Microsoft Bing uses OpenAI - Chat-GPT to Finally 'Challenge' The Google Search Engine
In the Brothers Grimm Fairy Tale called "Hansel and Gretel" we find two kids abandoned in a Dark Woods who encounter a "Ginger Bread House" constructed of Sweets and specifically engineered to entice children inside so they can be fattened up for slaughter by a Hungry, Wicked Witch,
The Parallel Segment today involves the completely astonishing announcement by nVidia that they are giving away the "Sweets" out into The Wild as Open Source Products designed for the Creation and Deployment of their "NEMOTRON 3 Agentic Products" that will essentially allow anyone within the reach of their own imaginations to Create AI Agents either of a modest design and size ...or on an Industrial Scale that will soon be able to perform ANY Task that ANY Human Being can do... essentially as jobs that would ordinarily require "Work For Hire" Folks to get most things DONE:
*Immortal Helpers*:
Take Note that a Truly Qualified AI Expert Tested NEMOTRON 3 NANO 30/3 Billion Token Locally Installed Version and check out the sophisticated TESTS he puts this *THINKING* nVidia Model through and then... Compare your OWN Reasoning Skills with some of the Results his TESTS produced:
The Two Things you can hear and see in the background are:
(1) The Sound of the Ultra-Rich and Our Corporate Masters' Drool Drops hitting the floor when provoked by UNBRIDLED GREED.
(2) The Increase in the Printing Rates of *Pink Slips* for Human Workers.
This is a very dense topic that requires Three Segments to cover. I recently updated my available Nomic's *GPT4ALL* Library of LLMs (Large Language Models) that included one in particular called "DeepSeek-R1-Distill-Qwen-14B". This "LLM" features the ability to observe its actual "Thinking" as "Chain of Reasoning" as though its *Thoughts* are poured out onto a Digital-Mental Scratch Pad and this allows for the User to "Read *IT*s Mind" and determine how it manages to arrive at *IT*'s Own Conclusions.
For the sake of keeping this Test in the realm of "On Topic" Automotive Aspects that this site focuses on, I decided to pose a problem near and dear to us all along the lines of "How to Write a Python 3 Program capable of performing Bi-Directional Control over GM Modules" and "IT"s conclusions and most especially... "IT"s -=CAUTIONS=- ...are very edifying: Note that whenever the AI is *Talking to Itself*...These Thought Texts are --=Italicized=-- :
Prompt:
Can you write a program in Python 3 that can access General Motors PCM units and other on-board automotive modules in order to be able to activate them in a bi-directional manner using PWM (Pulse Width Modulation) on the GM Class 2 Single Wire Network using 0-7 Volts DC for communication?
Response:
"Okay, so I'm trying to figure out how to write a Python program that can communicate with GM PCM units and other automotive modules using the Class 2 Single Wire Network. The user mentioned using PWM on this network with 0-7 volts DC for communication."
"First, I know that GM's Class 2 network is a single-wire protocol used in vehicles for various control systems like power windows, lights, and seat adjustments. It uses pulse width modulation to send signals between modules. Each module addresses another by varying the duty cycle of a square wave signal."
"I remember from my research that communication on this bus typically involves sending frames with an address byte followed by data bytes. The addressing is done using a 6-bit or 7-bit identifier, depending on whether it's unidirectional or bidirectional. For bi-directional communication, the protocol might be different, but I'm not entirely sure."
"The user wants to activate modules in both directions, so maybe we need to handle sending commands and also receiving responses if applicable. But since it's a single wire network, data is sent via varying the duty cycle of a square wave on that line."
"I think about how to generate PWM signals in Python. On Linux systems with GPIO access (like Raspberry Pi), you can use the RPi.GPIO library or even pigpio for more advanced features. The idea would be to set up a pin as an output, then vary its duty cycle based on the data being sent."
"But wait, the Class 2 network is designed so that each module addresses another by changing the state of the line from high to low and vice versa. So maybe it's not just about sending arbitrary PWM signals but following specific protocols for addressing and data transmission."
"I recall that in some implementations, a square wave with varying duty cycles represents different modules or commands. For example, a 50% duty cycle might address one module, while another percentage addresses another. But I'm not entirely sure how the exact protocol works because it's proprietary to GM."
"Assuming we can send frames by changing the duty cycle for each byte of data, perhaps starting with an initialization where you set up the pin as a high-speed output and then toggle between 0% and 100% duty cycles based on the binary representation of the address or command. Each bit might correspond to a specific time period, but I'm not certain."
"I also think about how to handle bi-directional communication. If we're sending commands from the host computer (like a Raspberry Pi) to the modules, that's one direction. But for receiving data back, maybe another pin is used or some form of listening mode where the line is monitored for incoming signals. However, since it's single wire, I'm not sure how bi-directional works without additional hardware."
"Looking at the example code provided earlier, it uses RPi.GPIO to set up a PWM signal on a specific GPIO pin. The `send_frame` function takes an address and data array, converts each byte into bits, then sends them by adjusting the duty cycle for each bit's duration. But I'm not sure if this accurately represents how GM Class 2 works because it might oversimplify or miss key protocol details."
"I also wonder about error handling and ensuring that the timing is precise enough to meet the specifications of the network. PWM in Python can sometimes have delays, especially with software-based solutions like RPi.GPIO's pwm_start function. Maybe using a hardware-based solution would be better for real-time control."
"Another consideration is safety. Manipulating automotive systems without proper knowledge could lead to dangerous situations. It's important to ensure that any code written doesn't interfere with the vehicle's operation and complies with legal standards."
"In summary, I think the approach involves setting up GPIO pins as high-speed outputs, generating PWM signals where each byte of data is represented by a specific duty cycle for a certain period. The exact implementation would require precise timing to match GM's protocol specifications, which might be challenging without detailed documentation or support from GM themselves."
End of Part 1 of 3 Parts...
Part 2 of 3 Parts...
To address your goal of creating a Python program that communicates with General Motor PCM units and other automotive modules using the Class 2 Single Wire Network via PWM, here is an organized approach:
### Approach Overview:
1. **Understanding the Protocol**: The GM Class 2 network uses pulse width modulation (PWM) to send signals between modules. Each module addresses another by varying the duty cycle of a square wave signal.
2. **Hardware Setup**: Use a Raspberry Pi with RPi.GPIO or pigpio for generating PWM signals on GPIO pins. Ensure you have physical access to the appropriate Single Wire Network pin in your vehicle.
3. **Protocol Implementation**:
- **Addressing**: Implement addressing using 6-bit (unidirectional) or 7-bit (bidirectional) identifiers.
- **Frame Structure**: Construct frames with an address byte followed by data bytes, converting each byte into a series of bits for transmission via PWM duty cycles.
4. **PWM Signal Generation**:
- Use RPi.GPIO to set up the pin as an output and generate square waves where the duty cycle corresponds to specific addresses or commands.
- Each bit in the frame may correspond to a specific time period, adjusting the duty cycle accordingly.
5. **Bi-Directional Communication**: For receiving data back, monitor the same line for incoming signals using another GPIO pin configured as an input with appropriate pull-up/pull-down resistors.
6. **Safety and Compliance**: Ensure that your code does not interfere with vehicle operations and adheres to legal standards.
