scorpio1 said:Sounds very Diesel, hahaha, love it. I'd say do it, but not practical at all like that though.
Remember after you re-tune you can gain a good bit of a smoother idle and better running by simply running a colder/ smaller gapped plug. Most people find 2 stages colder is better when going from N/A to boosted, but it all depends on tune and what engine, so play around with the Gap on them to fine tune after the ecu is dialed in.
Yet another similarity in these 2 engines, that makes my theory that the I6 LL8 is essentially a 6 cyl. version of the 4 cyl. Ecotec L61 even more credible.
I picked a good vehicle to upgrade to when my cavy got totaled, and didn't even know it.:wootwoot:ConeKilrAutoX said:thanks a ton for this info that is really going to be helping me out and I appreciate it! looks like Ill be purchasing these today haha. Thats crazy with the LL8 / ecotec resemblance... really does seem like the i6 is just 2 cylinders extended of the 4 cylinder.
With 93 octane those plugs should be excellent.
limequat said:As scorpio was saying you definitely want to wait until the idle is nailed down before swapping them in.
Here's a pic of Autoroc's plugs after 55k miles. This is a 414 RWHP 4.2. Not too shabby, and no misfiring problems.
vortec4200.com • View topic - Vortec 4200 Turbo engine swap into an IROC Z
ConeKilrAutoX said:haha DEFINITELY after the idle is nailed downJust wanted to order them while I still had enough money
ConeKilrAutoX said:well I havent ordered them yet. Whats the consensus then you guys think? ngk or ac delco ? pre gapped? adjust the gap at all?
Just curious I wont be buying them until I get the idle taken care of. max boost 7ish psi min boost 3 psi
ConeKilrAutoX said:I did put all new plugs in and new 93 octane as well which can only help out the situation. but todays my birthday and im in pitt at a rock concert so no car work today haha
JK! HOPE ITS GREAT!
Ryda55555 said:I was expecting a great photo of your turbo build when i saw that you posted something in here but was greatly dissapointed..... So i guess i'll just have to say happy birthday.....JK! HOPE ITS GREAT!
ConeKilrAutoX said:Just curious I wont be buying them until I get the idle taken care of. max boost 7ish psi min boost 3 psi
gmcman said:Just an observation since you posted this, I assume your tune is set for atmospheric pressure at minimum and 3 PSI is what you will be expecting at part throttle correct? Not that you would have 3 PSI at the bottom of the MAP values correct? I haven't tuned an EFI motor so I'm talking out of my arse but just wanted to ask since you were having idle issues.
gmcman said:What was the idle speed at in the video? Will the engine run smooth if you try to hold it at about 1500-2000?
ConeKilrAutoX said:I swiped my fingers across the inside of the throttle body plate (engine side) and it was dripping wet with gas. I keep having to clean the throttle body every start up and unplug the battery and that whole procedure.
Any suggestions for what to try next?
ConeKilrAutoX said:the fuel pressure regulator is what I am concerned about. I have it hooked up to the vacuum port on the intake manifold directly via the vacuum distribution block I had bought. no leaks but is that hooked up correctly?
gmcman said:I believe it needs to be ported vacuum, meaning on the front side of the throttle plate. Behind the plate is manifold vacuum and is constant. This could be the issue.
bruhaba said:FPR should have manifold vacuum the way you have it as far as i know. The point of it is to keep constant rail pressure relative to manifold pressure( differential pressure across the injector stays the same). So at idle it should show about 30 ish. At wot or with the vacuum line disconnected it should show about 43 if that is what you have it set at.
