taller tire on 17" wheel 2 wd Trailblazer
Can you snap a pic of the clearance for the others that may want to try that size...also the actual tire model and brand info?
Pittdawg
538
I ran 265-65-17 on mine and while it was extremely close to the ball joint I never experienced any rubbing. However, mine wore prematurely in the center because in my opinion 265 is a bit too wide for the stock 7 inch wheels. Not sure if the lower sidewall ratio will help or hurt that situation for the OP.
10,687
I'd venture to guess over-inflation. I've been running the same size tire for a couple years now, and don't have this issue on my EXT. :twocents:
Reactions: djthumper
I have 265/75/16 on my stock wheels and have not been wearing the centers.
Thats why I recommend a chalk test so you get even wear.
smt 59
Mine have about a 1/4" from the UBJ clearance with my oversized tires and have no issues at all and they look and perform great, Michelins A/T, I also have a minor lift on mine.
No Tyme
100
Monroe County Michigan
I need educated here... where is the clearance issue? Top edge of the tire or inner sidewall?
No Tyme
100
I am running 265 65R 17" on Rainier wheels. My Trailblazer is a 2 wheel drive if that makes a differance.
I would post a pic but constantly get error 10, and Photobucket has incorrect file extention... I have nothing but trouble with this site.
Mounce
13,667
Tuscaloosa, AL
What browser are you using? IE is known to have issues. I recommend Google Chrome.
But if you go look you'll see that the top of the steering knuckles (where the upper ball joints are) are close to the inner edge of the tire on the top. That's where the clearance issue is.
No Tyme
100
I am using Firefox on this site. Don't care for Google Chrome. I have Edge and Internet Explorer also but they suck real bad...
No Tyme
100
OK, I'll try this again.
Reactions: paul2005tb
FYI...2wd does not make a difference
Reactions: smt 59
paul2005tb
299
Massachusetts
If this pic is really taken from a tire that is a 265/65/17 (that is a 30.6in diam. tire) then it would seem that at least on his vehicle a 31.0 tire could fit.
No Tyme
100
Yep. I have also read that differant tire manufactures may have slightlyt wider tread area, but for me these fit with plenty of room. Bridgstone Duelar H/L 265 65R 17".
Fishermandude
