I am currently looking at buying a 2005 GMC Yukon Denali.. Couple Questions.. The build sheet is below.
Why are most Denali trucks built without a G80?
Does this truck have AFM/DOD? Its an LQ4. If I am reading this right...
This is the first time I have ever seen a AL4 suspension (firm ride), are we talking about different spring rates only then?
I like the truck the truck a lot, but there are good and bad.
69k miles
11k price tag
Some aftermarket Kenwood headunit that would get swapped out for a factory unit
Rims - I hate
Tires - I really hate
Interior is clean as a pin
Exterior has some of the standard, for Colorado, hail dings
Clear Bra is peeling
Looks to have some K&N intake tube and filter on it, but its just hanging where the intake bucket is supposed to be, would need to be replaced for factory I think.
No oil, tranny, diff, or anything, leaking
Heater isnt working (dealer is going to get that fixed)
Floor vent is not working
Thought? Opinions?
https://www.onallcylinders.com/wp-content/uploads/2018/04/05/LS-LT-Reference-Guide-Summit-Racing.pdf
... Its a 24x engine, which I think means no AFM/DOD. But I dont know this for sure.This is the first time I have ever seen a AL4 suspension (firm ride), are we talking about different spring rates only then?
69k miles
11k price tag
Rims - I hate
Thought? Opinions?
922 | TRIM COMBINATION LEATHER, PEWTER | 16U | PRIMARY COLOR EXTERIOR,PEARL WHITE |
1SF | PACKAGE OPTION 06 | 1SZ | DISCOUNT OPTION PACKAGE |
6XK | SPRING COMPTR SELECT FRT LH | 7XK | SPRING COMPTR SELECT FRT RH |
92I | INTERIOR TRIM SHALE/PEWTER | A31 | WINDOW POWER OPERATED, ALL DOORS |
AG1 | ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER | AG2 | ADJUSTER PASS ST POWER, MULTI-DIRECTIONALADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER |
AJ1 | WINDOW TINTED DEEP, ALL EXCEPT W/S AND DRS | AJ7 | RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT & SIDE |
AL0 | SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR | AL4 | SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR |
AN3 | SEAT FRT, INDIVIDUAL/NON-BKTSEAT,FRONT DRIVER,PASSENGER | AP9 | RESTRAINT CARGO |
AS3 | SEAT REAR UTILITY | AU0 | LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM)(USED WITH TROFEO SPORT COUPE WL3) |
AXP | VEHICLE TYPE MULTI-PURPOSE PASSENGER VEHICLE | B30 | FLOOR COVERING-CARPET STD |
B58 | COVERING FLOOR MAT, FRT & RR, CARPETED INSERT | BS1 | INSULATION,ACOUSTICAL(USED WITH SSE Y85) |
BVF | STEPS RUNNINGBOARD, SIDE, COLOR KEYED | BW2 | ORNAMENTATION,EXTERIOR,BRIGHT BODY SIDE MOLDING WITH DUAL BLACK ACCENT |
C25 | WASHER&WIPER-BACK WINDOW | C36 | HEATER,AUXILIARY |
C49 | DEFOGGER,REAR WINDOW,ELECTRIC | C5W | GVW RATING 7,000 LBS |
C69 | HVAC SYSTEM RR AIR CONDITIONER | CF5 | ROOF - SUN, GLASS, SLIDING, ELEC |
CJ2 | HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT | D07 | CONSOLE FRT COMPT, FLOOR, CUSTOM |
DF5 | MIRROR,OUTSIDE,REARVIEW,ELECTRIC REMOTE,THERMOMETER ILLUMINATED | DH6 | MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM) ILLUM S/S MIR(DH6) |
