Stewzer55
419
Drove it back and forth to work today, was a bit slick on the way in but not too bad.
4,050
Let me know what they quote for just the hood painting portion if you can. I have been looking a bit and all the quotes on painting the cowl hood seem high enough I may be doing a full spraypaint and some vinyl on it :wink:
Forget it mate. $1100 and change for an aftermarket (NOT OEM mind you) hood painted. Looks like I'm going the painted hood on ebay route for $495.
Reactions: HARDTRAILZ
redleg6
686
installed 2 new headlights and picked up a set of SS sway bars (front and back) for $25
next up, I need to order a new headlight header panel and get that LT front bumper with fogs
**if anyone has a set of Suspension Maxx end links (installed), please IM me, I have a question
-Sean
Reactions: mike_k and Capote
Stewzer55
419
Filled it up with gas, got 14MPG on the last tank, short trips and bad weather are a killer.
Capote
24,227
Atlanta, GA
Washed her, haven't had a chance in like 3 weeks -__- ....
BC backroader
349
Had a shop install a new front hub for me today, while I was at work. The mechanic told me he replaced the one that was noisy on his stethoscope, but that the other should be done soon, as well. Sure enough, I can still hear a faint rumble from the front. He also spotted a wonky UBJ on the right, so I'll have to replace both when I get the lift installed. I'm trying to save for the lift, but the rear brake job on my K3500 and the new TB hub have eaten that money for this month, so the lift waits, again.
Drove it to work.
BlazingTrails
19,409
Sunday - finally had time to hook up HP tuners and set it for the 4.10 gears. Tuned out sais, and the radiator fan. Ordered electric fans and I will do a writeup on that. Worked on the shift points and pressures a bit and did some butt dyno adjustments. She's running good boys.
Hopefully soon I can get it on a dyno and do some more tuning and post some numbers.
BC backroader
349
smt59, link for the brakes?
After work, drove the TB over to KMS Tools to grab a few pics with their old Chev duallie and LaFrance fire truck for the photo contest
10,798
A little fan action last night :smile:
:undecided: You going with a pair of 12"s? Looking forward to seeing some warm weather temp readings with those.
Left it in the garage since we did not get too much snow.
Capote
24,227
Atlanta, GA
Test fit it into a storage unit
68impalacp
37
Ordered Markmc's 3" front lift to upgrade from my 2.5" I have now. And got a new set of tires put on it. 35x12.50r15s BF Goodrich A/ts had to take each tire in individually the tire shop wouldn't touch it because it had adapters. So I took each one off one at a time in the lot across from their shop and did it that way. I've got a little rubbing that will be taken care of tomorrow right after work.
littleblazer
9,268
Did some donuts in the parking lot on the ice. (So far the power steering pump is okay) [emoji13]
rcam81
209
Onsted, MI
Just ordered an AAM splined disconnect off Ebay for $230.00 with free shipping.
Tried to change my one license plate LED but the screws that hold the lenses on are rusted so bad that I can't get them out. I'm going to have to pull the whole license plate pocket off the truck to get to the sockets.
Well, one bulb still works, so screw it I'm not taking that all apart right now.
BC backroader
349
Made an appointment at a stealership for TC drain and fill, as I have no idea if mine was ever done in the 9 years before I bought it.
Sir ffeJ
543
Got rid of the turbo sound by changing the idler pulley. Then had a chirping sound afterwards. So I changed the belt and all is nice and quite now. Ahhhh
redleg6
686
Odometer went over 200K this morning on the way in to work (of course this is on its 2nd engine).
Envoy_04
749
Yesterday, cruised in it with the windows down. Today, driving it in the rain. Gotta clean it soon, the inside looks like a pig pen! :frown:
10,798
Just drained about 20oz of oil from it. After talking with Angel a couple weeks ago about an odd phenomenon where doing an oil change and only 6 quarts showed as full on the dipstick... And I've had an odd idling issue since my last change, plus that phantom stall out in traffic 2 weekends ago, I decided to make use of the quick valve I installed, and drain a little oil at a time while checking the readings.
Apparently I have the same issue, and blindly dumping in 7 quarts cuz the manual says so, was too much, as my dipstick still reads full. I probably could have drained a little more, but didn't want to lug out my jack to raise the front end enough to stand the oil bottle upright. I'll see how the truck drives (and idles) over the next couple of days, continue to monitor the level.
Capote
24,227
Atlanta, GA
Installed New idler pulley & belt tensioner
Monday it got new diff fluid and TC fluid and a hub. Today it got some lower control arms ordered for it since the bushings are basically shot up front.
Capote
24,227
Atlanta, GA
Used it as a U-Haul again [emoji21] so tired of moving crap, but this is the cleanest & newest Stop N' Stor facility in Hinesville and the farthest from my place
EMT
20
Columbia, MD
I removed the headlights, headlight mount, front bumper cover, front passenger door, fender, fender liner, and had to take the side skirt partially off...
should be pieced back together tomorrow with parts that aren't damaged
Darkrider_LS
9,332
Bought some spare parts and 34" tires for the Diesel.
littleblazer
9,268
Cleaned it and replaced the brake fluid. Pedal is a little firmer now.
Indymastertech