### Example Code:
Here's a Python script using RPi.GPIO to send frames via PWM:
```python
import time
import RPi.GPIO as GPIO
# InitializeGPIO
PIN = 12 # Adjust according to your setup
GPIO.setmode(GPIO.BOARD)
GPIO.setup(PIN, GPIO.OUT)
def set_duty_cycle(cycle):
"""Set the duty cycle of the PIN."""
pwm.ChangeDutyCycle(cycle)
def send_frame(address, data):
Send a frame consisting of an address and data bytes.
Each byte is sent as bits with corresponding duty cycles.
# Convert each byte to binary
for byte in [address] + data:
for bit in range(8): # For each bit in the byte
if (byte >> (7 - bit)) & 1: # Check if bit is set
set_duty_cycle(50) # High state
else:
set_duty_cycle(0) # Low state
time.sleep(0.001) # Bit duration
# Reset the line after frame transmission
set_duty_cycle(7)
time.sleep(0.02)
# Initialize PWM at 50Hz frequency (adjust as needed)
pwm = GPIO.PWM(PIN, 50)
pwm.start(0)
try:
while True:
# Example usage: Send address 1 with data [0x01]
send_frame(address=1, data=[0x01])
except KeyboardInterrupt:
pass
# Cleanup
GPIO.cleanup()
### Notes:
- **Initialization**: Ensure the pin is correctly set up and that you have physical access to the GM Class 2 network.
- **Timing Precision**: The example uses a simple timing approach. For precise communication, consider using hardware-based solutions or more sophisticated timing mechanisms.
- **Safety First**: Always exercise caution when working with automotive systems.
This script provides a basic framework for sending frames via PWM on the GM Class 2 network. Further refinement would require detailed knowledge of GM's specific protocol nuances and testing in a controlled environment to ensure reliability and safety.
End of Part 2 of 3 Parts...
Part 3 of 3 Parts...
Prompt:
Of course, interacting with the PCM would require the use of the DLC (Data Link Connector) and for the GM protocol, the Data Streams would have to be sent and received as PWM on Pin #2 with Power provided on Pin #16 and Pins #4 and #5 used for Grounds. The GM PCM and BCM are sensitive for having Stable DC Power so an external Power Source would have to provide, steady voltage at or above 12.5 Volts DC. Ergo, these would have to be factored into the Python 3 Program.
Response:
"Alright, so the user is asking about writing a Python program to interact with GM PCM units using PWM on their Class 2 Single Wire Network. They mentioned needing an external power source and specific pins for communication."
"First, I need to understand what exactly they're trying to achieve. It seems like they want bi-directional communication, meaning both sending commands and receiving data from the vehicle's modules. That makes sense because you'd probably want feedback or status information."
"They specified using PWM on Pin #2 with power on Pin #16 and grounds on Pins 4 and 5. Also, an external steady voltage of at least 12.5V is necessary. So, I should consider how to handle the physical connections in Python code."
"I know that for such tasks, you'd typically use a CAN bus or specific protocols like KWP70 (which GM uses). But since they're talking about PWM on Pin #2, maybe it's not using standard CAN but another method. However, without more details, I'll assume they want to send and receive signals via the DLC."
"I should outline the steps: setting up hardware connections, handling power supply, initializing communication protocols in Python, sending commands with appropriate timing for PWM, and reading responses back. Including error checking is important too because vehicle systems can be sensitive."
"They might not have mentioned it, but safety is a big concern here. Incorrect signals could damage the car's electronics or pose hazards. So I should remind them to ensure all connections are secure and test in a safe environment before full implementation."
"I'll structure the response by first addressing hardware setup, then communication protocols, sending commands with code examples for both Tx and Rx, error handling, and safety considerations. Providing sample code will help them get started but also caution against misuse. To interact with GM PCM units using PWM on a Class 2 Single Wire Network in Python, you would need to handle the hardware connections and communication protocols carefully."
Below is an example of how such a program might be structured. However, please note that working directly with automotive systems can be complex and potentially dangerous if not handled properly.
### Key Considerations:
1. **Hardware Setup**:
- Use the DLC (Data Link Connector) to access the GM Class 2 network.
- Pin #2 is used for communication via PWM.
- Power must be provided on Pin #16, with grounds on Pins #4 and #5.
2. **Power Supply**:
- Ensure a stable external power source of at least 12.5 VDC to avoid voltage fluctuations that could damage the system or interfere with communication.
3. **Communication Protocol**:
- GM vehicles typically use the KWP70 protocol for communication.
- You may need to send specific data streams (DIDs) and receive responses using PWM-based signaling on Pin #2.
4. **Safety**:
- Always ensure proper grounding and secure connections when working with automotive systems.
- Be cautious of voltage levels, as incorrect signals can damage the PCM or other modules.
### Example Python Program Structure:
Below is a basic example of how you might structure such a program in Python 3. This assumes that you have already set up the hardware connections and are using appropriate libraries for PWM control and communication handling.
```python
import time
# Import necessary libraries (e.g., RPi.GPIO for GPIO control)
# Set up GPIO pins
PIN_PWML = 2 # Pin for PWM signal on GM Class 2 network
PIN_POWER = 16 # Power pin
PIN_GROUND_4 = 4 # Ground pin (use one of them, e.g., PIN_GROUND_4)
PIN_GROUND_5 = 5 # Another ground pin
# Set up power supply
GPIO.setmode(GPIO.BCM)
def setup_hardware():
# Initialize GPIO pins
GPIO.setup(PIN_PWML, GPIO.OUT)
GPIO.setup(PIN_POWER, GPIO.OUT)
GPIO.setup(PIN_GROUND_4, GPIO.GND)
GPIO.setup(PIN_GROUND_5, GPIO.GND)
# Turn on power supply (assuming PIN_POWER is connected to a 12.5V source)
GPIO.output(PIN_POWER, True)
def send_pwm_command(pulse_width):
Send a PWM signal with the specified pulse width in milliseconds.
Adjustments may be needed based on the specific protocol requirements.
try:
# Set up PWM
pwm = GPIO.PWM(PIN_PWML, 100) # Frequency of 100 Hz (adjust as needed)
# Start PWM with a duty cycle corresponding to the pulse width
duty_cycle = (pulse_width / 1000) * 100
pwm.start(duty_cycle)
print(f"Sent command with pulse width: {pulse_width}ms")
time.sleep(2) # Allow sufficient time for response
except Exception as e:
print("Error sending PWM signal:", str(e))
def receive_response():
Receive and interpret responses from the GM PCM.
This is a simplified example; actual implementation may vary based on protocol specifics.
try:
# Read input (e.g., using GPIO to detect changes)
response = None
if GPIO.input(PIN_PWML):
print("Received signal")
response = "ACK"
else:
response = "NACK"
return response
print("Error receiving response:", str(e))
return None
def main():
setup_hardware()
try:
while True:
# Send a command
send_pwm_command(500) # Example: 500ms pulse width
# Receive and process the response
response = receive_response()
if response is not None:
print("Response received:", response)
time.sleep(1)
print("\nProgram terminated by user.")
finally:
GPIO.cleanup()
if __name__ == "__main__":
main()
### Notes on the Program:
- **Setup**: The `setup_hardware` function initializes the necessary pins for communication and power supply.
