Members projector retrofits
10,687
:undecided: What kinda light output do you get from the 3757 bulbs with the reflectors painted? I'm guessing you can barely see the turn signals during the day.
68impalacp
37
Its a bit over 3 from my lil town over to Evansville. Still would like another Indiana meet this year or maybe Louisville or something in the area.
I am sure the cost is over what i can dedicate to headlights for something that nice.
Yeah the price is up there a little. Lol and I'd be game for a meet we could always do a southern IN to North KY meet. Louisville is about 1.25 hour from me.
It's actually not too bad running switchbacks. This customer requested it, I tried to talk him into doing strips but he decided against it. When I painted I made sure to clear it to help with reflection a little bit more.
Reactions: Capote and Sib
10,687
:popo: You gotta get hip to using the multiquote feature. :nono:
I'm interested in seeing some daytime shots at distance if you can swing it. :yes:
Reactions: Sib
68impalacp
37
[emoji14]opo: You gotta get hip to using the multiquote feature. :nono:
I'll have him send some to me when they make it to his house. Lol I'm still learning to use tapatalk on this forum. I'm usually not a regular poster. I done mine the same way his are done for the bottom turn. Soon mine will be pulled apart and done for a 3rd time. I got some stuff I wanna change. I'm going to a strip on the bottom of mine to match the corner light.
I got a couple sets extra i ought to slide down and get a lesson in making lights mo betta
aaronbtb
82
Anyone know where I can find clear corners?
eBay has a seller, but he wants more for them what the entire headlights are worth.
littleblazer
9,265
littleblazer
9,265
10,687
Maybe he meant the Infinity Q45 multi lens projectors :undecided: I considered doing a retro with these a few years back, but research indicated the output wasn't that great and the cutoff wasn't as sharp as most everything else available for considerably less.
dmanns67
32,979
Those projectors look unique, but like you mentioned, I have read/seen pics of the not so great output.
I did see TRS came out with a Universal XB LED sealed fog light and it is their smallest one. Slightly larger diameter of the Matchbox 2.0, but the depth is significantly less. I have been contemplating how I could retro that into an OE TB fog light. It would appear much easier than the Match projectors. Pig tail coming out of the end is a basic 9006 plug which you could swap with a 880 plug. Did not see any mention of a driver, appears to be plug and play. Each fog light is rated at 1200 lumens.
Is it bad that I have not completed my first fog light retro and really contemplating taking on another :crazy:
Reactions: Sib
10,687
Considering I am also thinking of doing a selectable quad retrofit, with 5000K in one set and a 3000K in the other set, I can't blame you for thinking of another retro. :crazy:
Edit: I wonder if their GMC LED fogs would bolt right up for the Voy guys here
Reactions: Sib and dmanns67
aaronbtb
82
Anyone know what shrouds fit best? I'm trying to retrofit a fxr-3 in the lows, and the new mini h1 7.0 in the highs, with all Iris shrouds. I don't want to mismatch shrouds. These Iris ones are way to big.
10,687
There is no correct answer to this question, as it's purely subjective from person to person.
If you have a sanding drum and a rotary tool, you can trim the shrouds down bit by bit, to fit whatever shaping configuration you want. I had Iris shrouds in the high beam buckets of my first retrofit. :twocents:
Reactions: aaronbtb
littleblazer
9,265
Random cutoff shot.
dmanns67
32,979
I seen TRS posted up some Morimoto square Chevy LED fog lights for pre-order. They fit the Silverado, Avalanche, Tahoe, and Suburban 2007+ (all trim levels).
Sadly, nothing for the TB though. $200.00 is not a bad price either and a 10 year warranty.
Capote
24,227
Atlanta, GA
I'm sure that wouldn't be hard to make work on our rigs
Capote
24,227
Atlanta, GA
Capote
24,227
Atlanta, GA
View attachment 73398 Spyder headlight look but it not available for the TB
Spec-D's is as close as you'll get to that for our rigs. Unless you do do a retrofit and try to emulate that look, plenty of us guys on the forum have done Halos too
4,024
Are the Spec-D's plug and play? Or do you need to do a bit of re-wiring?
10,687
You have to wire up the 'halos' yourself, but everything else should be PnP.
4,024
Wouldn't want the halo version, so that's good. Any idea if their projectors are any good or should I just get Sparky to do his thing?
10,687
Only member I know personally that got the off-the-shelf projector setup was @Decembersend. I believe he felt they were servicable, although that jacked up cutoff on the passenger side (shoots up into the trees) was annoying.
Maybe he'll chime in on whether or not he would have retrofitted them anyway, had they not gotten muddy water inside the housing, causing him to need to take them apart anyway to clean em out.
Reactions: Matt and Capote
Capote
24,227
Atlanta, GA
I've heard that pretty much every set of those is prone to leaks. I always recall members saying that water piled up inside of those or they had constant condensation issues. Glad I never chose to get any Spec-D's.
aaronbtb
82
I have these, they are complete junk, terrible cutoff, ccfl stopped working.
I replaced the projector in it with a Morimoto Mini 6.0, and switched out the ccfl with 90mm Morimoto xsb switchback halos.
Pretty sure those Spec-D use the same crappy halogen projector.
Capote
24,227
Atlanta, GA
They're not worth it at all, best to use that money to invest into a retrofit
4,024
Thank you gents! Got to get my arse into gear and get some $$$ together.
Capote
24,227
Atlanta, GA
Hell yeah man
fhendsbee
