Towing mirrors
gmctodd
22
I just traded my openbow boat for a new pontoon boat. The pontoon is 8'6" wide and seeing around it is difficult. I know where I can get a set of the power extending mirrors that were on the 04-05 GMT 800 trucks. I'm sure they will bolt on the Envoy, but does anyone know if the power slide function will work? Didn't some Envoys have a power fold option for the mirrors? I'm hoping that the fold function can be used to extend them instead.If not, I am looking for suggestions for towing mirrors.
Thanks,
Todd
Jan 21, 2012
58
i used some manual extended mirrors off of 2000 chev 3/4 ton. But I had to make adapters to fit between the door and the mirror. bolt pattern was different and the size of the triangle part was different size.
CaptainXL
Thanks,
Todd
I use these for my 5000lb 30ft trailer. They work great. I can see all the way down the side of the trailer. Remember that these have dual mirrors on each side. I also have the single mirror ones but you can't see all the way down the side.
Reese Towpower 7034200 Dual View Clip-On Adjustable Towing Mirror ? Walmart.com
Kuchar09
Thanks,
Todd
If you want tow mirrors like on the 04-05 GMT 800 trucks they wont be a direct fit due to how the bolt on but I can show you what needs to be done! I have all the functions except for power extending since this was an expensive enough gamble its self. I've been meaning to do an article on how to install them but I keep forgetting but maybe today ill do it.
Here is how mine turned out! There are better pics in the link above.
Wishbone
343
I loved your mirrors when I saw them at Coldwater. This could be my next mod, so I'll be looking for that write up.... :smile:
Wishbone
343
And sure enough, this was my next mod. Thank you Kuchar09 for the inspiration!
Like previously posted, there are differences in the mounting holes of the Trailblazer and the Silverado, so it took about 45 minutes of monkeying around with a driill and a rotary tool to make it fit just right. So far I've only installed the passenger side mirror because we're going up north this weekend camping and I don't have the time to get the drivers side installed yet.
Also note, my original mirrors are NO power, NO blinkers, NO heat. Totally manual. Turns out there is NO wiring harness in the door for power mirrors, so I'm glad I opted for the manual towing mirrors as well. I would have been really bummed if I spent more for power mirrors then had no wiring to connect them up...
So here's the new mirrors collaped and extended
Compare the old mirror to the new one, collapsed and extended
From the back, collapsed and extended
The difference between the mounting leaves a small gap which I will be finding some rubber trim to make it look like factory again...
I like those!
kenmyfam
168
South West Ontario, Canada
Same as we use for our boat and travel trailer. No issues with them to date and a decent rear view when adjusted correctly. :smile:
Mynamesjeff