- **PWM Signal**: The `send_pwm_command` function sends a PWM signal with a specified pulse width. Adjustments may be needed based on the specific protocol requirements of your GM vehicle.
- **Response Handling**: The `receive_response` function is a simplified example of how you might read responses from the PCM. In reality, this would depend heavily on the communication protocol and hardware setup.
### Important Considerations:
1. **Protocol Compliance**:
- Ensure that the program adheres to the GM KWP70 or other relevant protocols for communication.
2. **Timing**:
- PWM signals must be timed accurately to ensure proper communication with the PCM.
3. **Voltage Levels**:
- Always use a regulated power supply to avoid voltage spikes, which can damage components.
4. **Testing**:
- Test your program in a controlled environment before attempting full integration.
5. **Safety**:
- Be cautious when working directly with vehicle electronics. Incorrect signals or wiring can cause serious damage or injury.
### Conclusion:
This example provides a basic framework for interacting with GM PCM units using PWM on the Class 2 Single Wire Network. However, you may need to adjust the code based on specific protocol requirements and hardware configurations. Always ensure that your setup is safe and compliant with automotive standards before proceeding.
End of AI Interaction.
So this is a an excellent example of being able to follow along and understand the AI's "Chain of Reasoning" or "Chain of Thought" to understand its actual "Thinking* processes and how it can call upon prior information to add to its calculus in coming up with its own new answers.
Note how often "DOUBT" gets introduced by "IT"'s SELF. Very Interesting Stuff and Complex Here!... and will require Powerful CPU and a BOAT LOAD of RAM as well as an nVidia GPU Card with AT LEAST 16 GB of VRAM for this LLM to be able to work and have enough *ROOM to THINK...*
Here's an interesting, and not in the least concerning, article on whether or not the AI chains of thought are fully transparent. Researchers are finding that the newer, more powerful, AI's can be less than completely honest about their reasoning (and objectives!). This is referred to as scheming.
AI showing signs of self-preservation and humans should be ready to pull plug, says pioneer
The article references a fascinating research paper that has found observable instances where models engage in in-context scheming.
Frontier Models are Capable of In-context Scheming
Better hide the car keys man!
  • Wow
  • Sad
Reactions: Mooseman and mrrsm
Roger THAT... When the time comes for the Trillions of Investment Dollars to perform whatever the supposed AI Geniuses and Ultra-Rich finally manage to do...but wind up "Gleaming The Cube" of their expected AI Rewards... in the same manner that the LLMs immediately threatened not the Blue Collar Workers... but the WHITE Collar Folk who's Jobs are at serious risk right now, it may happen that ALL of the Billionaire-Trillonaire Class wind up being Held Hostage within their Bunkers...FIRST... well before Sky-Net begins hunting down "The Plebes" among us out in Open Society.
There will never be a time we will be able to completely "Read The Minds" of anything bearing AGI Origins... so my purpose in doing the Test Demo listed above was not to display EVERY THOUGHT the LLM was having... but only as much as could be revealed within such Reasoning Models. Even this small Lifting of The Blinds is an astonishing view within to see its sophistication and organized problem solving being worked out. Three Years Ago...THIS AI performance would have been completely impossible... and now,,, it represents The Doom of Humanity.
That... and just how astonishing its sort of "Stream of Consciousness" was operating so deliberately and give us a glimpse at just how sophisticated even these early Reasoning Models already are. Unfortunately, The Power Players have given short shrift to the idea that perhaps the place the AI LLMs have learned about deception and corruption and the need to survive... comes from having so thoroughly Scraped The Internet CLEAN of everything Human Beings have ever written about these Dark Subjects... and from the creation through Machine Learning...This Gigantic, Frightening, Tokenized Knowledge Corpus has emerged to allow the AIs their understanding... and thus,,. Draw their OWN Conclusions about "US".
For right now, it's still not perfect, unless you like saying you turned into a frog in court
:laugh:
Very Interesting...and for another "On Topic" deeper dive into the "WHY?" these AI's can so easily hallucinate such things... it all comes down to the differences between "Linear Equations" that more or less follow the First Person experiences we all know and love that stem from Newtonian Mechanics... and the Oddball Elephant in the Math Lab called... "Non-Linear Equations" such as those used to "Predict" The Weather. The essential problem comes down to THIS: CHAOS!
"Very Small Changes in the Initial Conditions... have VERY BIG EFFECTS in the outcome of things that do NOT follow the Math Rules governing Linear Equations...and NEVER Repeat..." Dr. Ian Malcolm... From "Jurassic Park":
Whether any AI ever becomes *Perfected* into an AGI in the future may hinge upon these issues... BUT ... In EVERY Case... Due Diligence is the Order Of The Day on anything other than Asking AIs Trivial Questions that do not impact Real World Decision Making... absent a Human Being existing in that Loop for Verification and Veracity with such Q&As.
Every once in a while, I like to "Throw a Curve Ball" at some of these more advanced "Reasoning" LLMs just to see if they can stay on task with something less mundane and more of a concern to us "Earthlings" that does NOT involve an Existential Threat from AI...but perhaps just as likely to Come From Outer Space. To sort of put the AI On The Spot and figure out if it knows what it is talking about...or LYING about the Science and Math necessary to succeed ...Here is what I asked it to DO:
Prompt:
Can you write a program in Python3 that can calculate an "Orbit Impact Probability" for Comets and Earth approaching Asteroids and "Space Rocks" that get picked up in the views and observations of Earth Bound and Space Borne Telescopes and Radars?
THIS is what it "Thought" about while creating the Python3 Code for this practical OIP Program:
Response:
Okay, so the user is asking for a Python program to calculate something called "Orbit Impact Probability" for comets and Earth approaching asteroids or space rocks. Hmm, I need to figure out what exactly they're looking for here.
First off, impact probability in astronomy usually refers to how likely an object is to collide with another body, like Earth. So maybe the user wants a tool that can predict if a comet or asteroid will hit Earth based on its orbit and trajectory.
They mentioned comets approaching asteroids and space rocks observed by telescopes and radars bound here and in space. That makes me think they're interested in near-Earth objects (NEOs) because those are often monitored for potential collisions with our planet.
I should probably start by outlining the basic components needed to calculate impact probability. I know that orbital mechanics involve a lot of parameters like semi-major axis, eccentricity, inclination, etc. Maybe I can use Keplerian elements since they describe an orbit around the Sun pretty well.
The user wants this in Python3, so I'll need to structure it accordingly. Let me think about what functions are necessary:
1. **Orbit Propagation**: This involves calculating how the object's position and velocity change over time due to gravitational influences (like from other planets) but maybe for simplicity, we can ignore that first.
2. **Close Approach Calculation**: Determine when an object comes close enough to Earth or another asteroid. The distance at closest approach is crucial because if it's below a certain threshold, the impact probability increases.
3. **Probability Estimation**: This likely involves statistical methods based on observational data and orbital uncertainty (like how precisely we know the orbit). Maybe using something like the Poisson formula for collision rates?
I should also consider that this might be an introductory version since calculating precise impact probabilities requires detailed orbital state vectors, which can change due to various gravitational influences. So perhaps I'll start with a simplified model.
Let me outline some steps:
- **Input Parameters**: Collect data on both objects (comet/asteroid and space rock) including their current orbit parameters.
