3m velcro tape works well too. Makes it easy for removal. I am a fan of simple zip ties. Holds ballasts and wires in place.
It's real cramped with the harness wiring considering I have two ballasts behind each headlight. I just need to unhook everything and properly ziptie it all up so it's not a mess
I have four ballasts as well and just let them sit on the sheet metal behind the headlight. I did have to use a lot of zip ties for the HIDs in my fogs. Tried to keep everything out of the way and dry, but its hard because of their location.
I have them sitting on the metal too,but the wires are getting in the way from me neatly arranging everything. Just gonna unhook the ballasts and wiring and the do it over
I wonder if you could wrap the ballasts for the fogs with something, then spray whatever you cover them in with "Never Wet"
There's no such thing as too much zipties [emoji41] mod rule #43 lol
SnowBlazer said:
Yup! Don't want the hassle of HID's. Having to wire, and position 'em. I'm more of a plug n play guy. :yes:
You think LED headlights are more pnp than HIDs? There is the EXACT amount of work to put either one in. All you need is the cap mod, an HID kit and a relay wiring harness and you're good to go.
Of course the relay wiring harness is optional..it's just highly recommended. And for $8(Ebay) it's cheap insurance.
I kinda been thinking bout trying Cree in the brights. My cheapo bulbs in them suck
Hopefully you don't have as much issue with them as most have, since you'll be using them just as your High Beams
Seems the issues are mostly solved.
Oh are they? Didn't know, last I heard there was still issues with them malfunctioning.
That is why I follow a couple threads on a couple forums. Knowledge is power.
After burning through 4 replacement Crees boards, Kevin sent me a new headlight and things have been great ever since (knock on wood)
Reactions: Mounce and Capote
I have industrial strength velcro holding my ballasts in place. 2 ballasts on the TB, 4 ballasts on the Camaro. Nothing has moved yet!
I zip tied my ballasts right behind the headlights. I'm still running stock high beams but I'm thinking about getting hids.
Same here
I've considered LED bulbs for my headlights, My lights flicker when my windows are being used,
I'm gonna have to see if I can buy a driver by itself from Kevin since I inadvertently let my good one go with the Tb...may try them out in the high beams of the Camry in the summer.
Anyone know anything about these high beam bulbs? They are led and do not require a driver. They are 2000 lumen. As soon as I get my hids delivered and installed I was just going to go with sylvania silver star ultra but couldn't find anything on their lumen output to compare.
They also make 880 led fogs that are plug and play and have 1200 lumen. Rather cheap mod without adding hids in the fogs.
http://m.ebay.com/itm/231292650700?cmd=VIDESC
I am not impressed with DT AutoTechs quality of their LEDs. I made a bulk order of (10) 194 LEDs and 8 of the 10 LEDs have failed. Their customer service did have me replacements out in the mail the next day, but that is after the fact. The 3157 LEDs I purchased are still doing well, but 80% of my 194s failed :no:
I was confused about the description, it says the drivers are water proof, but then it says no ballasts :undecided: Drivers are used with LEDs and ballasts are used with HIDs. You would have to have a driver to step up the voltage from 12v to 24v.
$70 is not a bad deal, but like I said I have not had any luck with DT AutoTechs 194 LEDs.
To be honest, if I did not already have my Cree LED headlights from Kevin, I would go with the Cree LED headlights from TRS. For $30 dollars more ($100 total), you get 3000 lumens, 5000k in color, and actual Cree chips. TRS offers a 2 year warranty as well. I believe DT AutoTech told me their warranty/return policy was 30 days. I did not see it listed though. TRS's link is below.
http://www.theretrofitsource.com/led-lighting/morimoto-xb-led-headlight-bulbs.html#.VKt1ep8o7qA
Reactions: Sib and Mounce
Hopefully it was just a bad batch of the 194s. I was going to order some of their 3157ck bulbs and their fog lights for now.
The front signals are not CK sockets are they?
It looks like they have a 30 day return if you don't open anything. At bottom of page it shows an image that says Full 1 Year warranty - I assume that is for any damaged products. TRS seems like the way to go though for the 9005s. $30 more and another year of warranty and an extra 1K of lumen seems like a good deal to me :yes:.
Ok thanks. Thought so but wanted to check before I started clicking pay pay pay.
Yeah I initially thought maybe a bad batch, until the replacements they have sent me have started to fail :no:
Like I said, the 3157 LED I bought from DT AutoTech has been going strong for 7 months without any issues (knock on wood). I would definitely avoid their 194 LEDs. All the ones that have failed overheated and either melted or burnt out.
Here is a pic of one of the two 194 amber LEDs that melted from DT AUtoTech :eek: I will definitely not be buying LEDs from the supplier anymore. I went with them because they were the only supplier at the time offering the 5630 chips. They are crazy bright compared to the 5050s.
Ouch. Was looking at 194 Amber leds today and say a few with 5630s. I wonder if that is too strong for those little things.
Could be possible. My 3157s have 5630 chips and they are fine. The festoon I bought for the cargo area are 5630 as well. Both are still doing fine.
Midnyteryder196 said:
All this talk of 5630... Got me thinking bout switching out my 5050 panels with these... http://pages.ebay.com/link/?nav=item.view&id=390617044350&alt=web
Those would be insanely bright. Too bad they come all the way from Hong Kong. I try to stick with US sellers.
I have seen a comparison between the 5050, 5630, and 5730 and the 5730s are brighter than the rest. When I was buying my LEDs 5630 was the brightest out at the time.
Not everything from sellers in China is bad... I found some sweet deals on 3mm & 5mm LEDs that were like 99 cents for a shitload. Yeah would of took like 2-2 1/2 weeks, but ehh it'd be worth it
Reactions: Midnyteryder196
Oh I know haha, only reason I paid $2.13 x2 for 50pcs of UV wide angle & 50pcs of Green wide angle 5mm LEDs. The bug was biting haaaard
Palmetto843
