JayArr's 4l60E Rebuild Thread
Do I need to reset the PCM or tell it to "re-learn" the new transmission ?
Yes, you need either a tech 2 or other scanner capable of resetting the trans adapts.
The shifts sound about right to me for towing. The 4.2 is a higher revving engine so it's torque curve is higher.
FWIW, the TAP parameters are stored in data blocks. When a Tech 2 clears these learned values all it does is write zeroes to data blocks 41 through 49. The Tech 2 will caution the operator that this is only to be done after an 'internal repair' of the transmission.
Given proper instruction of how to do it one can even do it with the current version of Torque Pro using the direct control option in the Torquescan OBD Terminal feature.
I confirmed this today with a 2005 PCM here in my corral of parts.
OK, I've got a tech II (clone) so i can do this.
Next question: Should I clear it and drive around with no trailer for a week before my trip so it learns daily driver conditions or should I clear it with the trailer hooked up on the day I leave and let it learn with the heavy load.
Or can I do both and clear it whenever I change the conditions?
Well before clearing it I would be certain to read and save the current values for all the cells. Maybe take pictures of the Tech 2 screen(s) with all the TAP Cell data for 1-2 adapt and 2-3 adapt screens. There will be 4 screens of data total. There may be good diagnostic data in there. You might also find the values in there may be practically nil anyway, though I suspect this is unlikely.
I would be cautious about repeatedly clearing data that suggests significant corrections are in force. In other words I would evaluate what I saw before randomly clearing this learned data.
I sort of wonder if it matters. The learned adjustments are saved in different cells based on things like engine load, torque and so on. Cell 4 is the lowest torque load and the highest cell number would be for the highest torque loads. So it seems like the cells adjusted would be different with the trailer load vs without?
Sort of like if I learn with the trailer it'll adjust and fill the top half of the map with new data and when I run with no trailer it'll adjust and fill the lower half?
I guess I'll just record what's there and blank it out tomorrow.
I have read a few descriptions of how the system should work and it leads me to believe that these values don't change rapidly. For one thing, it is said that for each shift the system evaluates whether or not that particular shift is a valid one to judge with. Like if the trans temperature is not up to a threshold value then that shift is not used. And if maybe the AC compressor kicked in during the shift then that shift data is tossed out. Things that may affect engine rpm that are not transmission shift related can get a shift tossed out of the running.
Reading about the temperature threshold makes me wonder what that threshold is? And if we add auxiliary coolers might we end up with a temperature that's too low and the adapt system then rarely actually gets a shift it feels is valid for consideration? Who knows!
Seems like long term monitoring of the values is about the only way to see if the system is actually doing its job.
I am going to tack this question here since it is somewhat related.
Does anyone know for certain what year the transmission adaptive feature began on our GMT360/370 platform?
When I use my Tech 2 and select model year 2002 there is no menu selection for reading or resetting the TAP values. If I select the 2003 model year then there are selections for reading and clearing these values. However, looking at my 2002 (built in 2001) TrailBlazer all locations where TAP values would be are zero. Seems unlikely for a trans that was rebuilt in 2014 and approaching 70000 miles ago.
Is it possible the 2002 model years did not have the adaptive feature?
My 2005 Yukon was rebuilt 3 years ago and shows maybe a dozen cells where the pressures are backed off varying amounts from the standard model. I have another scan of this data from 2 years ago and can see the same cell pressures were backed off a little further back then so there is evidence one would expect to see as the trans wears.
I took pictures of all the TAP pressures and then reset them all to 0.
I've got a week to drive around and let it learn before I hook the trailer up for our vacation trip.
I'll pull the TAP pressures at the end of the week to see which ones have been adjusted with no load from the trailer and then I'll pull them again at the end of the trip.
Any other data I should collect?
TJ - anything I can do here that would give you data that would be useful?
You have any interest in trying to use Torque Pro to see your TAP pressure values? And what TAP Cell is current? As you have seen with the Tech 2 there are a lot of pressure cells there. So it would take a bunch of screen room in Torque Pro.
As it turns out I believe I just worked out how to read these TAP pressure cell values. The behind the scenes details are thus: The Tech 2 reads these values from "data blocks" that are read with service $3C. We can also read them with Torque Pro. There are usually like 6 bytes in each data block though I have seen some with less.
