You KNOW there's going to be a "will it fit" thread
Shdwdrgn
One thing that always bugged me about TV was the lack of any kind of quick-reference chart for the tire info. I have a chart I made some time back to compile the info I found at the time, perhaps this could be of use?
Code:
          |          | *Wheel  | Wider | Upper ball | Spring | Body | Cutting &
Tire size | Diameter | spacers | rims  | joint mod  |  lift  | lift | hammering
245/70-16 |  29.5"   |         |       |            |        |      |
255/70-16 |  30.1"   |         |       |            |        |      |
245/75-16 |  30.5"   |         |       |            |        |      |
265/70-16 |  30.6"   |         |       |            |        |      |
285/65-16 |  30.6"   |   ?     |   ?   |            |        |      |
255/75-16 |  31.1"   |   ?     |       |     ?      |        |      |
265/75-16 |  31.6"   |   X     |       |     ?      |   ?    |      |     ?
285/70-16 |  31.7"   |   X     |   ?   |     ?      |   X    |      |     ?
285/75-16 |  32.8"   |   X     |   ?   |     X      |   X    |  ?   |     X
255/85-16 |  33.1"   |   X     |       |     ?      |   X    |      |     X
245/65-17 |  29.5"   |         |       |            |        |      |
255/65-17 |  30.1"   |         |       |            |        |      |
245/70-17 |  30.5"   |         |       |            |        |      |
265/65-17 |  30.6"   |         |       |            |        |      |
255/70-17 |  31.1"   |   ?     |       |     ?      |        |      |
245/75-17 |  31.5"   |   X     |       |     ?      |        |      |     ?
265/70-17 |  31.6"   |   X     |       |     ?      |   ?    |      |     ?
255/75-17 |  32.1"   |   X     |       |     X      |   X    |      |     ?
265/75-17 |  32.6"   |   X     |       |     X      |   X    |      |     ?
305/65-17 |  32.6"   |   X     |   X   |     X      |   X    |  ?   |     X
285/70-17 |  32.7"   |   X     |   ?   |     X      |   X    |  ?   |     X
285/75-17 |  33.8"   |   X     |   ?   |     X      |   X    |  ?   |     X
305/70-17 |  33.8"   |   X     |   X   |     X      |   X    |  ?   |     X
* Using rims with an incorporated offset is preferred over using wheel spacers
? May require this mod, depending on the particular tire used
I've been trying to think of some way a chart could be linked to useful information, and I have an idea... Would it be possible to create 'hidden' sub-forums under the off-road section, using a tire chart as the starting point? So for instance, someone brings up a chart (using mine as an example), and they see that if they want to install 265/70-17's there may be some cutting involved. From here, they would click on the tire size, and it would take them to a forum that only discuses the 265/70-17 tire (lifts, wheel-spacers, body mods, and of course pictures).
I just noticed over the past year that this seems to be THE most common question that comes up in the off-road section, and since we're starting from scratch here, maybe this problem can be tackled before it becomes a problem?
* As a final note... THANK YOU for choosing a forum software that allows me to paste a block of fixed-width text! I was never able to do this on the old site.
ItsOnVoy
2,401
that bad man!! Shouldn't we add a will it fit chart with 18", 20", 22" etc? I mean I have seen many question on those on TV.
Ghoster
The chart is awesome! We are working on some FAQ sections to house things like this. :cool:
Shdwdrgn
Absolutely! My chart was just focusing on the stock wheel sizes available on my 2004 TB, but once a framework is in place for the different sizes, it would be easy to add more wheels as needed.
Another consideration might be to simply make sub-forums based on tire diameter, since for example the same information would apply to both a 265/75-16 and a 265/70-17.
Regulator
2,496
Nice chart, it should certainly help out a lot of people.
smitty5150
There are so many different options when it comes to this subject. From 15" to 24" wheels and then some. Tires up to 35", higher with solid axle suspension. It might be nice to start from square one and build a comprehensive list of everything needed for every possible combination. Answer every question and concern out of the gate. I lime the baseline you have going...
NORCAL SS
for 18-26 inch wheels i've done it i put it in the wheels section.
Wooluf1952
2,663
Milwaukee, Wisconsin
Perhaps in the Wheels & Tires forum. Offroading is only reasonably done with 16 or (less desirably) 17 rims.
So, 26", don't even ask? :rotfl:
NORCAL SS
for 26s look in my section ive done a few already.
:squint:
Ohh I like the new long selection of smileys on here :cool:
I truly have to differ on this. 17s are far more common for offroad rigs. Most tire testing is done on 17s and most stock trucks have 17s now. 16s are going the way of 15s. 16s work well because of our baby sized tires even with lifts.
