Vehicle Usefulness hauling/towing/grocery getting ect.
Rate and list the big stuff you’ve thought naw too big but did any way.
So far I’ve towed a 2900LB boat + 600LB trailer. One way tripe are 220miles
Hauled 16’ 4x4
5 five gallon buckets of crused rock for my back yard drive/park.
Now I have a boat in the trunk. I’ve always wanted a boat in the bag this is a lot more.kindof like a big wide surfboard surrounded w/ air chambers very heavey duty rubber.
I intend to fab a cross brace on the lugguage rack w/ a roller in the middle then transport the 8’ inflatable rib on the roof Aussie style .yes it’s a bit heavey at 68LBs but I am used to Putting a 200LB 28’ fiberglass extension ladders on roofs of work vans.
w/ the ladders it was like straight press up then down into rack.
Loading the vessel will be roll into position lean hull onto the roller lift rear of hull basically tilt and press her on.
First off I need to patch a ½ hole in the front chamber. The 2 rear chambers are fine, Then a few coats of latex paint to help protect the rubber.
What do you Guy’s think
Hauled 16’ 4x4