DK8 | CONSOLE ROOF INTERIOR, DELUXE | DL3 | MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED, POWER FOLDING |
E52 | DOORS,REAR WRAPAROUND(83 INCHES) | EVA | TEST DVT, EVAP EMISSION REQUIREMENT |
FK2 | ARM,TORSION BAR,SPRING ADJUST,LH | FK3 | ARM,TORSION BAR,SPRING ADJUST,RH |
G69 | LEVEL CONTROL AUTO, AIR, HD | GT4 | FINAL DRIVE RATIO - 3.73:1 (GM CODE) |
JAN | PLANT CODE - JANESVILLE, WI, BOC | JF4 | PEDALS ADJUSTABLE, POWER |
JH2 | BRAKE HYD POWER, DISC/DISC, 7,200 LBS | JL4 | CONTROL ACTIVE BRAKE |
K34 | CRUISE CONTROL AUTOMATIC, ELECTRONIC | K47 | AIR CLEANER HIGH CAPACITY |
KA6 | VACUUM SYSTEM,BELT DRIVEN | KC4 | COOLING SYSTEM,ENGINE OIL(EXPORT-IRAQ) |
KNP | COOLING SYSTEM,TRANSMISSION,HEAVY DUTY | KUP | THROTTLE CONTROL ELECTRONIC |
KW1 | GENERATOR,160 AMP | LQ4 | ENGINE GAS, 8 CYL, 6.0L, MFI |
M32 | TRANSMISSION AUTO 4 SPD, HMD, 4L65-E, ELECTRONIC, HD | N93 | WHEEL 17 X 7.5, ALUMINIUM |
NA1 | EMISSION SYSTEM,LESS THAN 8500 LB GVW | NP5 | STEERING WHEEL,LEATHER WRAPPED(USED WITH GRAN TOURING PKG Y56) |
NR3 | TRANSFER CASE ALL WHEEL DRIVE (AWD), OPEN DIFF, SINGLE SPEED | NU4 | EMISSION SYSTEM CALIFORNIA LEV2 PLUS |
PCJ | CONTROL SALES ITEM NO. 103 | PDC | CONTROL SALES ITEM NO. 120 |
QAN | TIRE ALL P265/70R17 BW R/PE ST TL AL2 113S | R4Y | TYRE BRAND - GOODYEAR |
R6J | SALES ITEM NO.10 - 8VK69 - 1GT | R9Z | CONTROL SALES ITEM NO. 100 |
SAF | LOCK SPARE TIRE, HOIST SHAFT | SLM | SALES PROCESSING STOCK ORDERS |
T74 | HEADLAMPS CONTROL AUTOMATIC, DELAY | T96 | LAMP,FRONT FOG(USED WITH DELUXE SPORT PKG W32) |
TFE | SALES INCENTIVE COMMITMENT PLUS | TL1 | GRILLE,SPECIAL |
U1S | PLAYER MULTIPLE COMPACT DISC | U2K | DIGITAL AUDIO SYSTEM S-BAND |
U42 | ENTERTAINMENT SYSTEM REAR SEAT | UG1 | OPENER GARAGE DOOR, UNIVERSAL |
UM8 | RADIO,AM/FM STEREO,TAPE,ETR | UQ7 | SPEAKER SYSTEM,6,DUAL INSTRUMENT PANEL,SAIL MOUNTED,STANDARD SPEAKER AND SUBWOOFER |
V1K | PLANT OPERATION BUICK SKYLARK LIMITED NAMEPLATE | V54 | LUGGAGE CARRIER ROOF, PAINTED |
V73 | VEHICLE STATEMENT US/CANADA | V76 | HOOK,FRONT TOW(EXPORT) |
VFF | VIDEO FORMAT REGION 1, NTSC | VK3 | LICENSE PLATE FRONT FRT MOUNTING PKG |
VR4 | TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) | VT4 | BUMPER,REAR,PAINTED,INCLUDES IMPACT STRIPS(DELUXE) |
VXS | LABEL COMPLETE VEHICLE | VZ2 | CALIBRATION- SPEEDOMETER(EXPORT) |
XAN | TIRE FRONT P265/70R17 BW R/PE ST TL AL2 113S | Y91 | LUXURY EDITION PACKAGEMERCHANDISED PKG LUXURY EDITION |
YAN | TIRE REAR 225/70R19.5 G 126/128 N BW TL CTL | YD3 | AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE |
YD6 | SPRING RR, BASE EQUIPMENT | YE9 | CONVENIENCE PKG COMFORT & DECOR LEVEL #3 |
YF5 | CALIFORNIA EMISSION CERTIFICATION | Z55 | TOP,REMOVABLE(LT SLATE-TEXTURED) |
Z82 | TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) | Z88 | GMC TRUCK |
ZNK | TIRE SPARE P245/75R16 BW R/PE ST TL ALS 109S | ZY1 | COLOR COMBINATION SOLID |