I can whip up a file for import to Torque Pro in much the same way we import the "[GM]" PIDs there.
That would still leave having to place all those 'pids' onto Torque Pro dashboards, a tedious process for sure.
After the reset,,,, did you display ALL the cells and confirm they were at zero?? Did you have values specifically in cells 12 through 16 for either of the 1-2 or 2-3 adapts??
I ask this because I just explored this clearing of TAP with my Tech 2 and a 2005 PCM. From the Tech 2 screen there were no error messages in the clearing operation. However TAP cells 12 through 16 in both 1-2 and 2-3 adapts were NOT cleared. In my data log I can see the error. And if I displayed cells 12 through 16 the previous values were unchanged.
I tried using different year selections and all of the 2003 to 2005 years show the very same error and fail to clear cells 12 through 16.
Using 2006 did successfully clear the values even though 2006 uses a different PCM. The TAP clear Tech 2 function for 2006 uses a different method than the 2003 through 2005 years.
I suggest having a look at your TAP cells 12 through 16 in both the 1-2 adapts and 2-3 adapts.
Pics of data from before the reset
Pics of data after reset and driving around for a week but with no trailer/load on.
Fist of all, I don't see TAP cells 15 and 16, I also don't see cell 9 on the 2-3 screen
I checked after clearing them and I had all zeros after the reset.
My TechII is a knockoff
50 kPa = 7.25psi.
A lot of the 1-2 numbers didn't change very much, a few are a bit lower and a few are a bit higher. Cell 4 dropped from 53 to 4, 9 from 74 to 41 and 10 from 41 to 10. 6/7/8 all went up slightly. This is the shift where the band is engaged by the servo, maybe I need new springs in there? Maybe the new band hasn't bedded in yet?
The 2-3 numbers are sure a lot lower. I wonder if doing the Sonnax ream and sleeve of the PWM valve raised the pressure so that the TAP doesn't now have to turn it up to get a decent shift into third.
I now wish I could get a set of TAP data from a new 4l60e to see if my 1-2 numbers are a concern.
50 kPa = 7.25psi.
I need to sleep on this.
I explored a little more about the absent 2-3 TAP Cell 9 and found my Tech 2 (clone) also has this missing. I experimented with using other year selections and they also showed no 2-3 #9. But here it got really weird. I know the memory blocks where the TAP values are read by the Tech 2 and in the 2006 PCM I have there is a value for 2-3 TAP #9!! But the Tech 2 does not display it!! Why would a PCM update a TAP cell if it were not used?? Is it a possible bug in the Tech 2 not displaying this cell?
I'm just trying to interpret the numbers to see if they point to anything.
Having shift 1-2 still require extra pressure to get to it's optimum time, I think, tells me the servo isn't fast enough applying the band to get into second or the band is slipping?
I've purchased the OTC kit to monitor the pressure from the side port so this weekend I'll be doing the test with the Tech-II and the pressure gauge to see if the pressure responds correctly to the adjustments.
I'll also drain the fluid and drop the pan and look for any metal that may indicate I missed something.
If all is good I'll change the u-joints and take off on holiday.
I hooked up the 400PSI OTC pressure gauge to the service port today, it's a PIA. I had to drop the front propeller shaft and remove the cable and the electronic switchbox on the shaft to get to it. The hose barely fit but I got it in.
With the Tech II I was able to change the PWM signal to the EPC solenoid and read the resulting line pressure and sure enough all readings were in spec. At idle I was able to vary the line pressure from 62psi to 180psi in ten increments.
I'm happy with that, I think this trans is good to go.
Climbed through all the Rocky mountain passes without any problems!
We went through some small passes the first day then through Rogers Pass the second and then Kicking Horse Pass and Bow Pass the third. (5000-6000feet)
The trans shifted from 3-2-1 as we climbed with the periods in 1rst being brief spurts near the top of some long climbs. I don't think we slowed below 50km/30mph even on the steepest slopes. The engine temp stayed at 100C/212F even in first at 5000RPM so while it felt like we were screaming and about to explode we really weren't, we were not even close to max rpm and the engine temp was perfect. We spend most of the long climbs in 2nd at about 3500rpm.
