Lightly on the 'tightening' of those Intake Manifold Bolts here ...if you please... No more than 89" Lbs
(that's Inch Pounds NOT FOOT Pounds...) and mind the one fastener that is hidden behind that small Rubber "Elbow" Hose. The two lower Red Circles shown in
@TequilaWarrior 's Image show that the upper portion of that "Elbow" plugs right back into the IM... It's presence there allows for the Air Pressure from Piston Blow-By that can build up inside of the Lower Crankcase and allows this stuff to escape through a very tiny port machined into the Aluminum Engine Head.
That small Rubber Elbow Hose-pathway allows for the Blow By Gas to get vacuumed right back into the Air Column leading into the (6) Intake Ports, thereby satisfying the EPA Standards for capturing and minimizing the expulsion of Unburned Fuel and Partially Burned Noxious Fumes out into the Atmosphere and get that stuff "Re-Cycled" right back into the Combustion Chambers.
I will admit that seeing a single small hose that gets routed FROM the Body of the IM ...right back TO the IM is bit puzzling to behold.
As for the White Smoke...
If enough Coolant invades into the Crankcase.... it can raise the Oil Level higher than it should be, naturally because the Specific Gravity of Oil is much less than Water. If the stuff can reach the Rotating Assembly down there...it will get picked up by the Crankshaft Counter-Weights and churned into a substance that looks like Brown Pudding. But worse yet is the insidious Chemistry when the Poly-Ethylene-Glycol is ACIDIC and it will eat into the Babbitt Bearings and cause the Crankshaft to Seize.
That stuff has absolutely NO Lubrication Properties and under extreme conditions at higher RPM...can literally ...Get Whipped into a Brown, Bubbly Froth. When that happens... the Froth can NOT be ingested and squeezed by the Gerotor Oil Pump and pressurized to lubricate anything inside of the Engine. The Oil Pump fails due to Cavitation. After these events happen... its Bye-Bye Motor.
Usually... this problem can be discovered by opening up the Radiator and looking for the Brown Pudding under the Oil Cap. Also... if you pull the Dipstick and your Oil Level is about twice as high on the stick as it should be... then you would suspect a seriously Blown Head Gasket. THIS is just how bad the problem can get:
