What is a E-fan?
Ghost
Probably a n00b question. I searched the forum and haven't found my answer.
So, What is a E Fan ? What does it do and why would you have more rwhp ?
This question is based off a post i made on why when i am in park or N, when pedal to the metal is applied the engine doesn't have that zippy rumble... like race engine, keep in mind i know our engine is not a race engine but i had plenty of other vehicles that had no problem gulping gas and getting up to RPM. This is just a weird theroy that maybe the big giant fan attached to the front of my motor is causing the BOGing and that's why i asked what a E fan is...? does it replace the giant fan attached to the front of the motor?
side note: took off the air intake and checked the throttle body cleaned it and my engine just isn't touchy like i would expect.. :(
E-fan, shortened version of electronic fan. It replaces the belt driven fan. The minor increase in hp is not an increase in the sense of the word, but a reclamation of lost hp used to drive the belt fan.
An electronic temperature switch turns on the fan at a preconfigured temperature. Below the temp, the fan is off.
Our engines are limited to about 3K RPM's, by the PCM, while in Park or Neutral.
That limit can be removed with a tune.
Also, the fan is free wheeling until commanded by the PCM due to engine temp.
...and is not recommended. The P/N limit is there to prevent damage to the torque converter and/or trans internals.
... because kids used to love to get the RPM up to 6000 in Neutral and THEN drop it into gear and stress the hell out of the drivetrain to get 1/10 of a tire revolution of chirp out of them. GM wanted to reduce its warranty expenses, so they limit that path for abuse. They also limit the power you can get in other ways, (called torque management) and removing that restriction is one of the benefits of a PCM tune.
Not on all 360's. I have the 08 fanclutch which is when they went back to the thermodynamic and ditched the electro since it had so many problems.
Good catch. Although it is still still dependent on the engine temp. Just not the PCM.
Sorry ghost just kidding, You bring up a good point. Getting rid of that big glob of rotating mass GM calls a fan clutch assembly is on my to do list and I am going with an ELECTRIC fan.
1. HP increase however small it maybe
2.MPG increase
3. It cleans up the front of the motor making it easier to get to everything. No more BFH and BAW to remove fan clutch to change waterpump, lots easier to change belt and tensioners and so on.
2.MPG increase
Just curious why does pcmforless have such a large whp gain using there e-fan???
Btw ill make a video tommorow with me slamming on the gas pedal in part to show the serious bog/delay. Weird part if I am doing 50mph place in N engine revs to red line (awesome).
Why do you want to free spin the engine like that ? An above poster all ready stated that there is a rev limiter while in park.:crazy:
To show the delay...alright. ill forget about It.
Ill never Rev and drop in gear. That's really bad on Tranny.....
Its really hard on every thing but mainly the wallet.:cool:
I have done a fair amount of reading on here and THE OTHER SITE. PCM forless seems to be the place to go. They, from my understanding will get rid of the rev limiter for you also. Its on my list however I am going to have to have a switch to put it back in stock tuning because after I get done I know someone will want to borrow it. In fact I might make one and call it the kid switch.
You will need to have two seperate pcm's. Cant do a "switch" with a pcmforless tune.
The lady I been talking to at pcmforless said she cant remove the rev limiter, the best they can do is 4krpm.....+/-
It should be right here if they use HPTuners... oh and a correction is needed, 5100 rpm is the correct "not moving" limiter for 2004 w/ I6
Um, running the engine up to the rev limiter isn't the concern... It can be done for testing purposes like he was going to do. Occassional and incidental isn't going to hurt much, just don't bounce off the limiter for too long... It's the neutral drops that will cause more problems.
marshall@pcm said:
That's exactly the place to change it, but it just doesn't seem to take effect when we do it with HPTuners. :(
The governor can be eliminated right ? It sucks when it cuts off at 105mph....
....which you discovered on the track......right? :confused:
Yes siree
Mine is "disabled"... In fact, all 3 of my obd2 vehicles have no limiter... It can't be fully disabled, but set at a high enough value to where you will run out of gearing before the limit is reached.
PhillipEly3
