Used it to drag the trailer back n drop it off in the woods
Capote
24,227
Atlanta, GA
Drove the hell out of it today, raced a tundra that was fun :smile:
oooo do tell, pm me :biggrin:
Capote
24,227
Atlanta, GA
Whored it
Darkrider_LS
9,332
Drove one and looked at the one sitting in the driveway
jimmyjam
DJones said:
I'm liking his Flex-a-lite controller. I might have to swap out my DCControls, which has light-duty electrical terminations for the temperature probe.
jrSS said:
Yes....in a couple weeks I will have the part we need to splice into the upper radiator hose to make it variable speed.
why are you using that thing? ecm does it for you...
x2 :confused:
Capote
24,227
Atlanta, GA
[sharedmedia=gallery:albums:107]
pastorjwat
16
Today, I replaced the starter motor. Wow, what a pain that was! Took me ~ 2 hours or so, but I was pretty proud of myself! The whole working on your car through the wheel well is not all its cracked up to be!
14,956
Cleaned the MAF and throttle body. Faound a potential vacuum leak.
xavierny25
6,374
Staten Island, N.Y
Finally got a moment to remove the piller crap or wrap what ever u wanna call it. Yay.... it looks good... to bad I didn't do this before I put the wind deflectors in. Smh.. now I need some 3m double sided tape.
AManders6
638
Drove it today. While phoneless at work and running a longer than normal program on my machine, started to come up with a both of ideas for parts/upgrades in going to be making and doing
Capote
24,227
Atlanta, GA
Which vinyl did you remove?
Back glass and back sides.
Me either since I am work its too far away to work on
Darkrider_LS
9,332
Checked oil level and added STP oil treatment to the Blazer
Capote
24,227
Atlanta, GA
:pictures:
I think you are the only active :whore: that I have never seen a pic of your TB.
:popcorn:
:undecided:
Hatchet
2,405
Snapping bolts on mine . Waiting on my savior.
Capote
24,227
Atlanta, GA
Reactions: shrek77
sawicksted
366
Took the rear wiper motor apart and freed the two bearings.....
The arm was "slowing" down so in order to save some $....took it apart....about 2 hours to disassemble clean and put back together. Priced a new motor on internet between $195 - $300 plus labor ....would have been $500 easy at the dealer.
Works better then it ever has. Can't believe the difference....
I was thinking of doing a "How To" if you guys think it would be worth while.
Aarkon
5,607
If it will save people anywhere near that much its worth a write up
10,798
Popped out my back up camera, to try and troubleshoot why I'm not getting a picture anymore. Hooked up the video line to my TV, and put power and ground to it, no joy. It doesn't appear to be damaged at all, no moisture inside the lens as I saw on some reviews for other cameras. I'll do a quick check of the power cable, and I think I have an old 8mm camcorder in my junk bin I can plug into the line to the HU to make sure that's good too. Looks like I might be in the market for a new :pictures:
Reactions: Mounce and Capote
skwatr
