Needing some opinions ...my 06 envoy is revving jus a tad in first and second gear...sometimes it doesnt do it at all...tranny fluid is full...should i install a 1 and 2 solenoid and filter...or could it be someti g else
156,000Factory fluid? I'd change it / filter. When you drop / clean the pan, check for any metal shavings / fragments.
IIRC, you have to drop (or at least loosen) the valve body to replace solenoids, so I'd hold off on that, unless you're feeling up to it. They are relatively cheap, and easily replaced, FWIW.
Try shifting manually, and see if you get the same result. If you do, I'd lean against the solenoids. Finally, how many miles on the trans / truck?
Just brought it about a month ago...but im pretty sure it hasnt been touched....156,000what's the mileage and how is the condition of the fluid? Has the pan ever been dropped or fluid/filter ever been replaced?
156,000