What you really want to remember is to try and keep your rim diameter half of your tire diameter! Nothing wrong with 40's on 20's for a dual purpose rig.
JamesDowning said:
I thought we already had a well documented off-road tire chart: OffRoad TB - View topic - Lift/Tire Chart
:biggrin:
Agreed! Why reinvent the wheel.
Common wasn't what I was aiming for. When I'm aired down on rocks and sand, I like the 16's performance more than 17's. More sidewall to flex. If those were my only two choices, I'd run 16's. That's all I was saying.
But if you're buying new wheels like I was, I see no reason to run 17's over 16's.
If you mean it may be harder to locate new tires on the road if you have an unrepairable puncture, that may be right. Never researched it. But possible difficult field availability of "mission-specific sizes" like 235-85/16 was one of the many bullet points in my old "how do I choose a new tire" checklist.
That's what we got to work with. :yes:
GMT360 forum? Check. Offroad forum? Check. Discussion of 40's on 20's suitable here? I don't see it. :confused:
Thats what I would like to run with a SAS. It may not be all that far out there.
It would be SO COOL to have a section for SAS GMT360s with more than three trucks able to be discussed. :wootwoot: But something tells me that's more in the mission of ORTB than here. We gotta groom the noobs here first to get them salivating for a SAS.
Very true. Already saw someone here wanting to run 37s as his next set of tires...
fishsticks
433
If I'm committed enough to put 39.5"-42" tires on a rig there's no way I'm going to "dual purpose" that rig with 20" wheels.
The majority of true off road tires come in 15" wheel sizes. Sidewall is king. 15" wheels aren't coming on many newer vehicles, but there are tons of tires out there for them still.
I bought 17" wheels only because I planned on converting to EXT brakes.
jbones
658
From what I have been understanding off a will fit chart, and posts on the other TB forum The Ultimate 'Will it Fit' Chart? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum these are at the max, and over for a stock TB, unless spacers, hammering, lift, or other things are done. Just wondering did I misunderstand, or is this chart missing requirements for going to a 70, or even 265/65 on a stock TB?
jbones
658
Seems I spoke too soon, the other chart does not address those sizes:duh:
We should probably put a huge note in the first post what the THRESHOLD tire sizes are. At that size or below, you can get away cheaper than above. For the "no-mods please, just want larger tire" enthusiasts.
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
JamesDowning said:
30.5" diameter... that should be well known to everyone. :cool:
Mine must be the freak with the 30.8" well that is what they listed at.
Shdwdrgn
Maybe we could start some kind of combined chart and use color-coding to add in more information... For instance, tires in the green can be added without ANY other mods; tires in the yellow can be used with aftermarket wheel spacers and lift kits; tires in the red require more 'permanent' mods like flipping the UCAs and cutting the fenders for clearance.
Reactions: paul2005tb
I think it depends. 30.5" is the "safe" size that pretty much any should fit. Yours aren't that much bigger, and if the tread is slightly narrower it'll clear while another that is slightly wider won't clear.
Tire sizes are like jeans - three different sets, all the same size, yet one is too small, one is too big, and one is just right.
Shdwdrgn
OK folks, here's my contribution... I made an active table that merges the data from ORTB with my chart. This page allows you to select your wheel size and other options, then gives you the tire sizes available for that combination of choices. Hovering over the column names gives a more detailed description. Please be aware that this page uses javascript to update the view.
http://sourpuss.net/projects/vehicles/trailblazer/wheel_fit_chart.php
If anyone is interested in the code behind it, I use PHP to generate the table, with a tab-delineated flat text file holding the actual data, and a little CSS for the styling.
jham
1,334
Envoy/Trailblazer Wheel Fit Chart
:hail::goodpost: I really like the chart.
FYI I have 265/70/17's with Marks New style lift and I had to Trim inner fender wells and front bumper cover
fishsticks
433
Me likey! It seems to not be gathering the data from ORTB properly though.
I may steal the idea (but write my own code) for ORTB if you're not opposed to the idea.
Shdwdrgn
What is incorrect from the ORTB data? I actually started with that chart and added my own data, along with the ball-joint flag. The only thing that should be changed from the ORTB data is the order of the entries - I re-sorted them to be in order by tire diameter.
Feel free to use the idea. And if you don't want to reinvent the wheel, the source code is freely available as well.
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
LOL, if he is pulling data from the original tables at ORTB and you steal his idea for ORTB... How can he object if you are bringing it full circle?
Shdwdrgn
In this day of rampant stupidity, it wouldn't surprise me if someone complained that I stole their (patented) idea of using javascript to change the visible table rows.
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
LOL, I was kind of thinking the worst case of someone complaining about using their data that they posted on the sites.
wentzben
