Yea i have those hood wires on the envoy but there isnt one on this one..maybe cause its an LS..doesnt have a lot if things the envoy has.. No drivers information center under the speedometer for example
..anybody got a good vin search site they like?
I think any of them would work.@coolasice Thanx..found this one too..told the guy at the dealership that it was G105 and that helped the guy at gm that he called figure it out..can i connect it to any of those ground locations in your pic
G105 is at the firewall near the fuse block...@JayArr definitely helps..thanx..gonna just look for the hanging eylet at any of those points..would you happen to have a view from behind ..with the flywheel facing the camera? Dealership guy said "back of the head" im looking for G105
G105 doesn't go to the head... It goes to the t-case shift module...@coolasice yeah i know..thats the same pic i meant to add in post #91.. I guess i forgot to attach the file..i just need to find where the other end of G105 goes..inspection camera ruled out those 4 on the side of block..theyre all intact..took of the air box to get better acces to back but not much luck..to hell with it..intake mani coming off..iirc i think the hardest part for me was getting off the bracket that holds the pcm on due to clearance issues..but i got the proper tools now so shouldn't be too bad
@coolasice got an engine block wire diagram?
Not at all.. ground is ground. Won't hurt it a bit.@coolasice thanx man..i was just looking thru the wiring diagrams from the service manual that i downloaded from @Mooseman ..im on page 31 out of 101 looking for it..i gotta take a break and take care of some biz..but hopefully i can find it when u get back.on another note i think that pita pcm bracket bolts into the side of the head so maybe i just go buy an eyelet insulate up that wire and put it there..im gonna connect the pcm,batt and connections..touch the wire there and see if itll start..if that does work do u think that will interfere with the pcm one i screw it back on the bracket?
The GM service manual says there shouldn't be anything there at all. I suspect my red wire is just for an aftermarket accessory, there is only one wire on the post and the post doesn't connect to anything else.
That is incorrect. That is the infamous "disconnected red wire" for 12v at the trailer connector.
Thanks @Mooseman. BTW - what is this OS that is spoken ill of? Some "old site" you were all on before this one?