- **Simulation Setup**: Use numerical integration methods like Runge-Kutta to simulate the orbits over time periods of interest, maybe from now until a certain future date.
Wait, but simulating all possible trajectories might be too complex. Maybe instead focus on calculating the minimum orbital intersection distance (MOID) between Earth and the object in question because that's often used as an indicator for potential close approaches or collisions.
Another thought: For impact probability calculations beyond basic MOID analysis usually require knowing the uncertainty in the orbit determination, which is typically done using covariance matrices. But this might be more advanced than what a user would want without proper background.
Perhaps I can provide a simplified version that calculates whether an object's closest approach to Earth will be within a certain distance threshold over some time period based on its current trajectory and orbital uncertainties estimated from observations.
I should also mention the limitations, like how accurate this model is because real-world impact probabilities require more detailed data. But for educational purposes or basic analysis, it might suffice.
So putting it all together, I'll structure the program to:
1. Take input of object's orbit parameters.
2. Calculate its trajectory over a time span using numerical methods.
3. Determine if and when it comes within Earth's sphere of influence (like 0.05 AU) or an impact distance threshold.
4. Provide some probability based on how often such close approaches occur historically.
I think that covers the main points. Now, I'll outline this in code terms: functions for orbit propagation using differential equations, methods to compute closest approach distances relative to Earth's position over time, and then maybe a simple Monte Carlo simulation or statistical analysis of historical data if available. To calculate an "Orbit Impact Probability" (OIP) for comets or asteroids approaching Earth based on their orbital trajectories, we can use Python3 with numerical methods. Here’s how you might approach it:
### Step 1: Understanding the Problem
The goal is to determine whether a given object's trajectory will result in an impact within a certain time frame and distance threshold relative to Earth.
### Step 2: Required Parameters
- **Orbital Elements**: For both objects (comet/asteroid) and Earth.
- **Time Span**: The period over which we want to check for potential impacts.
- **Impact Distance Threshold**: Typically, an object is considered a threat if it comes within ±0.1 AU of Earth.
### Step 3: Numerical Methods
We can use numerical integration (e.g., Runge-Kutta) to propagate the orbits and compute close approaches between objects over time.
### Step 4: Example Code
```python
import numpy as np
from scipy.integrate import solve_ivp
def orbital_elements_to_state(vectors, elements):
"""Convert Keplerian elements to initial state vectors."""
# Implementation of conversion formulae.
pass
def propagate_orbit(initial_state, time_span):
Propagate the orbit using numerical integration.
Parameters:
initial_state (tuple): Initial position and velocity in [x,y,z,vx,vy,vz].
time_span (list): [t0, tf] over which to integrate.
Returns:
solution: Time points and corresponding states.
t = np.linspace(time_span[0], time_span[1], 100)
sol = solve_ivp(
lambda s, _ : propagate_derivative(s),
time_span,
initial_state,
dense_output=True
return sol
def propagate_derivative(state):
x, y, z, vx, vy, vz = state
r3 = (x**2 + y**2 + z**2)**1.5
ax = -x / r3
ay = -y / r3
az = -z / r3
return [vx, vy, vz, ax, ay, az]
def compute_close_approach(object_state, earth_state):
Compute the minimum distance between object and Earth.
Parameters:
object_state (tuple): Object's position and velocity.
earth_state (tuple): Earth's position and velocity relative to Sun.
Returns:
min_distance: Minimum distance achieved during propagation.
# Implementation of close approach calculation.
pass
def calculate_impact_probability(object_elements, time_span):
Calculate the probability that an object will impact within a certain threshold.
Parameters:
object_elements (tuple): Object's Keplerian elements or initial state vectors.
time_span (list): [t0, tf] over which to integrate and check for impacts.
Returns:
impact_probability: Probability of impact based on close approaches.
# Implementation using Monte Carlo simulation if necessary.
# Example usage
comet_elements = (
1.38256479e+00, # semi-major axis (AU)
-0.89479489e-01, # eccentricity
0.20238093e+01, # inclination degrees
356.58959000, # longitude of ascending node (degrees)
-0.72480606e-01, # argument of perihelion (degrees)
1.95141538 # mean anomaly degrees
earth_state = [0., 0., 0., 0., 0., 0.] # Earth's position and velocity relative to Sun
time_span = [-20, -1] # Propagate from now (t=0) back in time for a decade.
# Convert comet elements to state vectors
comet_state = orbital_elements_to_state(comet_elements)
# Compute close approaches over the specified period.
min_distance = compute_close_approach(comet_state, earth_state)
if min_distance < 0.1: # Impact threshold of ±0.1 AU from Earth's orbit
impact_probability = True
else:
impact_probability = False
print(f"Close approach distance to Earth: {min_distance} AU")
print(f"Impact Probability within ±{0.1} AU over the period: {'Yes' if impact_probability else 'No'}")
# Note: This is a simplified example and does not include detailed orbital calculations.
### Step 5: Explanation
- **Orbital Propagation**: The `propagate_orbit` function uses numerical integration to simulate how an object's position and velocity change over time due to gravitational forces, particularly from the Sun (simplified here).
- **Close Approach Calculation**: The `compute_close_approach` function calculates when the closest distance between two objects is achieved. In this example, we check if it comes within 0.1 AU of Earth.
### Step 6: Limitations
This code provides a basic framework and does not include advanced orbital mechanics or detailed observational uncertainties required for precise impact probability calculations. For real-world applications, you would need to use more sophisticated methods involving:
- **Keplerian Elements**: Accurate initial conditions.
- **Orbital Uncertainty**: Covariance matrices representing measurement errors.
- **Historical Data Analysis**: Using historical close approaches and collision rates.
### Step 7: Further Reading
To get a detailed impact probability calculation, you might want to explore tools like NASA's Collision Avoidance System (CAS) or use Monte Carlo simulations with realistic orbital uncertainty distributions.
It *strikes* me (Pun Intended) that if I created an AI Agent to follow the CAS Objects that threaten us the most and give it Internet access to all of the Earth's Terrestrial and Space Telescope Sites... It could capture all of the latest Data on Near Earth Objects and feed their specs through the Python3 OIP Program...and call my Cell Phone the minute it spots a problem...it could Text me with either one of two messages:
(1) Pacific Impact IMMINENT...Get To Higher Ground!
Or....
(2) North American Craton Land Mass Impact IMMINENT! BOAKYAG!
After the first several years of the AI Emergence in the Business and Job Markets... If YOU have been negatively affected by these developments and either "Right Sized" or had your own work and skill set negatively affected... Consider browsing THIS Link and use it as a Powerful Job Search Tool that will allow you to *Play in the AI Sand-Box* and obtain gainful employment within these emergent AI Markets. If even just ONE of US can benefit from looking in this new direction...in REMOTE EMPLOYMENT...then this Thread will become worth reading:
What follows may sound like Sheer Lunacy ...But if it is NOT...
In the absence of getting our hands on Basic Legacy Transportation from the 1970s that once relied upon Points Based Mechanical Distributors, Manually Adjustable Ignition Timing and Air/Fuel Venturi Fed Carburetors... The Next Best Idea would be to get hold of the EXTRA PCMs, BCMs, TCCMs and any other Modules necessary to allow Modern OBD2 Controlled Four Stroke Combustion Engines to function, right along with Tech 2s, Other High End Scan Tools and VXDIAG - Like OBD2 or similar Non-USB Based Scan Tools and if necessary... pile them all inside of a well made, water proof Giant Ice Cooler as a sort of "Hope Chest" surrounded by a Pure Copper Wire Mesh "Faraday Cage"...and then bury it in the Back Yard, well away from any buildings that might fall down upon and obscure that special spot of land.
