A Few Things before we
"Roll Tape" on
@MAY03LT running though his Diagnostic Procedures for a P0340 Code:
(1)
ALWAYS Choose ACDelco OEM Replacement Parts over
ANY Other After-Market Brand:
(2) Even though Drew was unable to demonstrate what the Oscilloscope Screen was showing in "Real YT Time" as
"Three WIDE and Three NARROW Square Wave Patterns" to the Viewers... Trust Me... The
ONLY WAY to be able to see any Error happening at the
FAST "Rate of Change" the CPS Sensor and Computer perform during Square Wave Generation is to use either a Hantek Model# 1008C (8) Channel Oscilloscope...or a PICO-Scope Model# 2204A (2) Channel Oscilloscope connected to your Laptop Computer and viewing the
Errant Wave Forms that Drew Hand Draws Out On PAPER
after he sees the problem ON SCREEN.
(3) Recommended Homework:
You don't need a Huge Bag of Coins in order to obtain and use an Oscilloscope for performing In-Depth Wave Form Analysis in Automotive Applications on everything from Problematic Electronic Fuel Injection to obtaining accurate Compression Tests to Diagnose Internal Engine Conditions. HANTEK...
gmtnation.com
On With The Show...
Thanks to
@MAY03LT for this YouTube Video and HIS Screen Cap of a KNOWN GOOD CPS WAVE FORM after changing the OEM Bad CPS for a Brand New ACDelco CPS:
And in THIS arguably 'Better' Video... "The Car Doctor" actually performs THIS Exact Same Oscilloscope Diagnosis of the P0340 and P0172 Codes by showing you the By The Book, Step-By-Steps in How To DO This Examination.
Take Note that the SAME ERRANT CPS KNOWN "BAD" WAVE FORM Patterns Drew found and Documented are also present in Plain View in THESE KNOWN GOOD vs. KNOWN BAD CPS Wave Form Screen Caps:
KNOWN GOOD CPS WAVE FORMS:
KNOWN BAD CPS WAVE FORMS (Sets The P0340 Code):
Screen Caps taken from THIS Video:
A Decade after
@MAY03LT recorded his Video, EZ-2-USE Automotive Oscilloscopes have
FINALLY become Affordable!
