be "uncalibrated" such that a "small error" results (ie. the measure is actually close enough to the expected 4.2v.). Note: this value does not actually provide any direct contribution to the resulting code although perhaps if it was significantly low such 2-3v then maybe. The code appears to be set from more of a "ac signal RMS" type value. Hence, the sensor vibration frequency AND amplitude are important.
ADDED: did you measure the voltage on BOTH pins at the connector? OOPS.... I misread the SM... the 4.2v is the upper limit. The voltage reading should be below that value... which yours are.
At this point, without getting some sort of signal scope, it might be tough to find the issue... perhaps pointing to the PCM. Bringing you to the PCM... have you pulled the connector and looked at the condition of the pins in the connectors.... focusing on those associated with the sensors? Its possible that the have oxidized enough to cause a "base voltage issue" (ie. slightly lower sensor "bias").
NOTE: probing any pins in a connector is dangerous to the pin itself IF you don't use the appropriate size probe. Too large a probe may cause damage such that the connections thereafter are NOT very good in future operation.
ADDED: another test suggested in the SM is a "active test". disconnect the sensor in question. Carefully connect your meter with the sensor wire (ie. rig up some form of "T"). Set the meter on ac volts. Set the key ON ENG OFF. Get a reading... probably nothing... wait for it settle. Then get a non-metal "striker" and tap on the engine block near the area of the sensor. Monitor the meter, you should see some change in voltage showing up as the sensor "causes AC" to occur (basically modulating the dc signal... that 4.2v DC... I think).
A little update on this since its been multiple weeks... Problem still not fixed.
I decided to go ahead and change out the valve cover gasket, just to try to eliminate the possibility of the oil leaking on the plugs, causing a misfire, and the chance that I am actually getting engine knocking and just dont realize it.
It all went well, I took it apart, replaced the valve cover gasket and the intake manifold gaskets. I also replaced the thermostat while it was opened up a bit, because it is much easier to access the thermostat with the ECM, alternator, and upper intake removed. I also cleaned off the plugs, cleaned out the throttle body and the upper intake while I had them off.
I reconnected everything and it runs nice and smooth now at idle. I used to have a slight misfire and a little rough hiccupping at idle that I assumed to be the spark plugs with oil on them not firing smoothly, but not rough enough to set off a misfire CEL. At first glance, it appears that may have been the culprit or something on the intake/throttle body side that I cleaned while doing the valve cover gasket. Will have to continue to monitor this and see if the rough idle returns.
But for now, I did a test drive and sure enough, the CEL came back for the P0332 for the rear knock sensor. So I think I need to follow the suggestions and look at the wire or connector back to the PCM.
This is my next move. I will rewatch the video above and the info provided and find which connector the wiring for the knock sensor goes to in the PCM and I will need to buy a set of small connector probes to be able to probe that connection pin at the PCM connector side of the wiring to do the continuity test to the knock sensor connector pin.
Thanks again for the suggestions and help. I'll update after I test the PCM to knock sensor connector wires.
EDIT:
A Correction and Admission of Error needs adding ahead of this Post. Thanks to the follow on Posts by @budwich and @Mooseman after this one which informs My Mistake in the idea that the Knock Sensor is not the Fault. All of the other information is valid and worth knowing, however not factored into this Diagnostic. Thank Goodness for the "Hive Mind" at GMT Nation keeping me in line... Thank You, Gentleman!
I've been puzzling over this Thread over how much the focus of your investigation has been over the One Device that actually seems to have been functioning correctly by its very design as a *Warning* that the P-0332 Code indicates ... meaning that it is actually WORKING and perhaps to just just "Take It's Word For It..." that there is Neither a problem with the Knock Sensor... Nor with the Wiring in between the Sensor and PCM... It is just emphasizing that the actual root cause of this problem has yet to be discovered.
The P-0332 Code is not a cause... but an effect that perhaps has a less obvious Point of Origin in either one or more Coil On Plug Ignition Coils...and drilling down even further... the principle of "Shorting To Ground" outside of the Cylinder Interior where you would expect the Spark Plug Electrode Ignition Plasma to fire if the atmospheric (Air to Fuel Balance of 14.7 to 1 ) should occur... --== but which will become impossible to achieve if those conditions become TOO LEAN ==-- due perhaps to failing EFIs properly spraying Atomized Fuel versus Fuel Droplets that are incapable of burning due their inability to Mix with NA Inhalations... or due to Weakened or Failing EFI Coil Windings.
