Went to town with some PlastiDip
Nothing to special. Did my first ever oil change :biggrin: I have to give big props to May03LT for his video, made things go very smoothly. I especially liked the tip to use brake cleaner on a rag to get a better grip when tightening the new filter.
Sorry no pictures of the actual oil change. I was to busy making sure I didn't screw things up, which worked fine until I was checking for leaks when finished, when I somehow managed to kick the pan with the used oil in it .... :hissyfit::lipsrsealed::crazy::no::eek: Cat litter has many uses :crazy:
Also I'd like to thanks to Steve A for hooking me up an account with Amsoil. I used the XL 5W-30 Synthetic Oil and an Amsoil 25,000 filter.
Here is the only pick I have.
Curiosity got the better of me so I traced out the mysterious wires in the dash. They route up the A pillar and into the headliner :confused: I see nothing anywhere that indicates anything aftermarket. My first thought was maybe they feed the sunroof, but fuse 20 in the rear fuse block is for the sunroof.
I may just leave it alone and forget about it. Well, I can't forget about it, I know it'll always nag me, but I really don't feel like pulling down my headliner just for this :crazy:
Pulling the headliner isn't too bad, can probably do it in an hour and a half lol. Planning on dropping mine (again) when I feel adventurous enough to wrap it in black suede
Short Bus said:
I'll wait 'til I see the finished pics, but I'm thinking....NO!!!!!
I disagree...but i like pushing the envelope.
Cant wait to see how it turns out!
I agree with Kyle. I think it'll look good.
Hurry up and finish so we can see!
Awesome!!!! Nothing beats doing it yourself and not having some ******* trying to sell you an air filter.:wootwoot:
WTF Did I somehow end up on FailVoy or did you censer your own post?
Bartonmd said:
Wait.. Sheetmetal??? You mean like 1/8" or 3/16" to make stuff out of, not body sheetmetal, right? Don't even try doing bodywork on thin sheetmetal with flux core!
Mike
Well thanks for making me do my research. Not a mistake I would've enjoyed making. MIG it is, huh?
We got a letter from xm today in the mail giving us a free 3 month trial. So apparently callng them about ordering it and not ordering it they will send you a free trial. Just and fyi for everyone. Then we took it to the daughters tee ball game and froze.
popped a tire. trying to get the spare down in the garage now... its seized up pretty bad. anyone know where the thread is about breaking it down?
Thanks for the support guys!
I like being completely different then everyone else. With black most people do a red or blue accent, and I wanted something that popped real well....So I chose orange. I love the orange interior pieces and can't wait to get the out side done.
Got my first coat on yesterday but ran out of paint that I use to tint the bedliner with so i'm at a stand still till I get more. Probably won't get this project finished for a week or two.(Slammed at my current job and have 3 interviews this week).
How hard is it to pop the plastic off the back bumper? I have that crappy faded gray look. Was debating about spraying it with bedliner......
Free Stealership changes are over, Time for the Purp.
Edit: Just finally ordered my LED reverse lights too!
The middle piece came out easy for me. I just stuck a flat head screwdriver between the pad and bumper and it just popped off. But the side pieces are a little tricky. They only have 2 clips like the middle piece near the inside edges and and a 10mm bolt you have to undo that is on the outside corn under the light from under side of the bumper. The rest of the parts are actually plastic welded on from the under side of the bumper so you basically have to break it off and then to reinstall the piece you have to melt plastic back on to hold it in place. (Going to be a pain in the ass to do).:banghead:
So if you are not too hands on or don't want to mess with plastic welding them back on I would find a way to mask it off.
Black and orange. You will have a Trailblazer Harley-Davidson Edition. :thumbsup:
I got that too, and xm is pretty darn good no commercials:biggrin:
Yesterday I plastidipped the bowtie and today I added some lights!
A MIG set up with the external gas will work hella better then the MIG Fluxcore. Lots of little tac welds is how i learned to do it best. and jump around alot. dont focus alot of heat in one spot, spread it out. Otherwise you will end up with it worse then when you started.
Yep... GAS MIG with solid wire, and a GOOD welder is THE way to do body sheetmetal. Cold tacks everywhere. You should be able to touch any part in the panel, including the tacks, 5 seconds after you do one. Just fill it up with cold tacks. There should not be a single "bead" of weld on the panel.
