Well... Generically Speaking...
Regardless of the Engine Source of Manufacture ... The PCM-ECM needs to be assured that the Intake and Exhaust Camshaft Position Sensors are reading coincidental in
THEIR Positions
WITH the Crankshaft Position within the proper number of Degrees out of a 360 Radial (
Actually ...720 Degrees to cover All Four Strokes) with a Focus being on the Piston inside of the #1 Cylinder, when it is located
...Just BTDC (Before Top Dead Center).
If the Two
(or sometimes 4) Camshaft(s) are
OUT OF POSITION ...
AND the Valves have
NOT Completely Closed on the Compression Stroke...
AND if the Fuel Injectors Don't Spray at Just the Right Time ...
AND if the Spark Timing is Off TOO Much or
NOT happening JUST before the Piston is finishing its Fuel and Air
SQUEEZE... Then when the Spark Plug finally
FIRES, there will be an insufficient amount of Compression and Explosive Burn to develop enough
POWER to Force the Piston(s) down in their Proper 4 Stroke Sequence.
Here is the Hidden Danger...> S-t-r-e-t-c-h-e-d... Timing Chains
(or perhaps Slipped and Worn Timing Belts with Missing Cog Segments in some of the Subaru, Audi and Volkswagen Horizontal Engines) will cause such a
Serious Misalignment as to Risk a Very Catastrophic Result on what we call
"Interference Engines" and thus... The Motor Might
*GRENADE* (If the "Valves Kiss The Pistons"...) Then Uh-Oh.
THAT is an Expensive "BUY, BUY Motor" Problem (if you know what I mean... $$$).
But... Let's Diagnose What MIGHT Have Happened
BEFORE any such a Disaster Occurs:
After Obtaining a 2009 Factory VW OEM Service Shop Manual and if necessary, Changing out BOTH the Intake and Exhaust Camshaft (CPS) Sensors
FIRST, My Next Favorite Method to Investigate this possible problem is to
Use a Two Channel Oscilloscope as follows:
(1) Back Probe the Signal Wire on the Errant
(CPS) Camshaft Position Sensor on Channel 1 of the "O" Scope.
(2) Back Probe the Signal Wire of the
(CKP) Crankshaft Position Sensor on Channel 2 of the "O" Scope.
(3) With the Engine at Idle, Align the
(CPS) Square Wave Form up on the "O" Scope Screen such that the "Break"
(AKA - Top Dead Center Notch) in the
(CKP) Sine Wave Signal is in very close proximity to the (CPS) image On Screen. (Set your Scope *Trigger* on the Rising Edge of the
(CKP) so that the "Break" (Missing Two Teeth) is showing the TDC of the #1 Piston. Knowing this will allow you to check its Position by Degrees against a
"Known Good Crankshaft (Sine Wave) to Camshaft (Square Wave) Wave Form" ...
Which is probably available to you somewhere over on some other Volkswagen Repair Forum.
(4) The Tolerance for having
a ..."S-T-R-E-T-C-H-E-D" ... Timing Chain or a Slipped Timing Belt will be
TINY... like maybe 2-3 Degrees before the Motor is in REAL Danger of having the "Interference" Problems that will risk Engine Damage or Destruction.
(5) Just Know that in some of the GM and GMC Engines, they use a 58 Tooth Reluctor Wheel (60 -2) vs. a
(CKP) Sensor mounted in the Block that creates its OWN A/C Sine Wave as the Teeth of the Reluctor Wheel orbit around on the Crankshaft, right under the Magnetic Pick-Up of the
(CKP). This is arranged so that the #1 Cylinder has a "Break" in the regular Teeth and this represents 12 Degrees of movement due to the absence of Just Two Teeth.
Consider that the other individual (CKP) Sine Waves represent 6 Degrees of movement in the Radial if you Divide 360 Degrees by 60.
(6) Your Volkswagen may be using a Different Tooth Count on its Reluctor Wheel, but once you know what that is, You can just Divide
THAT number into 360 Degrees... so when You see that "Break" point on Screen... You will know WHERE TDC for the #1 Cylinder is...and make your on screen measurement differences versus WHERE the Camshaft Square Wave winds up and COUNT the number of
(CKP) Sine Waves in between to figure out if You have a Stretched Chain, Damaged or Failed Timing Chain or Belt Tensioner(s) or any Damaged Chain Guides inside the Motor.
(7) You MAY have to perform this same Test on the Intake AND Exhaust Camshafts if your Motor has TWO Camshaft Position Sensors.
(8) By comparing a
"Known Good (CPS) vs. (CKP) Wave Form" Image versus whatever the Oscilloscope Screen shows You...THIS will determine
(by Counting the EXTRA (CKP) Sine Waves) just How Far Off The Timing happens to be. If THIS exceeds the VW Engine Specs Limits... then you are in for a Major Repair by way of the Timing Chain Set Replacement Swap, which probably means replacing ALL of the associated Pulleys, Guides, Tensioners, Cogs, Chains (Belts?), etc. and of course... Please Know...
THIS is NOT a Trivial Repair.
(9) Please visit "Mechanical Mindset" over on his YouTube Channel, since as a "Brit" he has a LOT more experience with using and explaining Oscilloscopes when Diagnosing Foreign Makes and Models:
(10) I'm Sorry that this sort of stuff can become so very *Technical* ... But there is no other way to be as certain of Identifying THIS problem and at least now you have a Better Idea (Warts & All) of What the DIAGNOSTIC THINKING is behind using an Oscilloscope when so much is at stake.