It will not be within most of our repair experiences and conventional thinking to realize that several dreadful things will follow on that can cause internal cylinder conditions to happen that WILL cause Pre-Ignition and Mis-Fires to happen.... involving Super-Stressed Coil On Plug Secondary Ignition Events climbing to ridiculously HIGH KV Levels because there are simply not enough Hydro-Carbon Molecules vs Available O2 to allow an Electrical Spark to propagate INSIDE of the Cylinder(s) as the Spark Plugs TRY to Fire... Just BTDC.
It is this NEXT Part that I draw your attention to the fact that all during such LEAN IN-CYLINDER IGNITION EVENTS, the Extra High KV will oscillate back and forth between the Secondary, slamming back into the Primary Side of the COP(s) and since "Electricity ALWAYS seeks the Easiest Path to GROUND" ... the Residual Electrical HIGH KV will seek to GROUND itself along the OUTSIDE of the Cylinder and follow the Interior Rubber Insulator Boot(s) and along the exterior of the Porcelain Insulator(s) of the Spark-Plug(s) and find their ultimate ways to GROUND OUT in the Outer Aluminum Engine Head.
Lean In-Cylinder Conditions eventually DESTROY COPs.
Whenever this Phenomena develops, Portions of the Rubber Insulator Boot(s) are -=BURNED=- by the HIGH KV Electrical Plasma Arcing and this creates CARBON TRACES (Tracks) inside and those are Channels that can leave Electrically Conductive Carbon Tracings along the exterior of the Spark Plug(s) as well that will make consecutive Mis-Fires easier and easier to achieve more consistently over time OUTSIDE THE CYLINDER. These Images illustrate what to LOOK for if you suspect these conditions are the prevailing cause of the Knock Sensor Issue:
https://www.tomorrowstechnician.com/ignition-and-coil-flashover/
https://easyautodiagnostics.com/chrysler/2000-2400/carbon-tracks-misfire?start=2
https://easyautodiagnostics.com/misc-index/two-wire-cop-coil-tests
PS:
Excessive In-Cylinder Carbon "MUNG" Deposits of the Piston Tops and around the Valve Seats can increase the *Compression Quench* sufficient enough to cause Pre-Ignition as well. Ergo, Carbon Busting Treatment could improve this condition with a Non-Mechanical Repair Intervention using Carbon Busting Liquid Solvent Treatments.
See THESE Threads for the "How To" Procedures and Empirical Success Stories:
View attachment 119604View attachment 119605
PS:
thanks for those links.
You hit the nail on the head here, "root cause... yet to be discovered"
I installed new spark plugs during this operation, so probably not a spark plug issue.
Could be the COPs, they have 50k plus miles on them. I don't remember when I replaced the coils last. I'll check out the testing on the COP too.
Top end cleaner will be another next step to see if cleaning up those cylinders will fix any potential knocks that may actually be occuring if the wiring tests good.
thanks.
Here's the schematic for the knock sensors. You'll want to check the wires for sensor #2.
Be sure to check resistance/continuity from the sensor wires to the PCM and also to ground on both wires at both ends.
Since you've tried swapping and replacing the sensors, and if all these wiring checks are good and the PCM connector pins are clean, I would be suspecting the PCM itself has gone bad. It might be supplying the correct 4V reference but the sensing circuit in the PCM might not be picking it up correctly. To be absolutely sure about this, you would need a means of scanning live data, look at sensor 1 and 2 data and tap on the block next to them to see if it picks up the knock and are comparable to each other.
Reactions: mrrsm and budwich
Actually, I think this code (and related sister code) means that the system will not being doing its job as the system disregards the output from the sensor and thus there is NO compensation done in the system for timing adjustments (and other running adjustments) to prevent "knock". Ultimately, perhaps "engine dangerous" if this persists depending on the severity.
