DJones's Custom Tail Light Configuration
DJones
701
St. Petersburg, Florida
I removed the tail light circuit board, replaced the housing with aftermarket, and wired up sockets. This is because of the rusty, corroded connectors on the stock circuit boards. I cut what was left of the connector coming out of the body and used it to connect three new sockets on both sides. I wish I knew why circuit boards were installed OEM instead of sockets. The upper two bulbs are switchbacks from Autolumination, and the lower bulb is a 3157 18-LED tower bulb from SuperBrightLEDs.com. The housings are available from eBay seller 4caroption. The bulbs cost more than the housings.
Anomalies I noticed:
The red/white switchback allows for simultaneous operation of both red and white.
The red/white switchback is wired for standard sockets - soldering an additional wire solved the problem.
The sockets are wired for CK operation.
The installation direction of the amber/white switchback determined white-priority or amber-priority. (seen in video)
I will reinstall new Delphi connectors to allow use of the stock circuit boards if needed. I'll need both the male and female side, connectors available from Mouser. I'm using wire nuts right now. :lipsrsealed:
The socket modified to fit the housing:
The circuit board opened, sockets removed, and cut for new sockets:
Socket attachment to the housing:
Installed:
Video:
[video=youtube;vOxf2BBkIgw]http://www.youtube.com/watch?v=vOxf2BBkIgw&feature=plcp&context=C4003023VDvjVQa1PpcFPXTT1qULtsTk9j5MFC2V5z EPmkirJnCQM=[/video]
SBUBandit
597
I'd like mine wired differently, but I love the sockets in place of the board, that would allow me to do what i want. Are the bases of the sockets just pinched between the housing and the board to hold the sockets in? Did you use the rubber rings to seal them?
DJones
701
That is correct on both. It should also be noted that longer screws should be used to attach the board to the housing because of it.
SBUBandit
597
Very nice. Anyone got some old boards that maybe they gutted the pieces out of or stopped working that i can modify?
kardain
557
Very nice concept indeed.
10,685
:goodpost: Very cool mod, had to watch the video a 2nd time just to make sure I knew what switchbacks went with which function :biggrin: :cool:
SBUBandit
597
Seems like you could have even just left off half the board, the half you cut the square holes in. The difference in thickness caused by the new sockets would have been made up by the loss of half the board
In fact, then you'd only be using the lid where the circuit isn't anyways, meaning no cutting necessary, and the old board would be still usable should you ever change your mind, just put its lid back on. If that's the case, I wouldn't need extras, cause if the boss doesn't like it I can reverse it easily
DJones
701
I need to flip the middle switchback on the right because it has white priority. I never use the turn signal while backing up, but for consistency.
The problem with using just the front half of the board was support. It's just a flat peice of plastic that bends easily. And there are no screw holes on the sides of the middle bulb.
SBUBandit
597
Gotcha. So the theory would work as I thought but be weak and a little too flexy. I may pop mine off and make a template and cut one a little stronger out of Lexan or some metal.
Feb 16, 2012
202
Bringing this thread back up, I NEED a set of clear tails like this!!! I would prefer not all chrome, but I would take whatever I can get nowadays! I checked the seller the OP had listed, and no such luck.
If anyone has any insight or leads on a set, PLEASE let me know!!
Nice job to OP!!
ready67
