jsheahawk said:"Nope. I haven't seen it, Mom."
Jared
I put it right back where it was and nobody knows any better. Besides, I didn't want to get my shirt dirty.
Jared
ConeKilrAutoX said:DROVE IT AGAIN FINALLY !
welded in my Hooker Header Aerochamber 3" muffler and all 3" piping. redid the tip and ill post a sound clip in a little bit. Summer 22's are on too.
Seeing the side exit exhaust. Very nice.kjkim93 said:Just spent 190 dollars for brake pads, went with oe ac delco of of newgmparts.
dmanns67 said:You could have went with BrakeMotive's set of front and rear rotors and 8 ceramic brake pads for that price.
triz said:Did you get rotors with that at least and a reach a round?:wootwoot:
kjkim93 said:That's on the list for next time. I wanted to go with those, but during my spring break I'm going on a drive and I wasn't sure if I could get it fast enough. 2 day shipping so should be here Tuesday or Wednesday.
cstern71 said:Changed the transfer case fluid today. It was black with a green hue to it. Most of it is in the driveway now. It came out a lot faster than expected. I figured consistency would be about like motor oil, but I was wrong. I bought my tb 2.5 months ago, so I have no idea when it was done last. I'm right under 130k miles. The thing I'm a little curious about, one of my 2 bottles of auto trak 2 was a much darker blue than the other. The first one looked more like mouthwash and the second one looked like liquid smurf. Same part number on the bottles. Should I be concerned?
I also crawled under the rear diff to check out the fill and drain plugs (woo hoo 2003). Fill plug appeared to be completely fused to the casing, but I managed to get it loose with some pb blaster. Also something I noticed is a lot of guys say to use a 3/8 extension to open it. I found that it was a lot more likely to wobble and help round out the hole. Its hard to keep it straight while applying the force needed to turn the plug. I was able to stick the ratchet head directly into the plug and it worked perfectly.
AC Delco spark plugs should be arriving later today, so I've got another project coming up.
KNBlazer said:I recently replaced Rear Diff gasket and fluid, I first tightened the fill plug, just enough to break the seal, I then loosened it without a problem...
blazinlow89 said:Well I went ahead and stripped the Avalanche of its door moldings and most of the badging.
Mark20 said:Mechanic was swamped all week but finally got link welded on drivers seat. Too late to install so I put it in the front hall for the night
MAY03LT said:Was it one of the front links where they wrap around the shaft? If so, can you still move the seat? I'm worried that if I tack mine on, it will bond to the shaft.
blazinlow89 said:Ok here is a better day time pic. I have a few scratches from the removal process, but nothing a buffer won't take care of.
Mark20 said:Yes, front right of the seat. The link is already welded to the shaft at the factory. So any additional welding won't make things worse. The whole shaft rotates to move the links to adjust the seat front.
Edit:
Installed & verified front of seat is going up and down. Any additional welding to the shaft won't cause a problem. Just don't weld or jam the shaft to the frame.
mcsteven said:Will you be replacing or putting a name on it somewhere? As mentioned, good decision. Looks very clean.
blazinlow89 said:Thank you, nope. I removed the moldings and left the Avalanche logo, thought it looked funny like that so I removed the Avalanche and just left the GM emblem.
dmanns67 said:Finally got around to installing my B-Day present from the wife. Upgraded my 2ohm Alpine sub to 4ohm and wiring it to 2ohm. I can tell a huge difference in bass over the 2ohm.
Most likely going to be looking to sell my Alpine SWR-10D2 sub (Less than 1yr old).