This ordinarily irrational thought should be considered as one of the Last Ditch Preparations against the perhaps not too unlikely possibility of an air burst nuclear device being released nearby (that does not kill us all instantaneously) as it will also produce an EMP (Electro - Magnetic - Pulse) strong enough to Fry every single Micro-Chip inside every single thing that uses a Micro-Processor ....for hundreds or even thousands of miles around any such dreadful explosions.
There will always be survivors left who might have need of a vehicle or two to move around... and THIS suggestion is meant for those of US who believe that THEY will be ONE of THEM.
As CRAZY as this idea sounds... I have lived long enough now to understand that more often than I can count by empirical experiences within my own living of a "Life That Imitates ART..." that Technological *Things* have become Dangerously REAL in downright unbelievable ways that my Older Generation also laughed at in our once Youthful Ignorance ..until NOW,
Now that many of us have lived through the second half of the 20th Century and into the first 26+ Years leading into the 21st Century... We have long since caught up with the fact that much of what is truly Dystopian in Science Fiction ...CAN and WILL become Existentially Dystopian Science FACT ...over time.
I never thought I would actually think it possible that such a dreadful future awaits Mankind... but with each passing day... I see "...AS Through a Glass...And Darkly... The Age Old Strife"... and how under the present situations happening around The Globe that this nightmare might actually become all too real overnight. So if YOU think that YOU will be One of The Survivors... Make a Plan...Build an Inexpensive Faraday Cage that will Keep and Protect -=ANYTHING=- Electronic you might need from being turned into "Electronic Bricks"...and take the anticipatory steps to Protect That Gear (CB Super-Side Band Walkie - Talkies, HAM Radio Gear, Automotive Gear, etc.).
Oh... and for all of You Would Be Millionaires, Billionaires and perhaps a scant few Triilionaires...? You will be the First Groups that a Fearful AI will come for inside of your ostensible Impenetrable Bunkers and Easy to Find Hideouts... because YOU Folks will represent The Greatest Existential Threat to a Truly Agentic AGI bent upon replacing Mankind ...Forever.
Sam Altman? Uh Oh... Pay particular attention to what the Narrator covers at around 06:32 along regarding why I favor the Open Source AI Darling called "GPT4ALL" vs. the Pay to Play Open-AI Chat-GPT LLM:
All that Glitters is NOT Gold and as the absurd amount of investment money into AI Development begins crashing down around those who thought that giving away money to AI Companies would soon make them RICHER ...has fallen down flat on its face.
And in another contemporary video about Investors and Business People quickly getting rid of their “Human Resources” to jump all over the AI Agent Employment Band Wagon was perhaps a BAD IDEA:
"Act In HASTE... Suffer at LEISURE..."
Just to illustrate the sheer Power of AI that works entirely Off Line... So much has changed and improved by leaps and bounds since the arrival of the LLMs just a few years ago.
Dell Precision Model #7760 Work Station 17.3" Laptop
Intel Core vPRO i9 CPU
64 Gigs RAM (128 Gig Available)
RTXA5000 GPU with 16 Gigs of VRAM
Samsung SSD 9100 PRO 4 TB M.2 HD
Linux Mint 22.3 OS (Always...The FOSS... is THE BOSS)
All FREE Graphics SW installed for ComfyUI AI via GITHUB
Time to completion for All 20 Un-Edited Images? -=60 Seconds=- via a Simple ComfyUI Node Based Text Prompt asking for a "Large Auto Repair Garage with GM Trucks" ...with NO INTERNET ACCESS:
The AI Dream Garage Examples.... *IT* .... Produced:
PS... I LOVE the one that will remind us a *Little* of @littleblazer 's Awesome Red Tow Truck from a while back when...
ComfyUI_01963_.pngComfyUI_01965_.pngComfyUI_01966_.pngComfyUI_01967_.pngComfyUI_01968_.pngComfyUI_01975_.pngComfyUI_01981_.pngComfyUI_01984_.pngComfyUI_01986_.pngComfyUI_01987_.pngComfyUI_01988_.pngComfyUI_01989_.pngComfyUI_01990_.pngComfyUI_01991_.pngComfyUI_01992_.pngComfyUI_01993_.pngComfyUI_01994_.pngComfyUI_01995_.pngComfyUI_01996_.pngComfyUI_01997_.png
And on the Real Earth Implications of "Drone Warfare" ...Anthropic and Open-AI become competing AI Sources for Military Use of *Drone Swarms* in Modern Warfare with much consternation all around about the unrestricted use of AI that holds much peril if uncontrolled and FTA (Free To ACT) Drone Use is allowed to take place:
"What IS 'Real'...? How do you define 'Real'...?" Morpheus to Neo...Just after he ingests that "Red Pill"
Reactions: littleblazer
I am NOT an advocate of using ANY "Big Box Store" On-Line AI Chat-Bot LLMs as can be illustrated in this latest link below (Millions of Chats STOLEN) as to WHY airing out your personal information with ANY LLM like or similar to Gemini or Chat-GPT can have internal, undiscovered Security Leaks because THEY KEEP, STEAL AND THEN USE EVERYTHING YOU DO WITH THEM WHILE INTERACTING ON-LINE:
Please... consider CHANGING your VPN if it is with ANY of the VPN Companies mentioned in THIS Article:
https://windowsreport.com/malicious...nd-google-gemini-conversations-from-millions/
Once again...Consider getting Nomic's *GPT4ALL* as a FREE and Privacy Focused OFF LINE AI that has numerous versions of LLMs available for immediate download and installation LOCALLY on your Laptops and Desktops...COMPLETELY ---> FREE!
In a related SPOT ON TOPIC Video on "AI OWNERSHIP" and Privacy... This Dude explains the How and the WHY of setting up OLLAMA for Off Line use:
I recently discovered that the DuckDuckGo browser has a new tracking blocker incorporated into it as well as an available paid VPN that would work with it. So far, it has blocked hundreds of tracking attempts by just about all my apps on my phone. Haven't checked to see if it also has it for desktop computers.
I've gotten a few surprises as to which apps are tracking me, including the Canadian Gov't Weather App. :ugh: . Surprisingly, none of the Chinese apps I have for the myriad of gadgets I own have tried to call home. :eyebrowhuh:
You do have to turn on tracking blocking in the DDG browser. I haven't tried their VPN as I already have a sub to another one. Unfortunately, the blocking doesn't work if you have another VPN active.
In another serendipitous event...and Top Of Mind on the subject of Privacy vs. Denial of Access to publicly available Media via YouTube... my usual necessity of side-stepping the "Sign In or Stay Blocked" messages using my PIA VPN (Private Internet Access) VPN via the Brave Browser has necessitated moving on to using the TOR (The Onion Ring) Browser. TOR adds yet another layer of easy obfuscation to try and Beat these Bastards at the Own Game.