Also, I know you won't want to hear this, given that I'd guess you were looking at a $200 HF flux core welder, but good welders have better transformers in them, and weld MUCH better on light materials. A 220V welder will weld thin stuff better than a 110V welder, generally speaking, because the 110V welder is made as cheaply as possible and really only has good arc charactoristics at the high end of its range. If you just have to have 110V capability, get a Miller 211 , and use it with the 110V plug. Welders are REALLY a "buy once, cry once" thing. Good welders also ramp up the voltage and wire speed a LOT better than cheapo welders, so they tack weld a lot better.
I really like my 211, and the only reason I got a 252 is for duty cycle for the kind of production that I do.
Mike
Running a test to prove myself right (or my wife wrong). I insist she is heavy on the right pedal, she doesnt think so. Reset my DIC (I know, I know...but without doing a full fillup it is the easiest way to get numbers. Plus, I imagine she would think i was fudging the numbers if i did my own math) on the way to my sisters last night. She lives very close to where my wife and I work, and i take the same route to get there as wifey takes to work. Reset the DIC when i pulled into the driveway last night. Today my wife is driving the TB and (unknowingly) is having her driving habits monitored. I will either update the group with the findings, or bow my head in shame and never speak of this again. Time will tell.
replaced rear sway bar bushings (was part of the 1st djm group buy, the ones supplied were no good and ended up splitting, norcalss sent the new updated ones a few months ago)
changed power steering fluid
cleaned the air filter ( I got a aem dryflow filter on my cai)
took off the front sway bar bushing to measure, stamped 44mm on it = 1.73" (guess I will be ordering the 1.72 bushings off rockauto)
Looking at valve stem and weight in both pictures, looks like different wheels...did RF and RR today.
Can you tell I am a little bit type a?
Removed the rusted out, falling apart cheap ass flowmaster exhaust the previous owner had put on. Installed a full stainless steel GM performance parts aka Borla cat back. Looks and sounds awesome! Scored it on ebay brand new shipped for $260!!
Can you give us some more details? What kind of clear? My wheels are similar
Heavy work with this guy and the dewalt cordless, maybe $8 at hardware store:
Then lots of elbow grease with 200 grit sand paper. A dremel would probably save a lot of time.
Went over it with 400 grit next.
Then a couple of rounds wax on wax off with this guy:
A round of simple green, then a round of dish soap/water to eliminate any grease/oils left behind.
Finished with 2 coats of:
Took about an hour per wheel...maybe a little more since the puppy kept coming over to "help."
Got the Cargo LED's in and look great...now just waiting for the other ones to come in (some sellers ship slow :no:)
I have LEDs and trust me you will like them a whole lot. :biggrin::thumbsup:
Oh I have leds all over my truck already haha I just upgraded my inside ones because those were my first mods I did a couple of years ago and bought cheap ones at the time and they started to bug me from the bad quality. I love the smds :yes:
Drove it to the post office to pick up the new Mopar rear brake rotors for my Sunfire.... Yeah, you read that right...
Disconnected the rain sense on the wipers.
I didn't like that the wiper would operate when it wanted to.
I like to set the delay and have the wiper sweep when I want it to.
You've got tons of room in there to splice two panels together and put them both in the cargo area
3 of those would be easy. I would (and did) use 2 larger panels.
Yeah I do have a lot of room but I do not have the time to bother with projects like that or do I bother myself with splicing lol This is 2x brighter then what I had in there before and I am happy with it :yes: I do not want tooo bright either lol I have 6smd bulbs coming in the mail for the other lights and that will be way better also!!
I am having a lot of trouble removing the glove box light...it seems like I either break it or I cant get it out
Well things have been slow this week so I've been fixing some odds and ends. First thing was gluing the back door w/s in place. I used some clamps to keep them in place while the w/s adhesive set up.
Next was fixing this asshole b pillar panel. Bass, wind, heck even closing the door would sometimes cause the upper hold down clips to detach from the body or detach from the panel. So I q-bond'd the clips to the panel and tweaked them for a better "bite" into the body. Worked awesome! To test it, I drove in the wind with the bass up while opening and closing the door.
That was probably pretty funny to watch
JLEAHY1952
