Transmission Cooler
RTTBLT1
512
Louisburg, KS
Looks like I have enough info for a purchase and install.
Also, I wanted to thank everyone for there input on this Thread. Special thanks for the pictures, those are always helpful! :thumbsup:
Mounce
13,667
Tuscaloosa, AL
Anybody running a Hayden 679? I'm eyeballing one now but not sure that it'll fit at 11x11 inches. Bout to go pull the grill and measure but just wanted to see if anyone else was using that particular one.
-just went and measured. Looks like it'll fit. Might need a hair of trimming but should fit.
Bow_Tied
453
London, ON
Maybe my Envoy is different but the opening on the driver's side was 11" wide and a hair more than 8" tall and that doesn't account for the protrusion around the hood latch area. I think you have a fair bit of trimming or have part of the cooler hidden. One thing you could do is delete those plastic side curtain that route air toward the rad instead of bypassing it.
Regardless, pre-plan your hose routing and cooler orientation. Although many seem to have no issue with different orientations, cooler ports pointing down is typically the least recommended orientation. Top port or side port with outlet at top orientations are most recommended.
vulcantoolman
