Shdwdrgn
- Joined
- Dec 4, 2011
- Posts
- 632
One thing that always bugged me about TV was the lack of any kind of quick-reference chart for the tire info. I have a chart I made some time back to compile the info I found at the time, perhaps this could be of use?
I've been trying to think of some way a chart could be linked to useful information, and I have an idea... Would it be possible to create 'hidden' sub-forums under the off-road section, using a tire chart as the starting point? So for instance, someone brings up a chart (using mine as an example), and they see that if they want to install 265/70-17's there may be some cutting involved. From here, they would click on the tire size, and it would take them to a forum that only discuses the 265/70-17 tire (lifts, wheel-spacers, body mods, and of course pictures).
I just noticed over the past year that this seems to be THE most common question that comes up in the off-road section, and since we're starting from scratch here, maybe this problem can be tackled before it becomes a problem?
* As a final note... THANK YOU for choosing a forum software that allows me to paste a block of fixed-width text! I was never able to do this on the old site.
Code:
| | *Wheel | Wider | Upper ball | Spring | Body | Cutting &
Tire size | Diameter | spacers | rims | joint mod | lift | lift | hammering
245/70-16 | 29.5" | | | | | |
255/70-16 | 30.1" | | | | | |
245/75-16 | 30.5" | | | | | |
265/70-16 | 30.6" | | | | | |
285/65-16 | 30.6" | ? | ? | | | |
255/75-16 | 31.1" | ? | | ? | | |
265/75-16 | 31.6" | X | | ? | ? | | ?
285/70-16 | 31.7" | X | ? | ? | X | | ?
285/75-16 | 32.8" | X | ? | X | X | ? | X
255/85-16 | 33.1" | X | | ? | X | | X
245/65-17 | 29.5" | | | | | |
255/65-17 | 30.1" | | | | | |
245/70-17 | 30.5" | | | | | |
265/65-17 | 30.6" | | | | | |
255/70-17 | 31.1" | ? | | ? | | |
245/75-17 | 31.5" | X | | ? | | | ?
265/70-17 | 31.6" | X | | ? | ? | | ?
255/75-17 | 32.1" | X | | X | X | | ?
265/75-17 | 32.6" | X | | X | X | | ?
305/65-17 | 32.6" | X | X | X | X | ? | X
285/70-17 | 32.7" | X | ? | X | X | ? | X
285/75-17 | 33.8" | X | ? | X | X | ? | X
305/70-17 | 33.8" | X | X | X | X | ? | X
* Using rims with an incorporated offset is preferred over using wheel spacers
? May require this mod, depending on the particular tire used
