Capote
24,227
Atlanta, GA
Damn man, I hope a tie rod isn't completely messed up
Hatchet
2,405
Looks like the lower control arm slid out. Either that or you destroyed your bushings and or ball joints. Were you able to drive it home?
And what have we learned?
Capote
24,227
Atlanta, GA
Took a closer look after I got home, wasn't as bad as I thought when it came to the camber. I think it's only a smidge off. Everything looks to be in place when I took the pictures from below. uploadfromtaptalk1409745315467.jpg
Can use some home alignment tricks n check it out. Tape measure n boards n such.
Hatchet
2,405
Comparing your first pic to the second one. It looks like what ever moved, moved back. The first pic looks like it is way out there.
mcsteven
6,584
Filled it with gas and checked oil, transmission, power steering fluids. Want to make sure it is at least getting the same but hopefully better gas mileage.
dmanns67
32,979
When did you pick up the Voy? Hows the "new" engine?
mcsteven
6,584
Yesterday. So far so good. Smooth, etc but want to wait a few miles before full throttle.
mcsteven
6,584
Sweet. I'd like to get one installed in mine. The fake one is crap.
STLtrailbSS
Aeroforce are a great investment! Had mine for about a year couldn't live without it
Also still waiting on my plate everything is out except the converter bolts it is basically jumping out at me. Come on mail!!!!!
mcsteven
6,584
Mounce
13,667
Tuscaloosa, AL
From what I've read, you can get every possible sensor readout via OBD2 port but that's with a scanner. I'm assuming this gadget has some fancy software that can tap into those sensors and read the levels just like a scanner.
Reactions: mcsteven
jrSS
U can read shit tons of info on these. I love it!!! 0-60mph...air fuel ratio.....oil pressure.....coolant temp....anything the torque app does and a lot more. My obd2 adapter fried on me and won't connect with my phone anymore. So I got annoyed and bought the af gauge.
jrSS
Clean carpets. Took seats out.
??? Lubed?
mcsteven
6,584
I've seen some images where folks have painted the cover over the intake manifold. Was thinking about doing that on my 4.2 in the GM red hue.
Suggestion on paint or type of paint?
dmanns67
32,979
I believe BlckShdw painted his silver along with a few other items under the hood. Put on a couple coats of adhesion promoter (for plastic), primer, paint, and then clear coat. Oe you could skip the primer and go from adhesion promoter, paint, then clear coat.
Reactions: mcsteven
Drunkplunk
