Rear G80 fill plug replacement?
Maverickxeo
44
Alberta, Canada
So, I decided to check my rear diff fluid on my 04 Envoy - and the plug was stripped and very tight. I was able to get it out and check the fluid, and I was able to put it back in (for now), but I was wondering if anyone know of any part number for the plug, or if a universal one would work with the right thread (if one exists). I did find a listing on Rockauto, but the image makes it look plastic and appears to be physically different (mine is just a threaded plug - a pretty normal diff plug).
8,056
This is the Eaton/Spicer replacement..
I dont recommend the Dorman one that you can buy from your local parts stores. Its a softer metal, and will do what yours did.
Reactions: Matt and mrrsm
7,737
You can get a pipe plug with the square head at any hardware store. Same thread.
Reactions: Matt and TJBaker57
7,737
moscoreli
