What came in your mail today?
10,687
Bunch of goodies today, thank you Amazon Prime. Got some studless wall mounting brackets, and some reversible recessed cable pass through plates. These will allow me to run my cables behind the wall, for when I eventually wall/ceiling mount the TVs in the living room and bedroom. I'm also going to relocate the HTPC from the living room, to the home office.
Got a 10' IR extender, which I'll run from the home office to the living room, and hook up the main cable box to the office one, so I won't need another cable box.
For my work office, gonna do a lil decorating, so got a Chicago Bulls basketball and a Bears mini helmet for my empty book case.
Garage door remotes for my dad
10,687
A pair of 18" x 24" poster frames for the office. 100' roll of fiberglass screen, staple gun, and staple assortment so I can fix the soffitt situation under my roof.
They still hand those out? I haven't seen a phone book handed out in about 10 years.
10,687
A couple of Chicago themed posters for the work office, courtesy of a buddy of mine I went to college with. They'll go in the frames I got last week.
One of the girls at work got me hooked on these mango-ginger candies from the Vitamin Shoppe. Can't get them in the stores, so had some shipped.
Reactions: Reprise
14,950
Parts to rebuild the front end. Now to get the money to have it all installed, waiting for a check..
4,024
A "new" (read second hand but perfect working condition) digital AC control unit with the right model number for an 02.
By the weekend I'll have one for an 03 & 04, remanned, for about $70 for sale.
10,687
Got a new replacement case for my old Note II. The clips on the gray plastic case of the old one were half broken, and the rubber shell was starting to peel apart from being the sole thing holding everything together. Much mo betta now
Daniel644
582
my new kitchen light fixture, one of the wires shorted out when I screwed in the bulb and fried that bulb and the dimmer function of the dimmer switch I just put in a few days ago. :Banghead:
4,024
Shocks for my wife's Rav4. Munroe Spectrum...rears are easy enough but the fronts I may have to either take to the local Munroe to swap the springs for me or take a trip to @Sparky and gain the use of his wall mounted spring compressor...might get him to put new lights in my AC unit while I'm there. :undecided:
Stainless bolts for my wheels to replace the rusting steel bolts along the perimeter. Originals are flange bolts, but getting stainless flange bolts the right length was impossible, and no way was I going to manually cut down 64 bolts. Regular bolts + washers will work, and might not even need the washers.
Brakes for dad's silverado.
Got stuff this week. Monday received stepper motors and bulbs for my son's Silvy. Tuesday received a new lens for his gauge cluster and a battery tester I got from Amazon on a flash sale.
Reactions: northcreek
10,687
Amazon delivery day. Got a few dirt cheap long sleeve tees for yard working. Getting tired of all the bug bites, scrapes and scratches on my arms :mad:
Got a tire inflator and air line, can you guess what piece of equipment is creeping closer to the top of my purchase list? :biggrin:
Also got a cheap support wrap/brace for my neck, since I did something to it the while working in the shed the other day, that has me pretty sore and effects my sleep. It has magnets which are supposed to cause a heating sensation, which I was skeptical of, just needed something cheap and temporary... Until I wore it for 10 minutes, then :eek:
:explode: Had to take that back off! :confused:
Reactions: RTTBLT1
charging stand for apple watch
Reactions: djthumper
4,024
New Detroit Axle hubs...one of mine is starting to growl, so I might as well get it early. Also got the end links for Chanin's Rav, so now I can change the broken rear spring.
RTTBLT1
512
Louisburg, KS
Put our Amazon Prime membership to use...
Received the Dash Cam and the 32gb (x2) Micro SD Cards today.
May end up ordering another for the rear of the TB. Have already seen the video quality these little cams have via a family member and will be nice to have with all the madness on the roads now day's.
Stay safe out there everyone!
xavierny25
6,333
Staten Island, N.Y
SAI or is it SIA cant remember how i looked it up, anyway block off plate. I had jeremy tune the codes out so I'm pulling the system out my truck at some point.20170831_191537.jpg
SAIS. Secondary Air Injection System. I kept the block off plate from my 02.
Joe102938