I've also learned that when you tow in 3rd the overrun clutch is engaged in every gear so the downhill slopes were easy to do with minimal braking required.
I couldn't be happier with the result.
We're now out on the prairie heading north so it's easy going for a week or so before we need to cross back through mountains to get home.
What were the tranny temps like?
Mostly mid 60s C, about 140F?
I've got the transmission cooler installed in front of the radiator.
I'm still playing with torque pro to get readable data while I drive. The dials are too hard to read on the fly (6 to a phone screen). I'm t
I usually use dials with a digital readout on the middle or straight up digital.
That's excellent temps especially while towing.
This is an area where the Car Scanner ELM OBD2 app shines. Enable data recording and then just select what you want to see when you start out, display it on a single combined graph and it will record all that you have selected and you can review the data later and keep your eyes on the road. The graphing is built right into the App.
I reconfigured one of the screens to have coolant temp and trans fluid temp as digital readouts with a large graph style box for the O2 sensor yesterday. This worked well as I can read it at a glance and the big graph is easy to see.
One mistake is that I thought my trans fluid was running around 60C but in fact it's about 80C/196F. I think that's still pretty good when towing 5000 lbs.
Well, I'm at it again. Spent the last two weekends in the garage rebuilding my other 4L60E.
There is a higher confidence on this one but at the same time there is a lot I didn't retain and have to look up or watch again. In particular remembering which way those slim bearings go on and making sure I didn't forget any o-rings. I also haven't memorized the plate orders yet.
No new tools required now, I have everything I need from the first time.
I bought all of my parts and kits separately on the internet this time and saved a few hundred dollars over the all-in-one kit I got from the local place last time. It also allowed me to get better quality parts.
Here's what I'm replacing this time:
Frictions and steels
Wide band
Molded pistons
ALL of the bushings
Full gasket set, paper and o-rings
Sonnax TCC and isolator valve sleeve fixes (I have the reamers)
Repaired the valve body plate holes with hardened seat kit.
Replaced all the steel balls with Torlon balls
Replaced the valve body end caps with the Sonnax ones with o-rings.
The valve body will be fully vac tested before I bolt it down using a tool similar to the Sonnax test rig.
So far So good.
Here is the Sonnax fix laid out for installation. The top grey valve is the OEM, all the shiny stuff below it with the blue spring is the new Sonnax replacement valves.
Once I had the valve plate removed and cleaned up I found three of the balls had hammered on it hard enough to crater the hole.
I was able to clean up and smooth out the other holes and then these three were drilled out to 1/4" and the insert just goes in and is held by a c-clip. Pretty simple and a $10 solution for a $75 plate.
All that's left now is to vac test the valve body and install it then put the pan and bell housing back on.
This transmission never actually failed, it was removed at high mileage when I had a rebuilt to install but it was fully functional at removal.
Since it was never let go until failure there were no filings or metal in the pan or fluid so I'm going to just re-use the TC. I'll do my best to drain it and clean it out with a swish of mineral spirits but that's all. I don't see a reason to spend $400 when it never failed or was subjected to any filings.
I'll have to keep this in mind, knowing the transmission is only good for about 250k it will be a big money saver to pull it early and not have any hard part failures or have to replace the TC, that's a big savings over running it an extra 10-20k and having it fail and fill the fluid with little shiny bits.
Just a "keep this in mind" kinda statement .....
I have had transmissions that broke simple things like a snap ring or an output shaft that didn't "metal-out" the whole cooling system either - but the heat exchanger still had some restriction from normally occurring friction material collected in them and some of what I called: "rubber slag" from deteriorated seals and o-rings.
I always used some flush through the heat exchanger, forcing it in the wrong way, to remove what it could to give it better flow.
I never regretted at least trying it - but it didn't always work 100%.
Good advice - Thanks!
I've got this aluminum container with an air nozzel and a spray gun on a short hose from my air conditioning tool kit. I can fill it with whatever I want and then use my shop air to push it through whatever I want to clean. I use it to flush out condensors and evaporators.
I could take it and flush a quart of mineral spirits backwards through the heat exchanger while the transmission is out. If you catch it all in a clean bucket it's easy to see if there was anything that needed cleaning out or not.
It can't hurt.
Kdew02
