Seriously considering ordering a full leather seat set/brackets/etc for my Camaro, but that's $1150. Now with a code I can get 5% off, and on Nov 2nd they'll do a random drawing for one person using that code to get a full refund.
Do I go for it? Or do I hold off on doing anything with the seats in the car until later?
Hmmmmm
:goodpost:
Hmmmmm
I say go for it. At least now you get 5% off and a chance to get them for free.
Unless you can get a better deal waiting until Black Friday which is around the corner.
Gonna do that soon as well. Not enough time to wash the TB again so I figure the drive thru should work well since everything is fresh.
Pretty much got same results as me using my usual manual car wash joint. Only thing is the water pressure of this,touchless wash actually removed some paint off the rear bumper trim pieces I've painted. Door handles too......
I had to same issue with my home pressure washer. Had to buy a pressure regulator to tone down the pressure from 2800psi to as low as 1000psi. Most car washes are around 1500psi.
If there was a water hookup around here I would of gotten a pressure washer a while ago
So.....I looked at this today....
Reactions: Porkins and Mounce
Reactions: Porkins
Put some aftermarket wheels on, lower it, cree's or HIDs, tint windows
More likely Hids since I believe they use a 9004/9007 style bulb which there are no crees for
I was hoping you'd say that. What temp?
Have you looked on Ebay? Many different versions. They might not be true cree LEDs though but you never know. They're in the $100 range.
Woo
Most likely around 6000k
Hmmm
Am I the only guy on GMTN without 6k's?
I'd go with HIDs myself. Just a good brand such as morimoto if you can afford it.
One evening I plan on spending a lot of time researching Hids again and talking to my supplier to see if our new ballasts are available yet
Correct. I have 9004 HIDs in the F150. Interesting how they work to create the hi beam.
4300K is where its at. If you want more lighting, they produce the most lumens. 5000K is even too high for me.
TRS is releasing their new Morimoto XB35 ballasts November 1st. Their XB35 HIDs are comparable to the Osram CBI. CBIs usually run $190 a pair. XB35s are around $50 a pair.
Nope, David and the other projector guys run 4300-4500k :yes:
That'll be the next color I get for the stang, started with 8k, now I have "5k's" from the same company that look like 8k...gap in quality control much? Only difference between the two is that they've updated their products. That's what I get for buying cheapies. I've recommended that company a few times because I was impressed with the first set, still am, but their new stuff appears to be garbage, at least their bulbs anyways.
Yea my old K3500 has H4 bi xenons...they basically use a little shutter to redirect the light pattern to the different areas of the reflectors.
Hmmm will need to scope that out..
Darkrider_LS said:
Good idea
He might he able to keep it simple snd he's reputable. Good luck, don't forget :pictures:
I may end up talking to him about a retrofit on the blazer perhaps either way
9004/9007 variety runs a solenoid setup, no shutter deal. Don't know what order the pics will be in but, one is with it extended (low beam) and one is with it pulled in (high beam)
matthewhall