Reactions: mrrsm and Mooseman
So I removed the C2 connector, the middle 73 pin female plug and it doesn't look corroded or bad at all. I will do the end to end checks from the bottom corner female pins 71 and 72 on the wiring harness connector plug to the knock sensor wiring harness connector end and also to ground and report back. (I'm going to check the KS 1 pins also just to compare to KS2 readings.)
Reply
Have you actually looked at your misfire counts?
There are likely other things associated with actual firing issues that would show up if you look at fuel trims.
I have no idea how to do this, I only have a cheap ODB2 code reader. I'm assuming I need some kind of more detailed live software on my laptop to read these misfire counts. I have FORSCAN for my Ford Truck, not sure that would do this for the Envoy.
Reactions: movietvet
An inexpensive ELM327 Bluetooth or Wi-Fi OBD2 adapter (Veepak, BAFX Products or OBDLink MX+) combined with an app for your phone like Torque Pro (for Android) or Car Scanner ELM OBD2 (for iPhone) will give you the ability to monitor misfires, knock sensor active counter. and knock sensor retard in realtime.
OK, update.
I tested the continuity between the female slots 71 & 72 on the ECM connector and the female slots on the knock sensor harness connector. Both had continuity and no resistance. I had audible beeping from the multimeter, and then when I tested the female slots on the ECM connector to multiple ground bolts on the side of the engine, they stayed OL with no resistance. So I think the wires between the ECM connector and the KS connector are good. They aren't shorted to ground or broken.
I also double checked the voltage with the multimeter. I had someone hold the probes on female pins 71 and 72 and I lightly tapped on the side of the block from underneath with an extension and it did read variable voltage at those pins when I was hitting the motor, so that's working also.
I am now considering doing the AC Delco top end cleaner and getting the live OBD2 reader to check the misfires, timing changes, and fuel trim readings.
But I can't seem to find the "ACDelco GM Original Equipment 10-3015 Engine Cylinder Cleaner" anywhere. Is this still sold in stores? maybe I need to go to a Chevy/GMC dealer to get it?
Unfortunately, it looks like the ACDelco TEC is no longer available. However, the next best "Chemical Analog" for doing this Top Engine Carbon Busting Job is:
Berryman Products 2611 Intake Valve and Combustion Chamber Cleaner, 16-Ounce Aerosol:
None of these Products are ever cheap...but when carefully, thoughtfully administered into all Six Cylinders and then "Turkey Basted" out after all that Carbon Build Up has been dissolved away to prevent Hydro-Locking the Engine... the results will be long lasting, The money you will make back from developing Better Compression and Better Gas Mileage may compensate your efforts very nicely. The same principles mentioned in the previous links will apply to the use of the Berryman's Stuff:
71QjpP3+7QL._AC_SL1500_.jpg71rJQ3FxN+L._AC_SL1500_.jpg71ZvgmT2IbL._AC_SL1080_.jpg614XWfpsltL._AC_.jpg
View attachment 119627View attachment 119628View attachment 119629View attachment 119630
Excellent, thank you.
Reply
Another update. I don't drive this vehicle daily, so the repairs are also slow.
Moving away from the knock sensor issue and trying to figure out a root cause, I got a Veepeak scanner tool with ELM327 as suggested and downloaded the Torque Pro app. I had some play store credits, so the app was "free" essentially.
I hooked it up and started looking and there is alot of info to digest off this thing. I went and looked down the list of sensors for fuel, and found fuel trim, but don't know what these readings indicate, could you help or point me in the right direction for the fuel trim data.
Screenshots attached from the app, sitting idle after warming up the vehicle and the Air conditioner blowing.
I noticed that the sensor for the fuel trim bank 2 isn't even registering, what does this mean? See attached...
I added a bunch of widgets to show fuel trim Bank 1 Long and short term.
It was at 3%-5% while it was warming up and then long term dropped to zero and short term fluctuated around 0-3
Not all data elements exist on a given vehicle. In the 4.2l engine case, there are only two o2 sensors, bank 1. Further, fuel trims are typically only concerned with the "front sensor" (ie. upstream). The downstream sensor is used to track "cat efficiency". You should be seeing a "fuel trim long term" and "fuel trim short term". The STFT will "waggle" while the LTFT will basically be "constant"... it will change depending on throttling but if you are watching a gage like display, it will be pretty static as the gage display does not update very fast.