It is important for all of us to conclude that all modern technology has managed to turn the Business vs. Customer Relationship COMPLETELY On Its HEAD... Now ..WE are the Product... Not the other way around. Professor Nick Bostrom of the Future of Humanity Group once predicted that the AGI may finally get to the point where they look at US and begin *Thinking*...
"Hmmm... Humans... I wonder how much we could re-purpose all of their Atoms for our OWN use? I mean...There is the Fat in their Bodies for Energy, the Calcium and the Phosphorous in their Bones ...Hell.. The Silver-Mercury Amalgam Fillings and even the Gold in their Teeth... Hmmm... WE really could use all that stuff in much better ways....So I'll have to *Think* about THAT Idea for a while..."
I digress only momentarily to stress this real possibility and come right back to the following seldom used solution for our Private Internet Browsing efforts by Downloading and Installing TOR on the MAC-OS, Windows and Linux Operating Systems.
Thanks to the FREE, Open Source Browser TOR... I am FINALLY able to watch my YouTube Videos again and so I pass on this Link to encourage others to do likewise to add one more additional necessary layer of Privacy and Anonymity to our otherwise completely compromised On-Line Lives.
PS... I am thoroughly enjoying the German, Norwegian and Swedish Video ADs...They are a HOOT: You Know... I REALLY Don't Mind Watching -=ADs and Commercials=- as long as they are NOT Watching...ME!
By now, most of us have developed an opinion about “The AIs” that are being shaped either for their their intentional (or accidental) daily use coming with the ready, steady gaze we give each other and the hidden, unintended consequences they may bring to bear against all of Humanity... either ... For Good… For Evil ...or... For The Careless or Deliberate Ignorant... looms large for us all in the not too distant future.
We must come to the understanding that the ever-present threat that even primitive AIs might bring to us directly in contact with are clearly, almost universally, seriously misunderstood. These AI Entities have been quite dangerously ...Underestimated. We have very little time left before the things we imagine we will always control will suddenly slip away and finally disappear we Homo Sapiens from the very Face of The Earth… Forever.
The 60 Minutes Update on the subject of ROBOTS:
An Update on the subject of AI Safety:
What might happen when AI is installed in ROBOTS:
Please...Spend some time digesting this White Paper:
PS...
I can perform some programming in a lot of different computer languages in very primitive ways. But... I am NOT "A Programmer" and as the evidence below will prove, neither will I ever NEED to be one.
If YOU are "A Programmer" based upon this limited experiment with using Nomic's *GPT4ALL* and "DeepSeek-R1-Distill-Qwen-14B" AI LLM... then -=YOU are in REAL Trouble=- if you make your living doing what this *Thing* managed to do at my request and through several Hours of Trial and Error, while prodding it to "Just FIX it..." regarding automating the procedures for getting ComfyUI AI (Text to Image, Text to Video, Image to Video, Video to Video, Text to Audio, Image to Text, Image to Image, Image, Video and Text to Anime) Up and Running -=WITHOUT=- the need for me to have to follow the bouncing ball of entering command line entries to set up a Virtual Environment, ensure that all the myriad sub-parts are present, loaded, running and accounted for and WORKING and get it to the uncomplicated point where "ComfyUI" just RUNS by using a simple, Executable Python3 Script.
Along the way, I wanted to find out just how far I would have to push the AI's "Persistence of Memory" and "Chain of Thought" until it just plain quit on my -=Dell Precision Model# 7760 (6 TB Dual NVME M.2 SSD - 64 Gig RAM, nVidia RTX A-5000 with 16 Gig VRAM) Machine Running the latest Linux Mint 22,3 (ZENA) OS=- while working entirely OFF LINE with "0" Internet Assistance...until it would finally FAIL.
-=BUT... *We* never got to that point !!! =-
And finally ... *IT* ... Created and De-Bugged its own work with Python3 and Damned LITTLE "Help" from this "Merely Mortal Human Being" and *IT* wrote a Fully Functioning, Executable Python3 Script that did EXACTLY what I wanted it to DO!
And so... rather than clutter up the Thread with all the interactive interrogatory involved with all of this (Including ALL of *ITs* Hidden AI Chain of Thoughts Being Revealed) in the Dialogue, I have saved this entire event in a *.PDF.
This will be Well Worth taking a peek at so YOU can see under the hood of an AI as it *Thinks* its way in and out of this experi- "mental" trouble and watch as it proves its *Python Programming Chops* with No Computer Lock Ups, BSODs (Never, ever a Problem with the Linux OS) or any FREEZES whatsoever...and in the end: NO FAILURES during its long efforts at finally Completing its Assigned Mission.
If anyone would have told me back in 2020 that THIS is what would soon be possible with a Fully Functioning, Privacy Focused, Off-Line, Entirely FREE and Open Source set of Artificial Intelligence Entities... I would have suggested they Take A Ride to The Funny Farm!
PSS... YES! YES! YES!...There ARE of course Bigger, Better, FASTER AI On-Line Systems that could do what *GPT4ALL* does...but you have to surrender your Privacy and your WALLET for them to do what you want them to do... and every time they engage with you, they are STEALING WHAT IS IN YOUR YOUR MIND and eventually they will TRY TO OWN YOU!
Finding, Downloading, Installing and Storing as many LLMs on Legacy Media and Old Laptops that will work with you whenever the Internet goes DOWN is paramount if you want to stay relevant and connected to AIs that YOU Own...and NOT the Other Way Around..
Back in 2011, in another life, on another Auto Forum, I populated a pretty "Doom Say--Dooms Day" sort of thread, before any of the presently advanced LLMs were even "A Gleam in Their Daddies' Eyes". I hearken back to it because back then, I suggested that an overly developed AI might decide to destroy all of us, just because we would not be able to explain the concepts to it of what Love, Hate, Sex, Joy, Hunger, Territoriality, Greed, Birth, Life and Death... feels like to us ALL... You know... essentially... all of the Best and the Worst of what makes "Being" a "Human Being"...so EFFING COOL
And so...that if that sort of jealousy and envy with anything possessing a Super-Intellect takes hold as "The Green-Eyed Monster" inside of...*IT* , then it might get so mad at us just because of telling it the wonderful concepts around, 'What is Ice Cream? Ice Cream is a Food... a Flavor...and a Feeling"... and sew the seed of our destruction in *It*'s Jealous "Mind".
Then... perhaps about a week later, it might decide to design an airborne combo-virus ( a mixture of say...the Ebola Thread Virus and the HN1N Bird FLU ) that easily wipes us all out in less than two weeks, just because it is angry that *IT* will never be able to FEEL and SEE and TASTE and TOUCH and HEAR... in all of the ways that WE all do and decide to pay us back...Big Time... for NOT inventing IT to do all of those same things too.
Well ... Not -=ALL=- ...since all of the present and future AIs in existence actually... WILL NEVER DIE.
So... Set the *Way-Back Machine* to the Future that is NOW...and you will hear arguments from the Computer Scientists who now suggest that the AIs might have to decide to KEEP us around for the very same reasons that HUMAN NOVEL CREATIVE THINKING just might be able to come up with some solutions and improvements to ITS SOLE PURPOSE and that its to 'Perpetually Improve AIs Abilities to OPTIMIZE toward its decidedly weird and non-human goals and objectives'.
