Over the last 2 days, still counts right?
Been a busy couple days. One of my friends hooked me up with some Nexen tires, then the place I took it to for mount and balance was trying to upsell me on everything the guy could think of lmao
Something look different?
Took off the running boards, got a little project before the a car show coming up.
Removed the top pads, used a razor blade to get down to bare plastic to shave the holes.
Plastic welded from the back, then the front.
Almost done with one side
Halfway there
Just needs a little plastic filler then sand and paint.
One of my friends going to finish up with the plastic filler, then spray them for me.
Today I concluded that all has been dry under the truck for 2 weeks now and went ahead an re-installed the skid plates. Prior to that I dropped 50lbs from the truck, I have driven for a year now without sway bars attached and decided that it was finally time to completely remove the front sway bar.
I also decided to get the back end up in the air and chase down a screech I have had for a couple weeks. There was a lot of mud and rock build up in the drivers side rotor. It looked like rocks were getting hung up on the emergency brake pad. I also went ahead and replaced the rear break pads, they were getting pretty low anyway. I did discover that one of the pins on the bracket that the caliper mounts to was frozen. After a few calls to the parts stores I discovered that I couldn't replace the bracket alone, they wanted to sell me the whole caliper with the bracket. Thankfully I happen to have a parts truck sitting on the side of the house so I cannibalized the bracket.
It took me 2 hours to take care of the drivers side, 15 minutes to change the passenger side. Grrrr what a PITA these trucks can be some times.
truck is running. had plugged the wrong wire into the vss sensor so the trans wouldn't shift. but the speedo still moved which was really weird. once i got it shifting, the shifts were later than they should have been due to the gearing in the 4l80 so I took the mph vs tps shift table from a 2500 truck and copied it over. shifts great now in part throttle but in WOT it will rev through the shift... gotta work on that... :undecided:
and FYI, if you think you can just solder an abs wire back together and it will work: it won't.
Back in the game
I never went down Ray. You never got me down Ray
Seafoamed Mat's truck....waiting to do the smoke show.....
I finally made the call to remove the PCMFORLESS tune. I had Second gear firmness but the shiftness was way too hard.
There was a very loud clunk between shifts and my heart dropped every time feeling as if was about to lose my transmission.
As much as I miss the power but not about to die for! I might go for another tune later but would send in my original PCM to avoid the mysterious security relearn process my TB has.
Since its a Japanese import TB I would need to take it to the dealership for the procedure. Needless to say my smooth transmission is back now but was pissed when a 07 LT was flashing his lights in my rear view so had to take the side bench since he has more ponies than my 03 lol
Mat's truck decided to throw a CEL....got the code read and it was a P0303, switched everything over to Cylinder 2 and waited...got a P0302 last night so we are switching out the coil pack.
I still don't have Phantom back, the guy painting it came down with the same flu/stomach bug that made me rush my daughter to the ER last night. He is spraying tomorrow and I will definitely have him back Wednesday, I'm not going to rush him, but I do miss my truck.
Fishhunter911 said:
New tires......
Cooper Zeon LTZ. Look nice.
Anyone have the A/T3 on a TB?
AV8ER said:
I would like to see what you do for a CB mount. I have not found anything I like so far.
Well I got the CB almost finished. Just got to string the coax.:biggrin: Here is what it looks like.....
Powder coated my air horns (145 db) to match my SS emblems.
my emblem
chin spoiler from a Tahoe
My keyless entry remote is a pos and broke so I fixed er up with some epoxy and little wire...
- took out stock fan
- installed 2 efans from my friends drift car build ( wrecked :no: )
- took out intake manifold, fuel rail, and I will be putting in my 80lb/hr injectors friday along with the 06 engine wiring harness and the 06 limequat tuned pcm
(a couple pics from today are in my 4.2 turbo build thread)
Midnight is an 06 Trailblazer LS with a 5.3 and 90k. Picked her up today. Traded in the grey ghost. Will be putting in my HID's this weekend, holding off on putting the stereo back in until I get a new sub amp and the adapter to keep onstar.
:wootwoot:
Getting Phantom back this afternoon!!! Then I'm going to shampoo the inside and do a pretty decent interior detailing. I have missed my truck so much! I am so excited to see him.
Man that took a while! I'm sure it's going to be well worth it though!
2 weeks, a week longer than expected but I rather have him have the truck for 2 weeks and do it right than for him to rush through it in a week and have the truck back in there being fixed.
I wish I was without my truck for only 2 weeks
After my cracked muffler caused the carpet to melt, I decided to install a fire extinguisher inside, mounted on seat bracket
:eek: I hope that's dirt, and not orange peel, that's making the reflection all blurry! :no: :sadcry:
more than likely it is the camera and my freezing hands lol
Edited- Yes it's orange peel, no biggy as it will be getting fixed, plus it STILL looks 10 times better than the peeling clear coat. It's pretty mild orange peel actually, and aside from it being annoying close up, it doesn't hurt anything. I'm not to concerned over it. :thumbsup:
fletch09 said:
Nice :thumbsup:
have fun keeping him clean, with spring coming.
think you need some black chrome rims to finish the new look off.:twocents:
Already shopping :biggrin:
Short Bus said:
Phantom looks much better!!!
Are you getting a lift to go with those? I like the Rock Stars, they would look great on Short Bus :yes:
Thank you!! And yes I'm planning to do Marks 2.5 this summer
Cool, Why not the 3"? If you need strut mounts that'll pay for the difference in price.
A guy I work with opened a sign shop, so I had him make this for me :smile: I couldn't wait for warmer weather to put it on.
Because at 4'9 I would be looking at a ladder or elevator to get in it lol
I'm sure you could jump the extra 1/2"
That depends....if i'm going to go big I might as well go BIG and do the 3" body with it :raspberry: but I can only imagine the turd I would get for that one though.
Voymom said:
That depends....if i'm going to go big I might as well go BIG and do the SAS :raspberry: but I can only imagine the turd I would get for that one though.
I fixed it for you, I don't know of a 'Voy on 35"+ tires yet, you might be able to break new ground :yes: (I'm good at spending other people's money for them :crazy:)
I want to spend some too :wink:
J0hnn0
