Onstar Mirror
Ilikemy3s
370
Hey everyone. I did a search and could not find an answer so I figured to post ..
I just purchased a 05 Trailblazer LT. I has OnStar with the buttons on the mirror. I just like the mirror I had in my 04 Envoy which had the auto dimming feature with clock and compass. Are the mirrors easy to swap as far as the connections? Has anyone swapped / upgraded thiers?
I swapped mine for compass from the 07 I had to my 06. Plugged right in.
10,685
:eek: Your mirror had a clock in it? That's new! Or did you mean temperature readout? :tongue:
And yes, like Kyle said, they are plug and play swapable. I did this mod as well.
Simon01
116
Yep, I have an 05 and just swapped the manual mirror with an autodim with compass and temp. I had to add the temp sensor, since I have an LS, but that was easy also.
Trkdrvremt
351
NJ
Where did you get the temp sensor from? Junkyard or was it a package deal?
Mounce
13,667
Tuscaloosa, AL
IIRC, it's like 5 bucks at the dealer. Google the subject and you'll see a thread or two on the OS that mention it, I think that's where I saw it said that they were cheap.
Reactions: Trkdrvremt
coolasice
1,019
Northern Maine
+1
If you don't want to cut/splice wires you will need the harness too and pins/seals for the connector along with some wire.
part numbers here:
http://forums.trailvoy.com/showthread.php?t=54154
Mynamesjeff