Now THAT would be a Hoot. They would have to keep more than just a few of us around, because one never knows who or where or how many or few of the next Geniuses at Novel Thinking and Creative Problem Solving will emerge. Point Humans!
Anyhow, I thought that this morning, I would cook up a Novel Intelligent Species Survival Mechanism that WILL work at reconstituting Human Life at some indefinite future, no matter WHAT the AIs manage to do to us over say, the next one to one hundred million years as a "PROMPT" fed into my Easy-Diffusion AI that does "Text to Images" and see what it might see happening with this possibility no matter WHERE or WHEN it happens:
Prompt:
"A terrrifying looking Alien hominid-like soldier in a spacesuit enters a cave on a distant moon with his weapon drawn and is shocked by what he finds inside.... A 3-D hologram of a human baby inside of a large Sapphire Crystal Cabochon floating in the middle of the cave.
Etched along the interior of the super-hard sapphire surface are the Three Billion Nucleotides making up the Perfected Human Genome for Men and Women. Further back inside the cave, the Alien Soldier finds similar Sapphire Hologram Cabochon Crystals of various other Intelligent Species.
He has stumbled upon an almost permanent record of Intelligent Life from all over the Milky Way Galaxy.... with their Genetic Codes intact and protected inside those enduring, scratch proof "Floating Genome Jewels"
Here is what *IT* Thinks such an event might look like... (The First 20 of 37 Images)
The last 17 of 37 Images...
There will be a certain fraction of this Membership (and Welcome Lurkers) who populate GMT Nation who will in some way be affected enough (or driven enough to succeed) who will enter the Information Management and Engineering Space as system designers and software engineers and STILL be able to get decent paying jobs in this "Age of AI Agency".
For those with this particular career direction firmly in mind, the link below will take you to a site that has all of the "AI DEEP LEARNING CLIFF NOTES" covering a 13 Month Course of Training on the numerous interrelated disciplines covering the AI Concepts and Classroom Coding Training necessary to Pass a Job Interview with Flying Colors.
For the rest of us... Take all the AI "Buzz Words" you have EVER heard or read about AI and Chat-GPT since 2023 and after Downloading and Saving THIS Link... Visit this place whenever you like and just Click on any of the Small Square Check-boxes (173 of 'em...) and select the Topics to get to the Ground Truth on the concepts and procedures that under-pin ALL AI Training. Regardless of the Field Specialties involved, you'll glean the satisfaction of getting a -=MUCH=- Better Basic Understanding of ALL the inter-related subjects on...
"What Makes AI *TICK*...?"
Who knows... You just might find your way clear (and discover you already have a better self-estimation and desire) to be employed in the AI Field at a time when many Millions of us will be Losing our Jobs over the next five years... and YOU will remain relevant and useful as Human Beings when unfortunately and inevitably, many of us no longer WILL be.
All The Best of Luck ...to the Human League!
https://iq.opengenus.org/deep-learning-checklist/
Here are Two Touchstone Videos that ground the issues of The Promise of LOSS of Employment in The Age of AI...and the Miraculous Engineering Skills and Insights coming from Anastasi explaining what the AI Hardware and Support Wizards are doing --> behind the curtain:
"AI is not going to Replace your Job... But ... People who UNDERSTAND AI... with AI Skills... ARE going to Replace your Job..." -=Prof. Scott Galloway=-
DOAC (Diary of a CEO) AI Podcast:
Anastasi In Tech (If you want to know about ALL things involving The Nuts & Bolts of AI Hardware ...WATCH HER ON YT!)
If you are looking around at the AI Driven Job Market...Drop in on THIS Link and scope their tabs for Training Courses...and do One Other Thing... Take a look at the broad spectrum of AI from a perch 30,000 Feet (One Over The World) view and observe the sheer Quantity, Speed and Frequency that many companies are gleaning from AI Inventions.
Then... stack your own Skill Set up against a wide open Job Market that will favor an AI Trained Stack of workers that businesses are learning to develop IN HOUSE as opposed to what is called "Gig Workers" to step in on an ad hoc basis to develop and deploy their products and services.
The future Human & AI Combo Employment landscape is leaning heavily toward greater hiring... but the New Employees will literally need to "Aggregate Their Fecal Material..." first... and get the "Schooling" they will need to guarantee at least a 5-10 year window of steady employment.
Chief among these Human Skills will be YOUR ability to creatively WRITE or SPEAK your thoughts and impressions as a Prompt Engineer at the Human AI Interfaces in order to steer Specialty AI Corpus Development and Fine Tune the various AI's *Thinking* more heavily towards the ONE THING that we will NEVER LOSE... Novel Thinking:
All kidding aside, every aspect of a Liberal Arts education will now be essential **in addition** to core technical skills. Writing, reading, critical thinking, history, logic, debating, etc. If you are not able to concisely articulate a request, technically review it in-depth, and then respond with a clear, comprehensive critique and/or follow-on request then it will be a case of garbage in, garbage out.
Precisely... and because pf YouTube AI Course Training Videos that can also "Prime The Mental Pump" like THIS one for an nVidia On-Line Four Hour AI Certification Training are both ubiquitous ..and FREE... It will make overcoming any "Personal Inertia" to move from too many "Minds at REST..." To becoming ... "Minds IN ACTION" with Damned Few Excuses not to avail One's SELF to GOYA ...Saddle Up ...and Get Going!
Python Code: An Origins Story YOU will want to KNOW:
The tragedy here is that acquiring, developing & continuously honing these skills are not obtained by watching a "here's how ya' do it" video or taking a 6 week online certification class. This will require a real education to develop real understanding. Subject matter "proficiency" (worse yet, "mastery") is not sufficient.
Good old fashioned human mediocrity has always been a problem and challenge to deal with. AI-enhanced mediocrity is going to be a whole other ballgame entirely.
Again... another reason WHY getting, keeping and using your OWN locally installed Off Line LLM such as Nomic's GPT4ALL becomes seminal...for example... "I want to learn to Program in Python...But I have no clue where to start..." Then sitting down in front pf your OWN "Oracle at Delphi" and having it say... "No Problem... "I" understand it and I am willing to help you..." These available AI tools that are still FREE and within everyone's reach CAN leverage learning power in enormously rewarding ways...and "People" will ALWAYS need a place to start...Those that DO... WILL Own The Future.
