DJones
I removed the tail light circuit board, replaced the housing with aftermarket, and wired up sockets. This is because of the rusty, corroded connectors on the stock circuit boards. I cut what was left of the connector coming out of the body and used it to connect three new sockets on both sides. I wish I knew why circuit boards were installed OEM instead of sockets. The upper two bulbs are switchbacks from Autolumination, and the lower bulb is a 3157 18-LED tower bulb from SuperBrightLEDs.com. The housings are available from eBay seller 4caroption. The bulbs cost more than the housings.
Anomalies I noticed:
The red/white switchback allows for simultaneous operation of both red and white.
The red/white switchback is wired for standard sockets - soldering an additional wire solved the problem.
The sockets are wired for CK operation.
The installation direction of the amber/white switchback determined white-priority or amber-priority. (seen in video)
I will reinstall new Delphi connectors to allow use of the stock circuit boards if needed. I'll need both the male and female side, connectors available from Mouser. I'm using wire nuts right now.
The socket modified to fit the housing:
The circuit board opened, sockets removed, and cut for new sockets:
Socket attachment to the housing:
Installed:
Video:
[video=youtube;vOxf2BBkIgw]http://www.youtube.com/watch?v=vOxf2BBkIgw&feature=plcp&context=C4003023VDvjVQa1PpcFPXTT1qULtsTk9j5MFC2V5z EPmkirJnCQM=[/video]
Installed:
Video:
Very cool mod, had to watch the video a 2nd time just to make sure I knew what switchbacks went with which function
