- Joined
- Dec 12, 2011
- Posts
- 4,687
Something else is there's a 180 deg bend off the manifold, the pressure difference on each side of the turbo is a key factor but I haven't spent time with that portion, that's why I think freeing up the exhaust after the cat will compensate for the 180 deg bend.
Edited to add, I'm thinking a 2.75 or 3" pipe off the cat to a Dynomax Ultra flow or a Borla XR-1 then one pipe routed to the stock location with or without a straight through resonator. Turbo's really quiet the exhaust by themselves so with your current dual-muffler, and added bends in both tailpipes may add a lot of restriction when under boost.
Of course it's easy to spend your money,
but just throwing out suggestions.
Too much commitment....but hey, we understand about the green meal. Sounds like it needs minor work, plus the trans but rest is almost cosmetic.
I have and will keep thinking it over...I just do not know how much more abuse it can take all around... being in grad school next summer+ however long that will be I do not have the funds to fix surprise problems that arise. I figured this would happen with the trans and really the engine needs an overhaul I think too just at its miles to be safe if I was going to re turbo it the right way.