IF you looking at the right data (PID's) for the values that you posted, they seem OK. There are PIDs in the data management screens for misfires on a per cylinder bases.... both current and history. You should look at those. In general, they should be "zero".
The app does take some time to get totally setup but is worthwhile to get a better idea of how the TB is running. There are options in the display setup for different "dials" which can be used to view "running data" just like gages that you would have on your instrument panel. There are also graphing screens that will provide a realtime graphing of the data. The O2 sensor can be monitored that way. The screens for displays can be set up as "pages". Thus, you can have gages on one page, you can then switch to another page that shows graphs of some elements and so on. Limiting the number of data elements is wise as having lots of elements will cause a slow down and potential miss of data. This is based on my limited experience.... others will be able to add more... :-)
Understood, thanks.
I was thinking fuel banks were setup the same as the knock sensor banks and I should have had a rear bank 2 reading because it shows waiting for data in the app.
I'll look for the PIDs for the misfires and report back.
I don't think that is correct. Yes, there are O2 sensor readings which are "voltage based"... but I think what you are seeing is some "app implementation issue"... I would have to check further. There is no bank 2 O2 sensors on a 4.2. The "strangeness" of the labelling is that fuel trims are done at the "engine level" and not directly from the O2 sensor. On a v8 / two sided engine there are fuel trims for each side but not for "front to back"... at least no that I have seen for these engines. Look closer at the PID's that are available as I think you have other choices. Further, in torque, there are "addon extensions", one of which a GM specific one that add additional PIDs for the GM "only".
ADDED: I see in the list there is a "label PID" for Short term fuel trim bank 1 O2 which is a voltage reading. If you look up in the list, you get the fuel trims (both long and short) for bank 1 that are percentages which are the "actual trims" that the pcm is instructing the fueling components to provide / reach for. In your first picture, you show the bank 1 short term trim but there is also one for the long term trim.
Yep, you are one step ahead of me.
I went into the app and added the custom PIDs, which are all listed under "[GM]xxx"
I am getting no misfires, at idle, according to this, but still able to feel a slight shaking.
I am going to go drive it around and log it while accelerating and see what changes.
Its also only showing a value for cyl 1 injector pulse width, not sure what that means either.
Another thing you will find is that torque is somewhat a "community app"... meaning that it is not "sanctioned" by the auto makers and thus not everything is guaranteed to be "spec'ed as engineered"... meaning not all information presented is exactly as the auto maker designed, GM in this case. The values that you may see are not "raw data" but are usually the result of some "formulation" which in lots of case, have been "reverse engineered" by some "net member" and added to files or presented for people to add to torque.
Based on the values that you show, it would appear that there are no misfires happening, which is good. But I am not sure what you mean by "slight shaking driving around"... rough roads! ... :-)
I saw in the PID list on my 2008 that there is a knock sensor pid that potentially show some "correction timing"... not sure if it is accurate (ie. has been sanitized by people) but mine shows 0 degrees. Does your vehicle have the pid and if so, is it showing anything?
Are you still having the code being set? IF so, have you looked at the freeze frame data, if any?
Check for a PID for spark knock or knock sensor data. As suggested in my post above, look at that data and knock on or near the sensors and see if the PCM is picking it up. Not sure if this would work with the engine running or not but would quickly confirm what is going on.
Was the wiring checked from the sensors to the PCM? (I think it was according to your post above) If everything checks out and swapping the sensors front to rear doesn't change anything, I would be ready to condemn the PCM. It is actually easy to swap out if you can get one cheap from a pick-n-pull yard from a same year and gearing (for proper speedometer readings). All you need to do then is a security relearn. You may need to do a CASE relearn as well if you get a correlation code but it won't prevent it from running.
Edit: In your wiring checks, did you check for a short to ground and each other on each wire?
Looking back at the photos... in particular, the second photo of the pins at the pcm connector. There appears to a be a few that seem to show some form of discoloration and even a bit bent.... maybe it just the photo.
Reactions: azswiss
Kdew02
