Fist of all, I don't see TAP cells 15 and 16, I also don't see cell 9 on the 2-3 screen
I checked after clearing them and I had all zeros after the reset.
My TechII is a knockoff
50 kPa = 7.25psi.
A lot of the 1-2 numbers didn't change very much, a few are a bit lower and a few are a bit higher. Cell 4 dropped from 53 to 4, 9 from 74 to 41 and 10 from 41 to 10. 6/7/8 all went up slightly. This is the shift where the band is engaged by the servo, maybe I need new springs in there? Maybe the new band hasn't bedded in yet?
The 2-3 numbers are sure a lot lower. I wonder if doing the Sonnax ream and sleeve of the PWM valve raised the pressure so that the TAP doesn't now have to turn it up to get a decent shift into third.
I now wish I could get a set of TAP data from a new 4l60e to see if my 1-2 numbers are a concern.
