Capote
24,227
Atlanta, GA
[emoji14]ictures:
[emoji14]opcorn:
Data is too slow to upload. And it won't start over until the 15th..[emoji35]
I've tried to upload, but can't. Tomorrow I can hit up a place with WiFi. But so far David I've:
-Repainted Center console flat black with Duplicolor Vinyl & Fabric paint
-Did LED mods for a Bud's 2015 Civic SI
-Removed washer tank for more airflow to intake
-Installed a custom bracket for that eBay intake I modified
-Replaced CPAS
-Added a ton of engine bay dress up bolts and washers from SickSpeed
dmanns67
32,979
-Replaced CPAS
Did you see the functional ram air hood for sale on the TB fan club FB page, $450 and its already painted black.
How does removing the washer tank provide better air flow? Did you do the FWI?
Capote
24,227
Atlanta, GA
There is?! Dude can you PM me it dude? Well lol it looks that way....[emoji15] [emoji19] ...
FWI?
dmanns67
32,979
FWI?
Shared it to your FB page. Not sure how to get links off of the FB app.
FWI = Fender Well Intake.
Capote
24,227
Atlanta, GA
Oh I haven't been on Facebook in like a year and a half, don't use it and I don't even know the login and can't login because that account isn't registered with my new number
Nah its not a FWI, I don't think I'd go that route now because I feel it'd suck up a lot of water. If I lived in a more arid place possibly, but its too rainy around here
dmanns67
32,979
Strange. Then someone hacked your account and friend requested me a few months back.
I agree. FWIs are the worst idea for a DD. That hood for sale loks like the same one a member here has. Here is a pic of the one for sale.
Capote
24,227
Atlanta, GA
It was probably me, it just seems like it was longer than a few months back that used it, lol it'd be a one in a million shot someone random would friend you as me that didn't know you.
Yeah I'm familiar with that hood. I dunno about that one, I'm on the fence about that one. Next would just be an induction hood if I didn't get a ram air one.
Hopefully picking up that hood Saturday for Grimor.
littleblazer
9,270
So my friends dad says to me the other day: "You know? When I was following you the other day I said to myself "I wonder when he is going to put led's in his tail lights." Now if I'm not mistaken those have the circuit boards that it never made sense to me why they were there. And I'd imagine most of the screws are stuck in the housing correct?"
Me: Well actually, I just don't want to deal with the load resistors yet. But it is next on the list. (Screws are in fact stuck in the housing by the way.)
Gonna start shopping around this week...
Easy fix. Break/drill screw heads off. Use new screws on new housings. Since I got total LED housings (Came with the load resistors too) not just LED bulb retrofit that worked out great for me :biggrin:
littleblazer
9,270
My housings are pretty new, look perfect so I'd rather go the bulb retrofit route. And I like the look too.
Edit: might be able to get them off with a vice grip...
littleblazer
9,270
Rears are ck and fronts are regular correct? And 6 ohm 50 watt if I only want 2 load resistors? Mod bug bit today.
Sib
3,446
Correct on the CK bulbs. And if you only want 2 load resistors to remove hyper flash for fronts and back then it's 3ohm 50watt.
Fronts on 02 were CK I found out. Not sure about other years.
I thought all the rears were CK.
Boricua SS
3,080
Matt has an '02 and his fronts were CK as well. Just a fluke year/first year introduction of the vehicle
Reactions: littleblazer
littleblazer
9,270
My fronts are regular for certain. I checked. (Pats self on back) 3 ohm 50 watt load resistor and I believe all the rears are ck... I just watched may's video and his probing confirms both are ck.
Edit: and I thought there were issues with backfeeding using the different flasher module.
Edit2: turn signal seems to be non ck under further investigation... opposite ground not in line.
Capote
24,227
Atlanta, GA
I thought Brandon at one time said only the rear turns were.
Rear turns are the CK ones
littleblazer
9,270
This is what I came up with?
Boricua SS
3,080
Rear turns are not CK on mine, just the brake lights are.
...sigh.
GM WHY YOU DO THIS TO US?!?!
Reactions: Mounce and Capote
Capote
24,227
Atlanta, GA
...sigh.
Because bro lol
littleblazer
9,270
I'm going to play with my lights...
Edit, the directional socket (middle one?) Can be considered either way!
Capote
24,227
Atlanta, GA
I think I'm gonna convert my rear turns to 3157, there's like no options for 3157CK red LEDs
littleblazer
9,270
Think about it.
You have what appears to be either or, since only the high is used for the directional socket. Are we talking a bout the stop lamp? Lol then disrguard everything.
Mounce
13,667
Tuscaloosa, AL
If you're brave you can rewire a 3157 bulb to be ck. Just have to take the base off and move the wires to the correct locations. Or even easier, just flip one wire on each side from one side to the other, yeah that'd be a lot easier.
littleblazer
9,270
Don't the philips ones work both ways?
Capote
24,227
Atlanta, GA
littleblazer said:
Think about it.
Talking to me? I'm talking about rear turn signals
littleblazer
9,270
Then you don't? Need ck... I think.
Yes if you want to pay the price for them. I wouldn't, they're $20-30 a pair iirc.
But 12 year warranty yo. [emoji6]
Capote
24,227
Atlanta, GA
LB I know they are CK, I was thinking of making then non-CK
littleblazer
9,270
I'm lost now. Top socket = brake and running light. Middle = directional only right? If so according to my board either bulb type should work... but I've been wrong so many times with the electrical system on this truck that I should just quit now lol.
Capote
24,227
Atlanta, GA
Top and middle function as brake lights together, top is on with headlights, middle is brake and turn
littleblazer
9,270
So you have mods? Mine is top running and Brake and middle directional only...
dmanns67
32,979
You still looking for cloth SS seats, front and rear? A guy just posted on FB selling his SS seats for $300. He is down in Jupiter, Florida. Hell of a price, but not sure how far the drive would be for you.
Capote
24,227
Atlanta, GA
Thanks for the heads-up, you're rather great at that brother [emoji14]
But I am only interested in the leather SS seats, if it was leather I'd drive to pick em up at that price. Damn such a good price lol
danzt
