New rear shocks in and truck feels so much better
Reactions: High Voltage
10,797
Aarkon said:
Where did you run the wires for the signal? Do you think maybe it got pinched
Though the trailer hitch, inside a piece of loom behind the bumper to the passenger taillight, into the truck through the taillight rubber grommet. The power and video cables are about a foot long, no visible damage, although there was nothing moving that could damage them. Chalking it up to being a $30 camera I guess.
I didn't like the wide angle lens for my application. Being mounted in the trailer hitch, I never had a visual reference to the truck so the positioning of things off to the side was always skewed. :mad:
BHAMER
268
Your truck licks SICK Blazing, love it :thumbsup: Tinted the windows yesterday, hoping to get some other mods done this weekend!
Hatchet
2,405
I have to change the driver side upper control arm, could only get the passenger done since i broke a bolt. then wash off all the red paint from work. Finally pack everything up and load up the truck for the weekend at jamboree with friends.
10,797
3" front 4" rear. Once I removed the spare wheel and associated hardware the rear came back up 1"......trying to decide if I want to drop the back down lower....
Me likey, are those stock diameter tires. Don't think I could handle dropping mine that low though. Maybe a 2"/3" max, and keep some slightly taller tires. I don't fear speed bumps much, and think I would end up moving exhaust mods to a higher priority spot on my mod list if I went that low. :banghead:
BlazingTrails
19,409
They are stock diameter @ 265/40-22". I have no problems ever with scrubbing not even when turning or going over speed bumps.
Reactions: Blckshdw and BHAMER
Capote
24,227
Atlanta, GA
Changed oil & replaced oil filter
Capote
24,227
Atlanta, GA
Also need to do that myself.
:yes:
What oil & filter do you like to use?
Capote
24,227
Atlanta, GA
Valvoline and Fram normally.. Ditching the Fram for an ACDelco since I found out that Fram is junk and Walmart has them cheaper than Fram.
I use Castrol GTX High Mileage & K&N Wrench off filters
GrizzlyDippah
182
Picked up my flywheel bolts and dropped the motor in! Can't wait til tomorrow so I can finish(no garage :sadcry: ) installing it. Will post pics when finished'
Capote
24,227
Atlanta, GA
Capote
24,227
Atlanta, GA
:iagree:
Driving it to work
Docks
