BikeShoe
Hey there everyone. I’m a longtime lurker and first time poster. I’ve made many repairs with advice from this site.
So, the high side ball-valve port failed, and it is not coming loose. I’ve tried all methods (no heat), but the line itself won’t withstand the force needed to break the port free. I—and the mechanic—so far cannot locate another evap line.
Is removing this line to isolate the wrenches’ torque to just the valve and the line’s welded nut feasible? I’m thinking clamping a socket in a vise, put the port into it, and using an open-end wrench & breaker bar
to undo the nut (and entire tube assembly.)
This TB is the ride for my very elderly parents, and no AC cannot happen.
Redding, California fwiw.
Thanks.
Thanks.
or breaker bar. Using shims or washers to give the exact offset to ensure that only the top nut is being "torqued". Further, the picture appears to show a "flange" with a hole in it. Use the flange and bolt a wooden block (or other material... angle iron). Set this up to act as a "platform" for the box wrench to rest on. Then, use a clamp or some form of bolting / screws to anchor the box end wrench to the platform to prevent it from turning and thus holding the piping in one position during the exercise. Hopefully you get the idea and have some materials on hand. I hate when nuts and bolts don't co-operate....
