Need Help!!!
I'm new to the forum, but a long time GM die-hard. Recently my 03 TB (ltz, 4.2, 4×4), turned into a nightmare. I stopped and filled the tank with 89, and within a couple miles it began to act like it had water in the gas, or was starving for fuel. It finally stalled, once started, everytime I gave it gas it would cut out and stall again. Towed home. New fuel filter, new fuel pump. Repaired the lines that were damaged with a high pressure union on the return, and a brass barb connector to join the main fuel line to the front of vehicle. (Would this Autozone technique cause a change in flow or fuel pressure?)
While waiting for fuel pump to arrive, I changed plugs to 41-103's, New coil boots and gaskets, cleaned the throttle body, careful not to get any cleaner inside plug or electrical component, changed air filter, idler assembly, both pulleys, and new serpentine belt. As well as some other little mods and fixes. I also found that the VVT connector had a gray in the wires and looked to be bare wire touching bare wire. So I junkyard dogged myself a nice length and rewired it with crimp connectors, which I hope will not interfere with electrical flow, or cause a disruption in flow? And plugged it back in.
I put half a tank or so of gas in the truck, hooked up the negative battery cable, turned it over, and nothing. No crank, no start. I did not have this problem before. I have since replaced the battery with a new one, replaced ignition switch, starter relay, fuel pump relay, and jumped the terminals in starter relay slot, confirming that starter and solenoid work. I pulled fuel line off at throttle body to check for fuel and there was none. I have all power, fuel pump energizes, no CEL, no funny noises, everything works like it should, except it won't start now.
A friend said there were a couple possibilities, it could be crankshaft position sensor, neutral safety switch, security bypass module, PCM itself, or it could need to go thru a re-learn phase. To leave key on, battery hooked to booster pack for half the day. I never heard such a thing. Is this true. Does anyone have any idea where I should start. I can't keep just buying parts. I'm not a certified mechanic, I know a little about diagnostics, don't have any fancy computer diagnostic test equipment. Code scanner. Test light. Multi meter. Fuel pressure gauge. About it. Please help. Any input is welcome and appreciated.
