3D Printed Modificiations
Semborski
81
Just to tease you guys a little...
Getting close, just a couple final touches and dimensions.
Semborski
81
Now you know I to mark them up an extra 3% for my royalty fees, right?
Just 3%?! That means you gotta sell them :cool:
littleblazer
9,267
What program are you using? That reminds me of auto desk inventor, I used it in auto cad a couple of years ago in high school.
Semborski
81
You are right. It is autodesk inventor.
Reactions: littleblazer
Would take awhile to recoup my investment so far at only 3% so lets mark it up 30%. These guys will never know :wink:
Semborski
81
Well I wasn't gonna let these bad boys go for less than $15 a piece without $650 handling and another $900 shipping charge.
littleblazer
9,267
I'm willing to pay 2000 for shipping and handling, as long as the product costs $14.99.[emoji6]
Semborski
81
First print is just starting. Doesn't have all the final supports but just wanting something to see if the securing mechanism dimensions fit fine.
Semborski
81
First prototype. Looks pretty good to me. Need to add some supports to stiffen it up and get some thin rubber or foam. Does anyone know if the non rounded corners by the screw hole will be a problem or not?
littleblazer
9,267
I do not believe the rounded corners interfere, but a dremel will fix that if it is.
littleblazer
9,267
We need plastic lift kits. [emoji6]
Semborski
81
I was thinking this! I was planning to start that once I am done with my plastic brake pads.
littleblazer
9,267
Back to reality, for the foam, home Depot sells the window sealer, it's a type of single sided adhesive backed foam, but I believe it is the correct width for the door, if that will help.
Semborski
81
Semborski
81
Printing out the final draft now. 1 hour and 30 minute print time. Will have them ready to order sunday. Will probably start a new thread either tomorrow or tonight even with details and prices and what not.
littleblazer
9,267
I call firsties. [emoji13]
Reactions: Semborski
Mounce
13,667
Tuscaloosa, AL
Whoever gets the first one needs to be prepared to install it the day they get it so that Semborski will know if it works or if he needs to redesign it before he sells more.
littleblazer
9,267
True. I'll be at school and might not be able to.... I'll let someone else try. [emoji13]
Semborski
81
When I return Hardtrailz's donor he agreed to test fit one for me so that will be taken care off. I'm not cutting a hole in my car but i will mount it up to make sure it fits.
10,694
I was gonna say,no cutting would be necessary for a test fit. You'll have the lip for the door to insert into, and the screw mount. That's all you need. :thumbsup:
Semborski
81
Ok so with that project done. What's next? Gauge adapter? I have been doing a little side project for myself you guys might be interested in. I bought a 3/4" square aluminum tubing from menards and have been working on quick release fittings for our roof rail channels.
Will they be stronger than the 3/8 bolt n washer I currently employ to attach my crossbars?
dmanns67
32,979
There is a projector shroud that Aarkon and myself have been unable to purchase. No one on the interwebz sells them separately from the projectors. The only issue is trying to get one to you for reference. I know Aarkon is looking for at least three pairs of them.
The plastic will need to be able to handle high temperatures and be UV resistant as the shroud is only an inch or so away from the HID bulb. Not sure what options you have as far as plastics.
10,694
Trkdrvremt said:
Anyone know the screw size that goes in the door?
You talking about the metal ones that hold the handle to the door, or the plastic push pins that snap in around the perimeter?
Or the size for cabin filter door?
Reactions: Trkdrvremt
littleblazer
9,267
Cabin air filter door, if you mean that, is 5.5mm I believe. I guess use a self tapping screw with a hex head.
littleblazer
9,267
I used these in the Envoy. [emoji6]
1,490
Osceola,Ia
So a little thread hijack real quick.. Do car/truck coils get dirty with out the air filter? In my big truck I have 2 filters for the hvac.. One for fresh air and one for recirculate. I have to clean my ac coil out once a year bc of the dirt and dust that we run in gets by the filters. So I was just wondering if anyone without a filter has looked at their coils and seen if they get dirty and plugged up? Or if anyone has ever heard of the coils being plugged in a car/truck.
littleblazer
9,267
My dad's old 1999 c3500hd old body style sierra, the boxy one, used to plug all the time, on hi it moved as much air as level 1. He hosed it out and decayed leaves and sludge came out and flow was restored. On the newer vehicles the inlet is higher from the floor so it doesn't pick up the the Crap from the floor. So yes, they can plug up, at least I've heard of the old ones doing that anyway. [emoji106]
Dec 13, 2013
1,490
Osceola,Ia
Good to know. When my fan is about halfway to all the way up it sure vibrates the dash and it seems like there should be more air flow tha. What I have, so I guess I will check mine out this weekend then. I'm pretty sure I already have the door but I doubt a filter.
littleblazer
9,267
There's a waterless cleaner, he hose it out since it was rubber floors, the spray breaks it down, then just blow it out with compressed air. [emoji106]
crtaylor80
