Hello! First my right rear window quit working. I checked the switch, and the left rear window worked fine with the right rear window switch. I then installed a new mechanism with the motor inside the right rear window, with no success. So, I quit using it. Now the left rear power window won't move either. I've checked all the fuses that seem like they could have something to do with the rear windows, but I don't see any other relay thing that seems related. I don't know how to correctly check for broken wiring between the truck body and the door. I did searches, and this seems to be a fairly common issue, but the wire checking language is pretty technical for me. Is there something I'm missing? Thank you in advance for any clarification or suggestions!
