I'm drink idk
I can tell lol. And Aarkon, he has tails from a old body suburban that's supposed to fit the blazer and he wants to LED retrofit them.
Aarkon said:
Im giving him free parts
Your the man.
Hey man I dont think the gatlings are going to work with the matxhbox. I have one projector mounted in the fog, but the way the shroud flairs up and out on the projector, the shroud will not clear the fog light lens. Need to get my hands on some eyelid shrouds I guess.
What year suburban I had an 86 c10 and those are way to small
Your the man.
No sir the way I mounted the shrouds is you have to dremel the inside lip out to the main supports so it can slid over the entire projector then cut around the entire base until you have the perfect fit those mounting screws should go in the garbage
Chodr
Good deal. I was contemplating going that route. I think I will need to order another new gatling, mine is pretty hacked up from test fitting. Problem is looking on TRS's site, I did not see the shrouds offered for the matchbox.
I thought you said you had the eyelids and never tried the gatlings.
Sorry man the micro gattlings are impossible to get a hold of trust me ive tried you have to buy a hole new set of projectors to get another set of shrouds
The mounting is the same though the only reason I hate the eyelids is the upper peice protrudes out and has to be cut off text me a pic of yours
Yo
Gotcha. I got a little carried away with the free hand dremeling. I think the next one I will make a card board template of the bowl outline and trace it on to the fog light.
I also had to bore out the mounting holes on the projector to fit the 4mm bolts. I could not find any 3mm stainless steel bolts, not a huge deal though.
[emoji487]
Night
If you were closer I'd help you build some.
Got talents? Work for hire? Let me check out pricing for lamps and projectors, but PM me if you might have an interest.
CaptainKD said:
Nice recover Porkins. :thumbsup:
I have three tires that are consistently losing air in the cold weather. The soapy water trick didn't help. I replaced the Schrader valves yesterday. This morning one tire was down to 10 PSI but I found the valve was loose also. Probably my fault. Those things seem so delicate I didn't want to over tighten and mess it up. After work will be the test because my truck sits outside for 8 hours.
Replace the valve stems. They crack from cold and if you get water in them it's even worse. Unless you really need longer ones, get the shorties. If you do it yourself it also reseats the tires, so you can blow out any debris that might be allowing hairline spaces between rim and tire bead. You'll need some higher pressure to reseat the bead. Avoid moving the tire since so you keep the tire/wheel balanced as much as you can.
swede said:
Hey Swede - what's your time zone compared to Greenwich? If I remember you guys are just +1 or +2 from GMT.... Is that right? I'm in California, USA so I'm GMT -8 (PST, GMT -7 for daylight time)
SnowBlazer said:
Do you guys just put mid grade in your TBs? I put premium in because it's the same price as mid grade at Costco.
87. They don't have midgrade at my Costco, just 87 and 91. No need to up it unless it calls for it. There is no benefit to it.
Tom cruise is a chode
True story
I guess you don't realize that you're not supposed to double post...us regular whores tend to get in trouble if we do it.
I'm sorry I didn't know that and it wont happen again, I'll stand in the corner with my stupid hat on for the rest of the day ok Mounce?
Here I Wake up after a good night sleep and find 145 notifications, wtf guys? It's gonna take me all day to read them all, I wont have any time to be your fellow whore today ;-)
Just wait for those nights where we post every second...you'll wake up to a lot more than 145 haha
Reactions: Mounce and swede
I don't remember exactly how, but you can turn off notifications for individual forums. I would turn it off for any of the whoring or games forums. Tech of course leave on, but no need for whore replies.
145? I have about 250 every couple of hours. It stops at 250.
Reactions: swede
Whore on
We are at +1 but also have Daylight saving time so right now we are at +2
Reactions: mcsteven
No big deal, you're new. And okay, sounds good, make sure your nose is touching the wall.
I rarely look at my notifications anymore. If you have tapatalk, turn them off and read every post and you won't miss a thing, that's what I do.
Reactions: swede
90 just 10 more and I'll hit 100, hell yeeeaaaaaahhhh keep whor(e)ing
Need spellcheck turned on, where is it??
Not sure that the sight has built-in spell check.
I didn't think that, was ironic [emoji12]
Morning Swede
Weekends rock!
G'day mate
Whore
Buckhunt54
