What is the arm on the bottom of the strut called? Also what size of wrench is needed to tighten the lower bolt, I believe mine are loose. Also what's the wrench size needed for the upper control arms? I noticed the bolts have backed out a bit.
I think the bottom arm you're referring to are the Yokes. I posted a WTB Ad looking for a set of them:
http://gmtnation.com/forums/threads/2-strut-yokes.14377/
And yes, the bottom yoke bolt is 18mm.
