I think the switch you're asking about is the low pressure A/C switch. It will kill the A/C if the freon gets too low.
If I remember correctly, it has a schrader valve on it, so you can change it without discharging the system.
It runs! Hahahahahaha.
Talk about a relief! No service engine light, either. No leaks so far. Got a miss on one cylinder, it feels like. Other than that, no issues whatsoever.
Well, except that the positive wire on the starter was touching the small wire and it tried to Crank when I hooked up the battery. Straightened that out, and cranked it 10 or 12 more times with the fuel pump relay and ign coil fuse removed. Replaced both and it cranked up immediately. Only thing missing is the hose going to the 2 ports on the intake. Other than that, I just need to reassemble the front end and drive it, I think.