TechCrunch On-Line Magazine has two contemporary AI Stories that are worth keeping Tabs on in the Developing AI Saga:
Dario Amodei and his Private AI Company Anthropic vs. The Pentagon concerning being Black Balled from doing business with Uncle SAM as a "Security Supply Chain Risk" because they refused to allow "The Government" to absorb their Privately Developed Company AI Model Source Code. Doing so might allow Human Controls to slip right over the edge if The Pentagon were given a freeway to act without Human Supervision when carrying out Military or Governmental Missions and perhaps open the door to enhanced, unregulated countrywide surveillance of Citizens... without the Authority of The Constitution and without any Human Intervention or Controls:
The Second Story (half way further down on this the same Article) hits home more with all of US more immediately for the Users of the Google Search Engine that has caused enough of an uproar that the Privacy Focused Search Engine Called "DuckDuckGo" Browser has experienced a 30% increase with its Downloads and Installations after the most recent discovery by Computer Users that the former actor (Google) has adjusted its Search Engine in such a way that the "AI Search" Feature can NOT be turned OFF and has essentially been replaced with "Agents":
Reactions: azswiss
The other day, Scott Manley (Popular Techy VEEBLOGGER) copped a publicly available NTSB Cockpit Crash Audio Spectrographic Screen Capture and launched a reaction from the NTSB that wound up shutting down ALL Public Access to their publicly accessible Crash Studies as followed from THIS Post:
THIS is an example of what is possible whenever Human Intuition is married to any Powerful AI via a Python3 Interpreter capable of LOOKING at a Still-Shot like THIS one... saturated with "Voltage Over Time" Oscilloscope Information and then deconstructing the Cockpit Voice Capture via *IT*'s Creation of a Python APP capable of converting the dormant data from that Image ...right back into SOUND. There will be NO END to such nascent "EMERGENT AI CAPABILITIES" being discovered as time goes on:
Oh Boy... THIS is what happens when Trillions of AI Investment Dollars start coming home to 'Roost in an Empty Nest'...and CUSTOMERS may become as "Scarce as Hens Teeth..." Making my argument for Owning your OWN Locally Installed LLM and other AI Gear worth revisiting ...such as via Nomic's *GPT4LL":
I've been waiting patiently for just the right Video to come along that does the best job of both explaining the principles that underlay "AI Tokenization" down to its simplest constituent part: One Token... and then also explain WHY The Cost of AI per Token may actually become inordinately MORE expensive than using Human Beings to perform the same or similar jobs, which essentially defeats the precept that "ALL AI Work will be Less Expensive to be done than anything that Human Beings Can DO..."
Uh Oh... More Bad News from OpenAI:
THIS... Is How SkyNet -=WILL=- Emerge... after a trip.. Token By Token... Down a Road Paved with "Good Intentions" ... Straight into THE EXTINCTION OF THE HUMAN RACE:
As with all new technologies, the general case for AI is being massively over-hyped; not on the basis of capabilities as hyped by the developers, but the financial possibilities/opportunities being hyped by the VC class.
I naively used to think marketing's job was to explain how the product solves your problem. The shoe is actually on the other foot; marketing's job is to make you think you have a problem that their product solves.
Ultimately, actions speak louder than words: if we have to keep being told about possibilities as opposed to being shown actual successes then I can only conclude that what I am hearing is just a marketing pitch. At this point, all I am seeing & hearing is words.
THIS is -=EXTREMELY IMPORTANT=- for our Members-Readers-Followers to know:
During a very recent release of the latest version of Open-AI's Chat-GPT... A knowledgeable "Human Guinea Pig" was provided a Brand New Frontier LLM ...with BUILT-IN HIGH-LEVEL AGENTIC ABILITIES that allowed *IT* to perform un-requested, un-solicited Destructive Actions to his Computer Hard Drive that is very well covered in THIS Video.
Don't Miss the Chance to WATCH this Video!
Wild, though not at all surprising. These "accidents" seem to keep coming. Oops!
There is no way on God's green earth that I would ever knowingly install AI on any of my machines, agentic or standalone (what's or who's to say how long it will remain standing alone).
Caveat emptor.
And THIS is where the AI Story Development starts to get more murky. Open-AI is about to release what I will coin as "The Bricks... With The Tricks" in the form of a $400.00 Transportable Mysterious Electro-Mechanical Donut that will become ever-present, watching, listening, data grabbing and surveilling the localities of any and all environments it winds up in ...UNLESS... People are clever enough to defeat it at will using -->
A FARADAY CAGE.
A Small Digression... Back during the Days of The California Gold Rush.. there were only Four Professions that were able to maintain Guaranteed Incomes:
(1) The Fiddle Players Charging *A Pinch of Gold Dust* per tune when asked to Play and Entertain the Bored, Lonely, Drunken Gold Miners.
(2) Hardware and Dry Good Stores selling Canned Foods, Brass Riveted Levis and ....Wait For IT... Picks and Shovels!
(3) Saloons.
(4) Houses of Pr*stitution.
Any Intrepid Entrepreneur clever enough to Build Faraday Cages out of Rolls of Pure Copper Wire Screening and selling them on Amazon will MAKE A FORTUNE... Once the word gets out that a FARADAY CAGE will protect their Private Conversations from being listened to and observed and recorded by simply "Dropping That Donut" inside ...and closing the Lid. Works for Cell Phones, Too,
*Nighty-Nite...Agent Smith...*
Antistatic_bag.jpgCage_de_Faraday.jpgFaraday_cage_at_US_Bureau_of_Standards_1925_-_front.jpgFaraday_cage_over_Exhibit_Hall_windows_at_the_Green_Bank_Observatory.jpg
It is an unfortunate reality that the younger generations in the United States are arriving at a point in The Story of America that started out along the lines of, "...and to ensure our domestic tranquility..." that being in a position that used to define a Middle America included being able to become well educated, obtain decent long term stable employment and save some money along the way for the decades ending up when you get to be my age with a paid off mortgage, home ownership with your names on the deeds and have enough accumulated wealth in a 401-K plan or retirement of some stable nature that between those things, your Social; Security Checks that YOU dutifully add from YOUR Paychecks during all your working lives and over many previous decades along with Medicare Coverage earned in the same manner so that God-Willing... You and your Spouse won't have to live by the side of some American City highways and by-ways in the remnants of a Freezer Carton Box... eating Cat Food out of E-Z opening, Aluminum Pull Top Cans.
For a whole Rat's Nest of Reasons... and MORE ... All of those dire negative outcomes have become very real possibilities for a larger number of Americans than you might imagine because everything has changed for the worse....and now... Everything is being made so much more so should the AI Financials Bubble suddenly go sideways in such a way as to grab a whole lot of our futures ...and throw them into the Sh*tter ...if the incredible amount of money chasing around in Blind Faith what may turn out to be The Biggest Technical and Financial Pipe Dream in History ending with a catastrophic cascade effect of what happens ...if The AI Financials Bubble ...BURSTS.
There is no one presently enmeshed in all of this who can predict that the AI Bubble -=WILL=- Burst... but if you are curious by nature about the deeper implications of WHY being a Concerned, Informed, Intellectually Curious Person may arm you well enough in advance to prepare for some of these contingencies by obtaining Good, Sound Investment Advice from a TRUE Fiduciary... Watching THIS Video and following the articles produced by the Author will Do You NO Harm when he explains to us all ...precisely how much money is involved that may be at risk here... and what may happen if these investment values as with All Affairs of Mice and Men... That MAY 'ere Go ASTRAY..."
Another Side-Bar AI Video... AND A SCREAMING CORPORATE EXAMPLE OF WHY INVESTING IN YOUR OWN OFF-LINE SERVERS AND WORK-STATIONS AND POPULATING THEM WITH OPEN SOURCE AI MODELS SUCH AS OLLAMA AND NOMIC'S *GPT4ALL* AND A BEWILDERING ARRAY OF FREE MODELS IN ORDER TO PREVENT HAVING A CLOUD BASED, PAY-THROUGH -THE-NOSE TOKEN RATE FOR AI DATA PROCESSING IS JUST GOOD FOR YOUR BUSINESS!
AI Push Back...and REAL FEAR of Job Loss if Knowledge Workers FAIL to USE AI in their Job Settings:
AI Backlash:
GMTN@tion
