when you just bought a used truck and you know it will need tie rods and ball joints.
You accept that there will always be a streak from the rear windshield wiper.
You mod it to take a cabin air filter.
You somehow are missing a cupholder insert
When you get half way into working on your truck and you're one tool short, so you have a friend come bring you said tool.
No, just no....
That's every project...
When you do a brake job and the pedal still feels exactly the same.
Reactions: Redbeard and Capote
When you have a Vortec 5.7 and the first thing you think of with a rough idle is lower intake gaskets and a bad fuel injection spider :'(
When you can hear a starter from across a parking lot and know it's a GMT360 without even looking.
You're shocked you adjusted the parking brake right.
and you knew where to find that hidden magical lever.
There's a magic lever? I kept adjusting the star at the drum until it seemed good.
When you have used the antenna to release the shift lock :laugh:
When you carry a spare ignition switch and coil pack
Time for a revival!
You want to throat punch a GM engineer anytime you want to fix something.
When you're packing a breaker bar, bernzomatic propane torch, or some sort of penetrating fluid to remove the rear diff fill plug.
One says their brakes are soft while another says they're hard.
Reactions: hrddrv and Capote
Preaching to the choir on that one lol
When your window sweeps are really just sand traps.
It's easier and cheaper to tune crap out instead of actually fixing it.
You realize that even a Chevy truck drives better than Ford's best car, so you own both :D
Time for a revival!
When you have parts trucks as lawn ornaments.
you make bets on which stock speaker will go next.
When your rear wiper takes a single swipe across the rear window, without a human command, on a perfectly dry day and then shuts itself off.
Rise from the dead...
You know the "crank, no start" troubleshooting drill from memory.
and
You know what LS stands for.
You know more about your truck than the engineers that designed it.
When you have to explain to your friends why you need a body lift and why you can’t add more than three inches of suspension lift.
The fix for all issues is cleaning the throttle body and replacing the ignition switch.
You can watch the rockers on your Silverado/Sierra rust away faster than paint drying.
Duckman
